Re: WIW, NOS manual steering box
[Re: justinp61]
#3140355
04/24/23 11:31 AM
04/24/23 11:31 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
The compatibility problems with different boxes largely boils down to output shaft, or sector shaft size. First, there are two sector sizes, simply known as large or small sector. The large sector, just above the splines as it exits the housing, measures 1.22". The small sector measures 1.11".
62-76 A-bodies, 62-72 B-bodies, and 70-74 E-bodies all used the same manual box. Most of these boxes used bushings throughout, however, the B-body V-8 units were built for more abuse and used bearings internally instead of the bushings. All manual boxes used a small sector shaft with the exception of C-bodies and vans to 1988. The big cars and vans used a large sector, presumably for added strength. It's also assumed these boxes used bearings instead of bushings.
from: https://www.forbbodiesonly.com/mopa...-steering-gear-box.165931/post-911156833, emphasis mine.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: justinp61]
#3140924
04/26/23 10:40 PM
04/26/23 10:40 PM
Posts: 9,497 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Box is dated 10-9-84 part is stamped 6-25-84. 4023 starting PN would fall into line as well. Early 80-s truck/van? Probably get $200
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3141436
04/29/23 11:15 PM
04/29/23 11:15 PM
Posts: 2,255 IL
furious70
IL
yup that canted top plate tells you its a van/c body one. While not hugely sought after, $200-300 for one you know isn't worn out doesn't seem bad. I have a used one I was trying to get that range for and the guy said no thanks. I sold another one cheaper but to a friend. It was also used.
70 Sport Fury 68 Charger 69 Coronet 72 RR
