Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132310
03/25/23 08:17 PM
03/25/23 08:17 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
My Hemi build made max power at 28 degrees total advance. I've been a B/RB Wedge guy for the last 40+ years and used to seeing 34 or 35 degrees. 28* seemed like not enough but the Dyno guy said 28 for my build was consistent with other similar Hemi builds. That hemispherical combustion chamber is pretty efficient. Also, it's 604" and like 11-1 on the CR (all aluminum) but runs on high-octane pump gas. I think the cam bleeds off some pressure and the aluminum soaks out lots of heat. It was one of last builds that came out of Muscle Motors.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: 438ci Hemi Dyno. Devil is in the details. [Re: rumblefish72] #3132321
03/25/23 09:14 PM
03/25/23 09:14 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
^ Appreciate the info, good to know! You're the only other person I recall stating their hemi made the most power at sub 30deg timing.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132344
03/25/23 10:57 PM
03/25/23 10:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Good heads and small cubes often will need less total timing.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: Dragula] #3132358
03/26/23 01:11 AM
03/26/23 01:11 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
That's some good Rwhp, sounds good too.
When I was dynoing my mazda to 10,500 rpm, some people told me the driveshaft was going to explode, but it never did, I was more worried about the clutch coming apart.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: Uberpube] #3132367
03/26/23 06:27 AM
03/26/23 06:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm impressed. big power for the cubes; especially at the tire. i like the way the dyno operator started at a low enough rpm to give you a good picture of the power curve. also impressed at how the car hung onto power and gained in the upper rpm range. what size are those carbs?
Re: 438ci Hemi Dyno. Devil is in the details. [Re: lewtot184] #3132408
03/26/23 10:33 AM
03/26/23 10:33 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I really appreciate your attention to detail. It's top notch in every respect, your Charger is outstanding!
I love the turn signals used as a shift light.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: Blusmbl] #3132470
03/26/23 03:47 PM
03/26/23 03:47 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys! The throttle bodies are Holley 112-588, 1000cfm.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132481
03/26/23 04:28 PM
03/26/23 04:28 PM
USA
hudsonhornet7x Offline
USA
What a nice build. Do you have pictures posted of the build/restoration?
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132645
03/27/23 10:19 AM
03/27/23 10:19 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very nice Hot Rod! Well done! Thanks for sharing.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: HardcoreB] #3132692
03/27/23 11:33 AM
03/27/23 11:33 AM
moparx Offline
moparx  Offline
the turn signal shift lights are a great idea.
do they have a second bulb in them to still be used as turn signals ?
beer
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132696
03/27/23 11:40 AM
03/27/23 11:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What company makes those W23ish wheels ?
Re: 438ci Hemi Dyno. Devil is in the details. [Re: JohnRR] #3132706
03/27/23 12:04 PM
03/27/23 12:04 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys.
Just one bulb on the turn signal lights. I wired in a relay so they work with both the turn signals and as a shift light. (voltage can either pass through to individual turn signal light as normal or be illiminated together by the ecu)
The wheels were made by Curtis Speed in California (not production, I had them made). Tires are Avon CR6ZZ road race tires. 80 treadwear rating. Diamondback put redlines on them.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3132950
03/28/23 10:34 AM
03/28/23 10:34 AM
an8sec70cuda Offline
Very nice! Surprised at the timing...mine likes 34°, but it's 575 inches.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 438ci Hemi Dyno. Devil is in the details. [Re: an8sec70cuda] #3133023
03/28/23 02:35 PM
03/28/23 02:35 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine made most power and torque at 33 degrees at 528".
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: 6PKRTSE] #3133121
03/28/23 09:08 PM
03/28/23 09:08 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
My 572 Hemi made max power on the dyno at 29* but runs quickest on the track at 32* and stays cooler on the street.
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3133219
03/29/23 09:59 AM
03/29/23 09:59 AM
I love the Fratzog detail on the wheels. Since that is part of the new EV branding for Stellantis, instead of people asking if that thing got a Hemi, they'll be asking if it is electric!!
Re: 438ci Hemi Dyno. Devil is in the details. [Re: rumblefish72] #3133299
03/29/23 01:36 PM
03/29/23 01:36 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thank you. I originally thought I would fill in the fratzog on the cap with black paint but not sure. (same with my indecision about a tail stripe)
Re: 438ci Hemi Dyno. Devil is in the details. [Re: INTMD8] #3133569
03/30/23 09:40 AM
03/30/23 09:40 AM
I don't know, I think that's really subtle without black paint. The way it looks now, if I walked past it at a car show and saw that detail, I would just chuckle and smile. I'd probably want to meet you and shake your hand wink. The rest of the car is like a big hammer, the subtlety of the Fratzog detail helps with the balance. Are those Coyote pencil coils? If so, I bought a set of those from MSD and hope to install sooner or later. Besides shortening the boot that goes over the spark plug, did you have to make any other mods to the coil? The MSD coils have that stainless steel coil spring inside the boot for connectivity between the coil and the spark plug tip. That looks a little sketchy to me but it works for the OEM. And, you have to add a stud or some sort of attachment provision to the valve cover. And once you do that, you're locked into a specific direction on the coil wiring. I thought it might be neat to run all the coil trigger wires to the rear of the engine to make the casual observer wonder if it is a Gen I 392. What ECU are you using? Thanks - nice car!
Re: 438ci Hemi Dyno. Devil is in the details. [Re: rumblefish72] #3133577
03/30/23 10:18 AM
03/30/23 10:18 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thank you once again smile
Yes they are Coyote coils.
I trimmed .125 off the end of the rubber boot with a razor blade. (inside is a spring as well that had enough range)
Shortened the ridge on the plug tubes by .200 on a belt grinder.
Used a bolt and .400 thick threaded spacers for mounting.
I'm using a Holley HP ecu.
