Page 8 of 15 1 2 6 7 8 9 10 14 15
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3134916
04/03/23 09:59 PM
04/03/23 09:59 PM
IL
furious70 Offline
furious70  Offline
IL
3" tailpipes pretty much fit like garbage on my Fury as well, I've never put the turndowns on and they took work to clear everything.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Thoughts on what to change to run mid 11's? [Re: furious70] #3134919
04/03/23 10:19 PM
04/03/23 10:19 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
The exhaust looks killer........thing just keeps getting better and looking cooler by the month LOL! I enjoy watching the progress!!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Thoughts on what to change to run mid 11's? [Re: furious70] #3135377
04/04/23 07:15 PM
04/04/23 07:15 PM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Thanks Wes! I'm just using this thread as a project update at this point.
After I ordered the exhaust, one of my other friends indicated the same thing, he had to have a shop fix the 3" TTI exhaust on his '68 300, it fit like garbage out of the box. If the mufflers clear my driveshaft I'll take it to an exhaust shop to get the tailpipes tucked up a little further.
Also, for the manual steering box, I might be able to pick it up this weekend. I'll text you later. I'll also be in Chicago hopefully in a few weeks to pick up the rearend and could stop by your house then too!
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3135460
04/04/23 11:27 PM
04/04/23 11:27 PM
IL
furious70 Offline
furious70  Offline
IL
we're around this weekend if it works for you!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3135953
04/06/23 02:06 PM
04/06/23 02:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Have you tried popping off the bottom of the shock to get the tires off?
It's a pretty common move on Fusey cars with big tires.
- Stu Harmon
Re: Thoughts on what to change to run mid 11's? [Re: feets] #3139801
04/21/23 05:44 PM
04/21/23 05:44 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Nick,
Its been a few weeks!!! Anymore updates to that STREET BRAWLER?!??!!
- A. Einstein
Re: Thoughts on what to change to run mid 11's? [Re: EvilB1Dart] #3139946
04/22/23 11:33 AM
04/22/23 11:33 AM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Hah!! Thanks... no noteworthy updates, besides stopping by Jeremy's to pick up the van/C body manual steering box.
I did a mini vacation last week to help my uncle with a 1958 Chrysler 300D he is restoring, then did some motorcycling in NC. Back home until Sick Summer now. My TTI headers showed up yesterday so I can start final installing the exhaust, and likely won't put the exhaust tips on until I can have a shop tuck the tailpipes up a little so it looks better.
Rearend should be done at Strange any week now, they accepted the order on 3/8 and said 8-10 weeks for lead time. Once it's done I'll make a quick day trip out to Chicago to pick it up. Then just need to bolt the Wilwoods on, bend up some brake lines, and get the driveshaft cut down.
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3142050
05/02/23 04:02 PM
05/02/23 04:02 PM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Update!! Got word the rearend was done, drove out to Chicago and picked it up yesterday. Now I've got some work to do...
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3142178
05/03/23 08:10 AM
05/03/23 08:10 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looks nice Nick!
69 GTX 68 Road Runner
Re: Thoughts on what to change to run mid 11's? [Re: JERICOGTX] #3142183
05/03/23 08:27 AM
05/03/23 08:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Thats a great start.
Doug
Re: Thoughts on what to change to run mid 11's? [Re: dvw] #3142199
05/03/23 09:20 AM
05/03/23 09:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks great!
68 Barracuda Formula S 340
Re: Thoughts on what to change to run mid 11's? [Re: Bad340fish] #3142202
05/03/23 09:31 AM
05/03/23 09:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow, that was quick!
'63 Dodge 330
11.19 @ 121 mph
Re: Thoughts on what to change to run mid 11's? [Re: GY3] #3142227
05/03/23 10:28 AM
05/03/23 10:28 AM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Thanks guys!
Quick question- are there any major drawbacks to running hard brake lines direct to the calipers on a fixed caliper system? The Wilwood brakes have the calipers fixed, and the calipers don't need to be removed to change pads, so the only time the calipers would ever need to be removed is if I needed to pull the axles. I could do a short section of flex line on each side but am not sure where to secure them to. There are little tabs on the housing but don't think they're designed to hold the weight of a flex line and fitting.
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3142233
05/03/23 10:46 AM
05/03/23 10:46 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did flex lines and just welded a little tab to the axle, but yours is already pretty and painted. I see no reason why you couldn't do a hardline. You could also make a tab that is captured by one of the T bolts that holds the bearing in if you thought you needed a flex line.
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3142239
05/03/23 11:26 AM
05/03/23 11:26 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by Blusmbl
Thanks guys!
I hope this makes sense, run your hardline on the floor of the body. then mount a tab to hold a bulkhead fitting above each side of the rearend near the frame rail. Run your flex line down to the caliper from that point. Makes it a lot more convenient to NOT have brake lines on the rear housing. Easier to tie it down for towing etc. AND the one time you need to service the caliper, you will wish it had a flex line on it....
....BAD A$$ STREET CAR.....
Re: Thoughts on what to change to run mid 11's? [Re: n20mstr] #3142266
05/03/23 12:37 PM
05/03/23 12:37 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thanks guys!
Where was this post in 2018 when I put a Dana in my car? Great idea.
Re: Thoughts on what to change to run mid 11's? [Re: Bad340fish] #3142353
05/03/23 06:18 PM
05/03/23 06:18 PM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
That is a great idea! I'll have to see where the lines will end up on the car. And agree- I would just weld little tabs on the axle but I don't want to jack up the powdercoat.
Re: Thoughts on what to change to run mid 11's? [Re: Blusmbl] #3142583
05/04/23 09:25 PM
05/04/23 09:25 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Hell yeah!!!! That's a nice piece, Nick! Right-on!
- A. Einstein
Re: Thoughts on what to change to run mid 11's? [Re: n20mstr] #3142586
05/04/23 09:34 PM
05/04/23 09:34 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Thanks guys!
X2 Good choice to upgrade the axle if you're still wanting to add power to this chassis!
Re: Thoughts on what to change to run mid 11's? [Re: HardcoreB] #3142911
05/06/23 10:05 PM
05/06/23 10:05 PM
Plymouth, MI
Blusmbl Offline OP
Blusmbl  Offline OP
Plymouth, MI
Right now I’m hoping to make it bulletproof for drag and drive events. I have less than a month until Sick Summer and need to get it drivable again asap!
Thinking the goal next year will be getting the Trick Flows installed, and then 2025 will be a 512 kit and beefing up the trans. The chassis should be as far as I can go with a stock suspension C body at this point.
The car is at the alignment shop currently but I did get the Wilwoods on yesterday. I do appreciate the irony of doubling the value of the car with a rearend install. laugh2
