Straightening a bent axle housing #3140536
04/25/23 12:20 AM
04/25/23 12:20 AM
WA
Air Grabbler Offline OP
WA
I have a 68-70 B-body Dana 60 axle housing that was raced and spent some time under a Camaro. I'm building it to put under my 69 road runner.
When I installed my D60 narrowing fixture I found that one of the tubes is bent such that the bearing housing is about 1/8" out of alignment with the carrier bearings. I heated and quenched the tube but this had zero effect. The next attempt will involve the careful use of a press to straighten it.
Question: is there a tolerance associated with axle housing straightness? Or does any amount of misalignment cause excessive bearing and tire wear, unacceptable axle shaft sideloads, and a car that tracks or launches poorly?
Thanks!
Re: Straightening a bent axle housing [Re: Air Grabbler] #3140539
04/25/23 12:26 AM
04/25/23 12:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You do NOT want the rear axle to steer the car.
Use a bar slid through the axle end-to-end to know it's dead straight.
Re: Straightening a bent axle housing [Re: Air Grabbler] #3140545
04/25/23 02:45 AM
04/25/23 02:45 AM
I know several chassis shops that straighten Dana and other housing by heating small places on the axle tubes near the housings(1 to 3.0 inches out from the edge of the housing) and then quenching them with water soak rags until they get it straight enough for them to use, wrench weld
Try again and don't quit weld
I use a pair of carpenter squares laid onto the bolts that the bolts that hold the backing plates onto the housing and then measure 15.0 inches out from the center of the housing to the end and then to the other square held on the other side to see how much toe in or toe out they have, same thing up and down also wrench scope
You can use two nuts with large diameter flat washers to hold the squares up against the axle flanges up scope I shoot for no more than 1/8 inch toe in on the front side towards the front bumper up
Let us know what you do and how you do it once you get it fixed please luck
Re: Straightening a bent axle housing [Re: Cab_Burge] #3140555
04/25/23 07:01 AM
04/25/23 07:01 AM
WA
WA
Topside: 10-4, I figured the housing had to be straight as possible.
Cab, are you saying apply heat 1-3" away from the center casting? I was applying heat in the center of the tube (half way between the center casting and the bearing end. I have a Mark Williams narrowing fixture I'm using to check straightness. It is a 2.5" precision ground bar with three steel bushings. Two bushings locate in the carrier bearing saddles and the other slides into the axle bearing housing.
Re: Straightening a bent axle housing [Re: Air Grabbler] #3140557
04/25/23 07:15 AM
04/25/23 07:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I haven't done a Dana . But I did do an 8 3/4". Heated and quenched about where the perches would go. You could watch the tube move the wrong way when heated. Then move back when cooled. However the Dana tube is much thicker. I'll bet it would take a ton of heat. My bet is 1/8" probably won't hurt anything. Now if it had toe in/out that would be different. Bolt some straight stock (center a 3 foot piece) to the housing flanges and measure the difference at the front vs the rear. That'll tell you what the toe is. You could always cut the end off if its bad enough and reweld it on in the exact spot. Measure it first and see.
Doug
Re: Straightening a bent axle housing [Re: dvw] #3140596
04/25/23 10:33 AM
04/25/23 10:33 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I'm wondering if a bead of weld could be placed longitudinally on the tube? I know stuff always moves when welded that you DON'T want to move wink
Re: Straightening a bent axle housing [Re: DrCharles] #3140609
04/25/23 11:46 AM
04/25/23 11:46 AM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
Southwick machine Colona IL 1-309- 949- 2868 straighten axles all the time [stock car, demo car, big ford ends on TR-6 road race car's, ship those all over the world ] never seen them use heat ,just the centering bar and a big press they even will replace tubes in dana's if you need.
Re: Straightening a bent axle housing [Re: dvw] #3140611
04/25/23 12:10 PM
04/25/23 12:10 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I However the Dana tube is much thicker. I'll bet it would take a ton of heat.
Yep, that's the trick...more heat on a larger area close to the center before quenching. You want the housing as close to dead straight as possible or you can have premature axle bearing and spline wear.
