Post deleted by Defbob
[Re: DARTSPORT340]
#314244
05/11/09 12:25 AM
05/11/09 12:25 AM
Re: Turboing a big block?
[Re: polkat]
#314246
05/11/09 03:06 AM
05/11/09 03:06 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Turbo choice boils down 1000 percent to your realistic goals.. What kind of power do you REALISTICALLY want to make? How important are the spooling characteristics? At a certain point you have to choose between having low end boost for massive torque, and having a later spool (RPM wise) for higher horsepower combo's...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#314247
05/11/09 03:42 AM
05/11/09 03:42 AM
Posts: 960 NE Ohio
ixelerate
Go Buckeyes!
Go Buckeyes!
NE Ohio
theturboforums.com
go to the mopar section and there you will find a great amount of tech and guys there that have done turbos. The torque of a turbo engine is tremendous, meaning that everything in the motor has to be very strong. This also means some serious $. You can go a cheap route of course to save some dough but in the long run you will be paying. Boost tends to break things, and a weakly built motor will not last. On the other hand, a well built turbo big block will create monster power and even get pretty good gas mileage. Turbo 'd cars need lower geared rears which help in mileage and streetability. There are guys running 600 plus turbo motors on the street no problem.
[img] [/img][img]http://i277.photobucket.com/albums/kk45/ixelerate/random/falcon.gif[/img]
[Re: DARTSPORT340]
#314248
05/11/09 07:02 AM
05/11/09 07:02 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
It's probably going to eat the cast pistons before you even get over 8lbs of boost. You could run real cheap head gaskets and use them as a relief point and hope for the best
hhmmmmmm................
then I've got problems lol
