Surgery for Siatica #3140773
04/26/23 07:15 AM
04/26/23 07:15 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
wondering if anyone has had recent surgery for this ? I've had it for about 2 yrs. I have learned exactly what the term debilitating means. I have pain from my left hip down to my knee. Feels like a lightening bolt and turns on and off like a switch. Gets worse as the day goes on. I'm trying to find 2 neurosurgeons that recommend the same procedure. My back feels fine. So far one doc says get a simple procedure to eliminate interference with a nerve and a piece of vertebra, the other, a full back reconstruction. thoughts ?
Re: Surgery for Siatica [Re: varunner] #3140781
04/26/23 08:04 AM
04/26/23 08:04 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I had it once, it lasted about 10 days , that was enough, there is several exercises to do to make it lessen or go away
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Surgery for Siatica [Re: bigdad] #3140788
04/26/23 08:20 AM
04/26/23 08:20 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Mine has always went away on it`s own. Some times it lasted a long time to recover. Never needed surgery yet. I have learned what not to do to help it not happen again.
Re: Surgery for Siatica [Re: mopars4ever] #3140798
04/26/23 09:19 AM
04/26/23 09:19 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here's what they did at Mayo Clinic in Rochester, MN to cure my sciatica. However, there were a lot of problems with my back. Pain is gone.
Re: Surgery for Siatica [Re: TooMany62s] #3140841
04/26/23 12:35 PM
04/26/23 12:35 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am sure everyone's circumstances are different but my brother manages his sciatica with a monthly infusion.
However he has other back problems that have required multiple surgeries.
Re: Surgery for Siatica [Re: varunner] #3140844
04/26/23 12:53 PM
04/26/23 12:53 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
I had a diskectomy done in 2006, and am happy with the outcome.
The nerve pain was gone pretty much immediately.
However, the muscle/tissue recovery was a slow, gradual process (lots of muscle spasms in the beginning). After about 2 years I was back to running a sub-12 minute 1.5 miles. I know...that's no land speed record, but it was my indication that I was finally "healed."
Everyone's recovery is different. Don't half-@$$ your physical therapy, but don't over do it either.
Hey...we're not 20 years old anymore. Don't expect miracles, but trust that you will be better off having the procedure done.
Re: Surgery for Siatica [Re: varunner] #3140849
04/26/23 01:32 PM
04/26/23 01:32 PM
IMGTX Offline
IMGTX  Offline
I have a bad disk that puts pressure on the Sciatic nerve.
I am able to manage it with Physical Therapy and lots of hanging upside down on a slant board.
I started at a slight slant and worked my way up to fully vertical. Imminently after getting off the board I lay down and let my back settle for at least 20 to 30 minutes.
It does wonders.
My doctor said right off the bat surgery is a last ditch situation. He said I had ever heard of anyone's back getting stronger from cutting on it.
You may already have tried this but if you choose surgery choose the least invasive one, You can always go back for more but never put back what has been removed.
Re: Surgery for Siatica [Re: TooMany62s] #3140858
04/26/23 02:06 PM
04/26/23 02:06 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Is that what a fusion looks like ?
Re: Surgery for Siatica [Re: varunner] #3140859
04/26/23 02:14 PM
04/26/23 02:14 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I'm all in for surgery, but just how invasive a surgery I need is the question. As a 65 y.o. man that's had an active life, I'm not surprised to hear that I've got multiple issues going on. I've had 2 MRI scans. In my mind I just want to fix what's causing the pain and not fix other issues that aren't causing pain.
thanks for the reply's
Re: Surgery for Siatica [Re: varunner] #3140865
04/26/23 02:53 PM
04/26/23 02:53 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
My dad suffered from sciatica for a period and also found the specific exercises very helpful. A friend a work suffers bad, and was told to lose weight. He's at least 50 lbs. over weight. My dad has never been over weight but probably too much sitting aggravated his. I haven't known anyone to have the surgery but I'd try everything else first. Good luck.
Facts are stubborn things.
Re: Surgery for Siatica [Re: larrymopar360] #3140914
04/26/23 08:55 PM
04/26/23 08:55 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I had back issues for years. Tried everything from PT and Cortisone to inversion tables. Nothing did much to help. The pain would shoot down my leg to my knee. Horrible...wouldn't wish it on my worst enemy! Finally decided to do the surgery...L4-L5-S1 fusion. Long story short...my insurance company f'd my Dr around and we ended up doing it twice. It helped but wasn't a complete cure. Year or so later was decided I needed a new hip on that side. Had that done in Dec and haven't looked back! 3 surgeries in 3 years but...no more back pain, no more shooting pain down my leg! It's fantastic!!! Good luck to anyone fighting back, leg, sciatica type pain...it sucks!!!
Re: Surgery for Siatica [Re: Dcuda69] #3140957
04/27/23 08:06 AM
04/27/23 08:06 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I appreciate the info, some tough stories out there. I tell ya, I think what annoys me the most is the basic state of affairs of the health systems in general. I live in southeast virginia and there are a bunch of for profit health systems here. You would think it would fairly easy to get appointments, second opinions, Nope, any request takes months. And don't even ask for a pain reliever.......
I'll be getting a second opinion in about a month. I'll update then. Thanks !
Re: Surgery for Siatica [Re: varunner] #3140958
04/27/23 08:20 AM
04/27/23 08:20 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
For what its worth, my father had fusion done. He was 66. He was a large man(not fat) and suffered from degenerative back issues most of his life. He always worked through the pain, until he couldn't. The injections stopped working. It was hard to watch. He got the surgery, and it was a huge success. About a year recovery time with pt. My point is, the surgeon after the procedure discussed the operation and what he saw. When they were correcting the real estate, they uncovered his sciatic nerve from a destroyed disc. When they did this, the nerve immediately started to fill/flow blood. That was the first thing he noticed when he woke up was the strange feeling of no pain in his left hip/leg.
