suncoast 68RFE clutches? #3142013
05/02/23 02:01 PM
05/02/23 02:01 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I'm rebuilding a 68RFE and when I opened it up it had a suncoast drum in it and the stock clutches in the re-build kit won't fit. Suncoast said they don't sell just the clutches so I need to figure out what clutches they are using, does anyone know? I figure they didn't make custom clutches and just found something bigger they could fit in there but what did they come from? Customer don't want to buy another $1800 drum that didn't fix the problem.
Re: suncoast 68RFE clutches? [Re: HotRodDave] #3142016
05/02/23 02:09 PM
05/02/23 02:09 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
What are the dimensions of the frictions? Thickness, tooth count, OD, ID? I would bet they used frictions that are somewhat readily available.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
