Front End Vibration/Steering Wheel...help..
#313118
05/09/09 08:42 PM
05/09/09 08:42 PM
Posts: 4,244 West Virginia
NewbombTurkk
West Virginia
Just traded for an ebody and when the trade was done we swapped wheels and left...
Well the car has a pulsating vibration at 35-40 mph...steering wheel shakes, mirrors shake....
I have tried different rims/tires on the front, rebalancing, etc....still no help....
Any ideas.....could it need a front end alignment?
It doesn't do it in Neutral and the motor revving...so I ruled out the balancer, converter, etc.....
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: Front End Vibration/Steering Wheel...help..
[Re: NewbombTurkk]
#313119
05/09/09 08:54 PM
05/09/09 08:54 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Neutral
sounds like a possible bad U/joint. Take down the drive shaft and check them. Don't just try to shake the drive shaft. Very misleading doing that.
[Re: NewbombTurkk]
#313122
05/10/09 12:10 AM
05/10/09 12:10 AM
RapidRobert
jack the rear end up off the ground & have some one get in,put it in gear & run it up to 40 mph, if no problem go back to the front end
[Re: RapidRobert]
#313123
05/10/09 09:37 AM
05/10/09 09:37 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Alignment wont cause a shake.Cant believe how mnay people wanted cars aligned at work because they had a vibration.Rocky
Chrysler Firepower
