Federal P/S Pump - Hose O-Ring Question #3140680
04/25/23 05:04 PM
04/25/23 05:04 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Question about the O-ring that is used in Federal power steering pumps where the high pressure hose fitting attaches to the pump. I have both an NOS pump rebuild kit and an aftermarket. Both kits include two different style O-rings that I assume are for the hose fitting. Do I use one or the other or both?
First pic shows the two different style o-rings.
Second pic shows the flat o-ring in place in the p/s pump. Seems like a perfect fit but why the xtra round o-ring?
Re: Federal P/S Pump - Hose O-Ring Question [Re: floyd] #3140765
04/26/23 04:53 AM
04/26/23 04:53 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
When I redid my Federal pump, I used the smaller O ring for the hose and the taller one on the bolt that holds the tank
to the pump.
Re: Federal P/S Pump - Hose O-Ring Question [Re: solarguy] #3140780
04/26/23 08:03 AM
04/26/23 08:03 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Uh oh, I can’t remember noticing a seal around that bolt.when I rebuilt mine.
Re: Federal P/S Pump - Hose O-Ring Question [Re: floyd] #3140812
04/26/23 10:22 AM
04/26/23 10:22 AM
VA
dragon slayer Offline
VA
Been a long time since I did this. Did the kit directions tell you which seals included? That tall seal looks to tall for the bolt seal, but it may be optical look. I did not think the kit had seals for hose, I thought they came with the hose.
Re: Federal P/S Pump - Hose O-Ring Question [Re: dragon slayer] #3140822
04/26/23 11:09 AM
04/26/23 11:09 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks for the replies! Solarguy, you probably saved me a big mess or at a minimum a constant leak. Yep, the flat style o-ring is for the reservoir bolt hole. Forgot that on assembly. Installed now and my question has been answered regarding the high pressure hose. Thanks again
