Keith black bare hemi heads
#3142773
05/06/23 07:24 AM
05/06/23 07:24 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I have a pair of keith black bare hemi heads for hemi They have never been finished matching. No valves or anything I bought them long time ago I thought at time someone made a comment they were half where heads I can you tell? What do I need to look for. Would they be OK on a blown 572 motor on the street. What would the cost be to have the pair finished ready to bolt on block and run minis the rocker assembly? I already have new pair of indy hips heads. But someone was asking about these so I don't know value of the kb heads Or if I even want to sell them They are a cast head currently as mock up on my motor Yes I know can't tell much from the pics lol
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Keith black bare hemi heads
[Re: toplescuda]
#3142785
05/06/23 09:33 AM
05/06/23 09:33 AM
Posts: 2,639 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
There are many different configurations. D-port exhaust, rectangle exhaust, 10 bolt intake, etc. There may not be enough water in them for the street. More photos would be needed. I would be interested in buying them. You can call me or text photos to 501-519-7425 or email rick@rickseeman.com
2011 Drag Pak Challenger
[Re: rickseeman]
#3142801
05/06/23 11:01 AM
05/06/23 11:01 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Is there anything special to look at?pic of? Not really trying to sell them. But have no ideal how to tell difference in a full water/half water head I haven't even found any info on a keith black head at all to do research Much less value
[Re: toplescuda]
#3142802
05/06/23 11:06 AM
05/06/23 11:06 AM
Posts: 2,107 Byron, NY
W.I.N. Racing
Byron, NY
There are so many (more than likely better) heads available now and considering the cost of machining services, unless they are something special and you had the capability of doing your own machining they are serving their best use now...mock up heads. Part numbers and pics would help
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3142809
05/06/23 11:26 AM
05/06/23 11:26 AM
rickseeman
Stuttgart, Arkansas
I don't know how to tell a 1/2 water head. If it has all the normal water passages that would be good. If not I wouldn't try to use them. I have one now that I use for a mock up but I would like to have a pair. Mine appears to have normal water jackets. 1/2" head bolts and o-rings for top fuel. They might all have the same casting number. Mine is P4120711. If you can text me photos that would be great.
[Re: rickseeman]
#3142828
05/06/23 01:14 PM
05/06/23 01:14 PM
rickseeman
Stuttgart, Arkansas
The KB heads will have the steam holes in the wrong place for using on regular blocks. The real problem is brand new Edelbrock heads (that I'm sure flow much better) are only a little over $3,000 a pair, new and complete. Are yours D-port exhaust or rectangle part? Are the intake bolts the normal 16 bolt or 10 bolt?
[Re: rickseeman]
#3142903
05/06/23 09:20 PM
05/06/23 09:20 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Went over to shop pulled a head off So now....what can tell me about them. And value as is.. .no they are NOT for sale
[Re: toplescuda]
#3142905
05/06/23 09:24 PM
05/06/23 09:24 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
... Again they are not for sale. I'm just trying research them and gather as much info on them as possible Yes I know it will cost a good amount to have them ready to go down the road. But no hard Numb3rs of what $$$$ that would be(not counting rocker assembly)
[Re: toplescuda]
#3142916
05/06/23 10:10 PM
05/06/23 10:10 PM
W.I.N. Racing
Byron, NY
My guess based on parts cost is you will have at least $3000 in parts and labor.(assuming all parts are new and good quality) Guides - $25 ea seats - $20 ea SS valves - $50ea retainers $270 Locks - $60 Springs $600 Thats just the parts no labor.
