Re: Slow progress
[Re: n20mstr]
#3153522
06/22/23 10:06 AM
06/22/23 10:06 AM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
We have some progress here, and it cranks over Fuel Economy - Disabled...
'71 Duster '72 Challenger '17 Ram 1500
Re: Slow progress
[Re: n20mstr]
#3153555
06/22/23 12:31 PM
06/22/23 12:31 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Looking good. I think we are anxious to see it run for sure.
Re: Slow progress
[Re: HardcoreB]
#3160893
07/19/23 10:33 AM
07/19/23 10:33 AM
Posts: 10,041 MN
JERICOGTX
MN
Things are gonna start happening now...
69 GTX
68 Road Runner
Re: Slow progress
[Re: n20mstr]
#3160924
07/19/23 11:47 AM
07/19/23 11:47 AM
Posts: 4,694 Wichita
GY3
Wichita
Firecore wires , on point with service and fast turnaround. Rick is a great guy to deal with Such a slick setup with the coil near plug.
Re: Slow progress
[Re: GY3]
#3168441
08/17/23 07:54 AM
08/17/23 07:54 AM
Posts: 4,689 On the parachute mount
n20mstr
went to a hub dyno yesterday, lets just say ....it made a lot of power , more than i expected . on the SMALLEST nitrous jet Couldnt really test bigger jets. We stopped because the converter pressure started reading 300 . I checked the thrust endplay and its right where it was on the build sheet. Im hoping that the sensor is bad. In Rosslers directions it say NOT to use the senosr i used. Hopefully it is just the sensor.
....BAD A$$ STREET CAR.....
Re: Slow progress
[Re: n20mstr]
#3168571
08/17/23 04:13 PM
08/17/23 04:13 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Well that sounds like fun...I bet it made a rather substantial, although undisclosed number!
I remember testing on the dynapack hub dyno, my first time ever at a friend of Blusmbl's and that was a good experience.
I would have gone back again later but the owner said the torque number was too concerning for him, he thought it'd damage the machine.
Pretty safe to say yours is making more torque than mine ever dreamed of!!! I think his was a model 2000? Not sure what it can take.
Switched to a different shop with dynojet/Jake's and will probably stick with them as long as they will have me.
Rich H.
Esse Quam Videri
Re: Slow progress
[Re: n20mstr]
#3171115
08/28/23 03:41 PM
08/28/23 03:41 PM
Posts: 34,934 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
After my mess with Cope , trans problems can take the wind out of yah, that sucks
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Slow progress
[Re: n20mstr]
#3171153
08/28/23 05:40 PM
08/28/23 05:40 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
WELL....not so good. Something in the converter broke, as it was throwing a lot of aluminum. The trans is already at Rossler and the converter is on its way back. I’ve been following along with Steve Morris’ trans woes on his wagon. When you start making the big numbers, things you(I) never thought of start becoming problems in the trans/converter. Hopefully you get it sorted out without too many headaches.
Re: Slow progress
[Re: bigdad]
#3171197
08/28/23 08:00 PM
08/28/23 08:00 PM
n20mstr
After my mess with Cope , trans problems can take the wind out of yah, that sucks deal with Rossler is great to deal with, this is my second Rossler trans and they have been flawless. The Converter manf, this is the first time i, using their product. They have a one year warranty on race converters, and told me send it back we will take care of it. I guess i will see how that works out.
Re: Slow progress
[Re: fast68plymouth]
#3171198
08/28/23 08:02 PM
08/28/23 08:02 PM
n20mstr
WELL....not so good. Something in the converter broke, as it was throwing a lot of aluminum. The trans is already at Rossler and the converter is on its way back. I’ve been following along with Steve Morris’ trans woes on his wagon. When you start making the big numbers, things you(I) never thought of start becoming problems in the trans/converter. Hopefully you get it sorted out without too many headaches. It makes really good power. but not Steve Morris power LMAO.....its under 2,000hp
Re: Slow progress
[Re: n20mstr]
#3172783
09/04/23 11:20 AM
09/04/23 11:20 AM
n20mstr
While waiting for converter and trans , knocking out the final interior details . Touched up the dash and got it all done .
Re: Slow progress
#3172813
09/04/23 01:08 PM
09/04/23 01:08 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Beuatiful work. At least there are two cars out there with brown interiors. Now to seat belts. You can get black, silver, purple, red, orange, blue, lime green, pink, yellow. But brown ot tan, Ah no. Doug