Re: Straightening a bent axle housing [Re: John_Kunkel] #3140661
04/25/23 03:24 PM
04/25/23 03:24 PM
WA
WA
I'll keep everyone posted on this. I burned a lot of acetylene trying to heat and quench the tube to no avail so I'm going to try the press next. I ordered a large Vee block to try to avoid crimping the tube. My plan is to go slow and see how the tube reacts to the pressure. I figure I'll probably wind up having to push it slightly beyond straight and let it spring back. I can also use the torch in combination with the press if need be. I don't want to create a larger problem than I already have!
Re: Straightening a bent axle housing [Re: Air Grabbler] #3140681
04/25/23 05:07 PM
04/25/23 05:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Two rules when straightening with a torch.
1) Heat where the bend is.
2) Heat on the long side of the bend. The bend should get worse with heat and when quenched will move to get better.
Our mechanics straightened 10" vertical pump shafts with a torch and a rag in a water bucket.
Re: Straightening a bent axle housing [Re: 6PakBee] #3140699
04/25/23 06:18 PM
04/25/23 06:18 PM
WA
WA
6pakbee, I did it exactly like that. I clearly wasn't able to get enough heat in the tube with my large rosebud to move the tube. It didn't budge during heating or quenching. I made six attempts with zero results. I could only get a 2-3" area of the tube to a very dull red color.
Re: Straightening a bent axle housing [Re: Air Grabbler] #3140728
04/25/23 08:11 PM
04/25/23 08:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Then you have done all you can do with what you have using that technique. up
Re: Straightening a bent axle housing [Re: Air Grabbler] #3141673
05/01/23 08:55 AM
05/01/23 08:55 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Don't use a rosebud to heat the tube, use a cutting torch, heat and make a 1/2 inch wide band about 1/2 way around the tube, as this cools, gently heat
the other side of the tube, this allows the tube to shrink on one side aided by expansion on the other side.
Re: Straightening a bent axle housing [Re: MO_PA] #3141800
05/01/23 04:55 PM
05/01/23 04:55 PM
Minnesota
VcodeR/T Offline
VcodeR/T  Offline
Minnesota
We straighten axle housings in-house. A large press, line bar and holding fixture is what we use. They are all done cold. Here's a couple pic's of before and after. Good luck on your project!
Re: Straightening a bent axle housing [Re: VcodeR/T] #3141844
05/01/23 07:26 PM
05/01/23 07:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a bent trailer axle and have been unable to find a replacement, guess I will be taking it out and trying some of these techniques... weld
JB Rhinehart, Realist
A-Body's RULE!
Re: Straightening a bent axle housing [Re: Rhinodart] #3141941
05/02/23 10:01 AM
05/02/23 10:01 AM
Findlay
Ramman Offline
Ramman  Offline
Findlay
Make darn sure your "bent" trailer axle isn't by design.
Re: Straightening a bent axle housing [Re: VcodeR/T] #3142010
05/02/23 01:50 PM
05/02/23 01:50 PM
moparx Offline
moparx  Offline
that's how i have done it.
also use that method when narrowing the rear housing. i use two support slugs for the bar at the differential bearing locations as well, so everything is in the proper location.
doing it this way insures axles will slide in without effort.
one would be surprised just how off a factory axle housing can be at the ends, and still function just fine....... biggrin
beer
Re: Straightening a bent axle housing [Re: Ramman] #3142184
05/03/23 08:34 AM
05/03/23 08:34 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes, I agreed to cut a trailer axle down for a friend. When I started working on the axle I realized it had built in camber. In order for the axle to be right I had to cut and remove the same amount of tube from each side of the bend. It was a pain but it came out well.
Re: Straightening a bent axle housing [Re: justinp61] #3143644
05/10/23 01:20 PM
05/10/23 01:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I was able to make progress with an I beam, bottle jack, and a chain.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Straightening a bent axle housing [Re: Hemi_Joel] #3143664
05/10/23 02:08 PM
05/10/23 02:08 PM
moparx Offline
moparx  Offline
i have done that before as well, when a shop press wasn't available.
still used the solid bar and alignment pucks for the ends, with bearing bucks bolted to the differential where the bar passes through.
it still amazes me just how far off an original, unmolested housing can be as far as outer bearing ends are in alignment, and still have very long bearing life.
beer