Re: Surgery for Siatica [Re: moparjim79] #3140966
04/27/23 09:07 AM
04/27/23 09:07 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Good to know. If I need a fusion, I'll get one. But want to get what I need the first time, if possible....... Right now I have two recommendations, radically different. Hopefully the third one will confirm what I need.
Re: Surgery for Siatica [Re: varunner] #3140977
04/27/23 10:08 AM
04/27/23 10:08 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I've had 3 lower spinal surgeries since 2013 with the most recent being a 3 disc fusion in 2018. Surgery was my only option as the previous surgeries were band aids that didn't last. I'm fine and it worked. But recovery is very slow (I was 50 at the time.) Now back in 2018 Norco did not help with my recovery pain and this was before the crackdown on opioids. They prescribed me plenty but the pain overpowered it. The first 4 days after surgery was the absolute worst for me. I have NEVER been a pot user. But a friend heard I was suffering and brought me some edibles. The edibles (cookies) made me sleep sleep and sleep PAIN FREE. I was able to make it thru that initial painful few days after surgery. After 4 days I stopped the edibles (maybe I didn't)
and the Norco was enough.
Keep old mopars alive.
Re: Surgery for Siatica [Re: varunner] #3141012
04/27/23 12:23 PM
04/27/23 12:23 PM
N.W. Florida
N.W. Florida
It'll be important to do as much research/vetting on your neuro/spine surgeon as possible. Some have far greater success rates than others. Being in VA, you probably have some "world class" neurosurgeons within the region. It would certainly be worth the extra effort to get to the best that accepts your insurance.
The aggravating process you're going through isn't unique to your area, unfortunately. It's tough to be patient when you're in constant pain. Once you find the surgeon you're comfortable with, talk to him/her about getting fast-tracked to operating table. Maybe they can get you in sooner, maybe not, but it's worth asking the question. Having been there, I wish you the best. up
Re: Surgery for Siatica [Re: varunner] #3141028
04/27/23 02:26 PM
04/27/23 02:26 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Keep in mind that if the symptoms are being caused by nerve root impingement (usually a disc, sometimes a bone spur) that surgery will fix the mechanical problem but no surgeon will guarantee a relief of pain. Spinal stenosis is hard to fix and operating can cause scar tissue that worsens the problem! If the sciatic nerve is being entrapped somewhere in the hip instead, that's the area that needs repair, of course.
Not only that, in the long run (10-15 years or more) the outcome measured in mobility and pain level is about the same for people who had disc surgery vs. those who did not. Individual cases vary, naturally, and no one intervention from epidural steroid injections, electrical stimulation, physical therapy (or even a chiropractor if it works), and surgery are 100% effective.
I do wish you the best possible outcome though! up
Disclaimer: not medical advice, no doctor-patient relationship established, etc. Freakin' lawyers rolleyes
Re: Surgery for Siatica [Re: DrCharles] #3141030
04/27/23 02:41 PM
04/27/23 02:41 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Some folks have the pain resolve on its own over time. Some resolve with PT. Some with home exercises or going to the gym. There are lots of articles out there about exercises, stretches and such to help.
Sometimes injections help. Surgery is definitely what you do when you have exhausted all conservative therapy and cannot live with the pain any longer.
If you go with surgery, find out everything you can about the doctor who is going to do the procedure. You probably wouldn't take your hemi Superbird to Jiffy Lube. Your spine needs an expert as well - -and the skill levels of doctors vary wildly. Many people have great outcomes. And some were better off before they had surgery.
Re: Surgery for Siatica [Re: Tom_440] #3141036
04/27/23 03:28 PM
04/27/23 03:28 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Once again guys, I appreciate the feedback.
Re: Surgery for Siatica [Re: varunner] #3141151
04/28/23 08:53 AM
04/28/23 08:53 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
My mother had the worst back x-rays.
Twice, at different MD offices I have heard them say to her:
“Mrs xxxxx, I look at your x-rays and I honestly do not know how you walked in here without help ! “
As a young boss in the 1980s I had employees who injured their backs at work, were slow to heal, and elected for back surgeries.
None ever were able to really recover or be free from pain.
I have had a now deceased family member who had 2 back operations that afterwards she did not feel were successes.
My mother, a doctor’s daughter who had 4 MD grandchildren,
never had back surgery.
She was no stranger to hospitals, had several complicated operations, such as having a fiber threaded up from the leg to the head to pull a clot loose from deep in her brain.
I witnessed two different Hospice MDs do legally required exams on her and both remarked:
“That is a really bad back, it curves in all directions.”
What worked best for my mother was the very special pain reliever
Tramadol.
Tramadol is one of the most complicated drugs.
When you swallow it, the drug is changed six different times before it leaves your body.
It is like taking one pill that contains 7 different “time release” drugs.
Not all 7 drugs are pain relievers.
Tramadol can lower blood sugar level,
even to dangerous levels in some people at relatively low Tramadol doses,
because people’s blood sugar levels vary a lot, and vary by time of day.
Tramadol is generally accepted as the opioid-class drug least likely to cause addiction.
Despite that, many criminal drug smuggling rings use Tramadol to “cut” other drugs to dilute them before sale.
What award winning MD and long time medical school professor
really has studied back problems
and speaks the truth as he sees it?
This one:
https://uncpress.org/book/9781469642253/stabbed-in-the-back/
If you give back doctors 100 of randomly mixed up x-rays of patient backs to read:
50 of which are patients complaining of severe back pain
50 of which are patients with no back pain, but needed an xray for another reason
can the back doctors correctly identify the xrays with back pain?
The book above has the answer.