[Re: toplescuda]
#3142948
05/07/23 12:18 AM
05/07/23 12:18 AM
rickseeman
Stuttgart, Arkansas
Went over to shop pulled a head off So now....what can tell me about them. And value as is.. .no they are NOT for sale It appears they have some water but I don't know how to tell a 1/2 water head. They look like KB heads as originally designed from the late 70's. 16 bolt intake and D-port exhaust. Later they also made them with 10 bolt intake. Mine has rectangle exhaust. I assume later they made some solid. And probably other variations also. I like 'em. But wow what a project. They don't even have the steel inserts for the head bolts or the head stud inserts. I don't know where to get those inserts for the head bolts but hopefully they are something standard. You asked about value. There's probably some fruitcake like me that would give $2,000 just because he likes 'em. But I can tell you the last time I sent a head like that to the shop for work the bill was shocking. Positively shocking. Thanks for sharing them with us. I think that's all I know about them.
[Re: rickseeman]
#3142954
05/07/23 01:31 AM
05/07/23 01:31 AM
rickseeman
Stuttgart, Arkansas
Of course there's no headers available for those either so you would have to make your own. I assume that is a standard D-4/D-6 port and bolt arrangement. They used to sell exhaust gaskets for those but I haven't seen any in forever. Those water passages are so small the guy that told you they were 1/2 water heads might have been correct. Especially since KB was a Top Fuel shop. They might have been made that way for strength. In the mid 70's the supply of aluminum hemi heads was drying up. The Ross Foundry heads, aka 433 heads, aka replacement heads, aka twin plug heads were the only thing they had. I don't know if Chrysler even had any left. The D-6 castings were so bad I never saw one on a Top Fuel car. All of Chryslers R&D at the time was based around the D-6 port head. And I don't know if they even used them. I think all their R&D heads were 433's turned in to D-6's by Mullins. I think Chrysler knew they needed new heads and I'm sure KB knew he needed new and stronger heads for his engines. At the time Chrysler and KB were in bed together. All 426 Hemi R&D at this time was done at KB's. KB knew the D-4/D-6 port looked the best so he got the patterns from Chrysler and the KB head was born. Still the best looking 426 Hemi ports. I have no idea what the idea of the rectangle port like mine is about.
[Re: rickseeman]
#3142969
05/07/23 06:59 AM
05/07/23 06:59 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well they came with a hemi package I had bought Really my only concern is weather or not they would live on a blown(14-71) pump gas application Reason for the 14-71....it's what's on hand and also can slow blower speed down and keep it under 10 pounds boost
Will never be in a drag car as long as own it. Just a fun stab n steer street car
[Re: toplescuda]
#3142977
05/07/23 08:05 AM
05/07/23 08:05 AM
rickseeman
Stuttgart, Arkansas
They will surely handle that. The problem is the cooling. There appears to be almost no water flow. When I get home today I’ll look at mine and see if they are any different.
[Re: rickseeman]
#3143040
05/07/23 02:29 PM
05/07/23 02:29 PM
rickseeman
Stuttgart, Arkansas
Ok, it appears you and I have gotten the education we were looking for over the past 2 days. The gentleman that called yours 1/2 water heads I would say is correct. There's just not much room for water to flow thru those tiny holes. Mine has what appears to be normal water jackets except they don't have the steam holes across the bottom. Without the freeze plugs in the end you can look right thru them and the water passages are large. And the upper water passage is large also. Based on what we know now I don't think you would want to use your heads on an application that was going to run for more than a few minutes. I love KB and it's been a pleasure working with you on this. For some reason my photos won't attach. I'll shut down and try again.
[Re: rickseeman]
#3143447
05/09/23 05:09 PM
05/09/23 05:09 PM
Posts: 3,504 DFW
mr_340
DFW
Mine look like the ones that Rick has. Ten bolt intake, rectangular port exhaust, raised floor exit.
Floyd Lippencott IV
[Re: mr_340]
#3143523
05/09/23 09:24 PM
05/09/23 09:24 PM
rickseeman
Stuttgart, Arkansas
If you decide you want to sell those I'd be interested. I'm kinda limited on what I can do with one.
[Re: 90%]
#3144229
05/12/23 05:56 PM
05/12/23 05:56 PM
rickseeman
Stuttgart, Arkansas
If I stick my finger in mine I can touch the back side of the combustion chamber.
