Re: Slow progress
[Re: an8sec70cuda]
#3140612
04/25/23 12:15 PM
04/25/23 12:15 PM
Posts: 4,679 On the parachute mount
n20mstr
Thanks again for all the kind words A couple more pics of some details . I separated the crank and cam synch wires , master cylinder is mounted inside firewall now
....BAD A$$ STREET CAR.....
Re: Slow progress
[Re: n20mstr]
#3140627
04/25/23 12:54 PM
04/25/23 12:54 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Nice job on the firewall, car is looking good Tony. At any point did you consider using a Deustch bulkhead connector? I'll admit it is a bit of a PITA with the solid contact tooling but it's a nice solution.
'71 Duster '17 Ram 1500
Re: Slow progress
[Re: RMCHRGR]
#3140629
04/25/23 12:58 PM
04/25/23 12:58 PM
n20mstr
Nice job on the firewall, car is looking good Tony. At any point did you consider using a Deustch bulkhead connector? I'll admit it is a bit of a PITA with the solid contact tooling but it's a nice solution. Consider it , Sure .... can i afford the tools to do it...NO Great job on your firewall also ! ! ! All it takes is practice , glad to see it came out nice
Re: Slow progress
[Re: n20mstr]
#3140636
04/25/23 01:19 PM
04/25/23 01:19 PM
RMCHRGR
Spahn Ranch
Nice job on the firewall, car is looking good Tony. At any point did you consider using a Deustch bulkhead connector? I'll admit it is a bit of a PITA with the solid contact tooling but it's a nice solution. Consider it , Sure .... can i afford the tools to do it...NO Great job on your firewall also ! ! ! All it takes is practice , glad to see it came out nice Thanks. It was a lot of work. The Deutsch crimp tool I got is an "offshore" knock off that was under $200. Still a lot of course but not $500 or whatever the real TE ones are. It's fine for what I'm doing. Looking forward to seeing your car go down the track. Keep the updates coming!
Re: Slow progress
[Re: RMCHRGR]
#3140720
04/25/23 07:43 PM
04/25/23 07:43 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
We have used the Duetsch stuff for a few years now. Yes there is an initial investment for stuff but nice and clean way to do it. But still stuff we don't run through it. Crank trigger being one. The further we can keep it from ANY other noise source the better,
Re: Slow progress
[Re: Al_Alguire]
#3140745
04/25/23 10:04 PM
04/25/23 10:04 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
How about using shielded cables for those noise sensitive circuits, like in aircraft and computers?
Re: Slow progress
[Re: Cab_Burge]
#3140782
04/26/23 08:07 AM
04/26/23 08:07 AM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Looking great and loving the attention to detail. The color combo is just perfect!
Re: Slow progress
[Re: Cab_Burge]
#3140820
04/26/23 10:55 AM
04/26/23 10:55 AM
Al_Alguire
Las Vegas
How about using shielded cables for those noise sensitive circuits, like in aircraft and computers? They are already twisted and shielded wire for the crank trigger. Asd far away from any other electrical interference is the preference for me. Been there done that
Re: Slow progress
[Re: n20mstr]
#3149643
06/08/23 08:32 AM
06/08/23 08:32 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Looking great. Wow. I almost understand what it all does and where it all goes to, but not quite. Moving the radiator forward seems to create alot more space where it's needed.
Rich H.
Esse Quam Videri
Re: Slow progress
[Re: HardcoreB]
#3149673
06/08/23 10:54 AM
06/08/23 10:54 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Very nice, clean, and all business!
Re: Slow progress
[Re: moparx]
#3149778
06/08/23 04:22 PM
06/08/23 04:22 PM
Al_Alguire
Las Vegas
what, or where, is the overflow tank from, and how much does it hold ? Pretty sure what you are talking about is a "surge" tank. The radiator lower than the engine creates an issue. That tank allows Tony to fill the engine with water and not have any air pockets. Looks awesome Tony cant wait to see it run.
Re: Slow progress
[Re: Al_Alguire]
#3150198
06/10/23 10:30 AM
06/10/23 10:30 AM
n20mstr
what, or where, is the overflow tank from, and how much does it hold ? Pretty sure what you are talking about is a "surge" tank. The radiator lower than the engine creates an issue. That tank allows Tony to fill the engine with water and not have any air pockets. Looks awesome Tony cant wait to see it run. It’s a 1.5 quart surge tank . If you look close , it’s fed on the bottom from the block , and there is a bung welded on the upper side to feed the radiator. There is a pressure transducer to data log coolant pressure (keep tabs on head gasket life) Yes Al is also correct , you need a “high” spot to bleed air out of the cooling system . It solves a lot of issues
