Re: Rear Wheel Spacers [Re: DAYCLONA] #3141601
04/30/23 08:00 PM
04/30/23 08:00 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Dayclona, who makes those spacers? I like em.
Re: Rear Wheel Spacers [Re: JFChallenger440] #3141796
05/01/23 04:52 PM
05/01/23 04:52 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by JFChallenger440
These are the type of spacers I mean
They bolt on to the hub and have their own studs built in
These are not spacers - they are adapters. Huge difference.
Re: Rear Wheel Spacers [Re: markz528] #3141802
05/01/23 04:59 PM
05/01/23 04:59 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
These are mine. I have no concerns. Lug centric
Re: Rear Wheel Spacers [Re: markz528] #3141803
05/01/23 05:02 PM
05/01/23 05:02 PM
London, England
JFChallenger440 Offline OP
London, England
How do you mean ?
They are bolting on to my 97 Mustang hub and then a Ford bolt pattern wheel is bolting on to them
What are they adapting ?
Re: Rear Wheel Spacers [Re: JFChallenger440] #3141809
05/01/23 05:20 PM
05/01/23 05:20 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
In general, adapters usually change bolt pattern diameter but don't have to. An adapter always has 2 sets of studs - one to bolt adapter to axle and one for the wheel. Adapters are generally considered much weaker than a properly made spacer with correct studs. I would never run an adapter on anything other than a very mild stock vehicle.
Re: Rear Wheel Spacers [Re: markz528] #3141811
05/01/23 05:29 PM
05/01/23 05:29 PM
London, England
London, England
Ok thanks
What could happen then ?
Re: Rear Wheel Spacers [Re: JFChallenger440] #3141901
05/02/23 02:51 AM
05/02/23 02:51 AM
They fail going around a corner and you crash shruggy tsk luck
Re: Rear Wheel Spacers [Re: Cab_Burge] #3141903
05/02/23 02:59 AM
05/02/23 02:59 AM
London, England
London, England
Fail why ? As in fall off ? Surely if they’re tightened up ok they should be fine ?
I’d imagine the companies who make them have done safety tests etc otherwise they wouldn’t be allowed to sell such a product ?
Re: Rear Wheel Spacers [Re: JFChallenger440] #3141910
05/02/23 07:10 AM
05/02/23 07:10 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
thats a bad assumption. people sell alot of things until there is a problem. i think you can still buy cast aluminum wheel spacers. these can crack and fall apart, the billet are better but i'm sure no one has done the proper calculations and or testing. afterall we are talking about this because people want to take the easy way out and not spend the money on forged wheels with proper backspacing. that being said, there are tons of companies making aftermarket wheels so for 98% of the people who just want to look cool they will most likely be fine. however if you're racing i'd spend the money on the proper equipment
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
