1970 challenger rtse wiring question #313481
05/10/09 12:36 AM
05/10/09 12:36 AM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Hi Does anybody have a picture of the clips that hold the wiring harness for the door ajar switch.The harness runs along the parcel shelf(rear speaker tray).Thanks in advance
Re: 1970 challenger rtse wiring question [Re: sam c] #313482
05/10/09 08:20 AM
05/10/09 08:20 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It only from my memory, but I think they are the same ones that are used to hold the antenna cable underneath the glove box to the dash frame.
Re: 1970 challenger rtse wiring question [Re: fastmark] #313483
05/10/09 05:55 PM
05/10/09 05:55 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
They look close to the under dash clips but they're bigger and they fasten using an added barb to hold them in the upright position through a hole in the back seat bracing...The clip is unique but it's the same clip holds all the wiring across that bracing area...Speaker,rear defroster, and door ajar all rely on that clip...Here's a pic I borrowed from Alan's rear defroster thread showing the clip...
Re: 1970 challenger rtse wiring question [Re: screamindriver] #313484
05/10/09 08:57 PM
05/10/09 08:57 PM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Thanks for your help. I am sure these clips are not going to be easy to find any ideas?
Re: 1970 challenger rtse wiring question [Re: sam c] #313485
05/10/09 11:03 PM
05/10/09 11:03 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
screaming is probably correct. I pulled a clip from underneath a 68 Dart I am restoring from the rear shock area and it looked just like that and it had the barbs. It might be the same one. I am sure they used that clip somewhere else. A trip to the wrecking yard might be in order?
Re: 1970 challenger rtse wiring question [Re: fastmark] #313486
05/11/09 09:06 AM
05/11/09 09:06 AM
cataclysm80 Offline
cataclysm80  Offline
I heard it was similar to a cuda road lamp wiring clip (up by the valance). I haven't checked it out myself though.
Tav
Re: 1970 challenger rtse wiring question [Re: cataclysm80] #313487
05/11/09 06:23 PM
05/11/09 06:23 PM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Tav
Problem with the roadlamp clips is that they do not push into a hole like these ones do.I guess going to a scrapyard is the only alternative
