Billet vs forged Dana yoke (twisted)
#3130512
03/19/23 11:41 AM
03/19/23 11:41 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
It looks like I twisted my yoke 0.200 thousands
What’s are the benefits of billet vs forged yokes
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Billet vs forged Dana 70 yoke (twisted)
[Re: Kam*Kuda]
#3130534
03/19/23 12:40 PM
03/19/23 12:40 PM
Posts: 4,632 Motor City
6PKRTSE
Motor City
Never seen that. You would think the u joint would have broken first. You won't twist or break a billet yoke.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: justinp61]
#3130610
03/19/23 04:58 PM
03/19/23 04:58 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I've never seen it either. It looks loke it's still square whit the other half, just offset. What does the u joint and the driveshaft look like? You'd think the driveshaft would have to match the yoke. It's odd that nothing broke. Here is the U joint /driveshaft
Re: Billet vs forged Dana yoke (twisted)
[Re: Kam*Kuda]
#3130646
03/19/23 07:48 PM
03/19/23 07:48 PM
Posts: 4,219 New York
polyspheric
New York
Billet is cheaper to make. All you need is the blank, the program, and rent CNC time until it's done. No minimum quantity, no inventory. Once you rent the program, all cost the same. Forging requires a clever pattern maker and a foundry to make the 3-dimensional model into a set of very expensive set of dies, and someone with a huge hydraulic press (Mickey Thompson sent their blanks to ALCOA). If you're not going to makes lots of them: $$$$.
Billet has no directional grain structure, it's almost a casting.
Boffin Emeritus
[Re: '72CudaRacer]
#3130679
03/19/23 09:41 PM
03/19/23 09:41 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Never seen that before. I've seen broken yokes, u-joints and pinions (and twisted driveshafts & axles). Might better check the pinion splines for being twisted too?
Brian Good idea. I will have it checked. also I have a Detroit locket in it. I am having the brackets to fit some longer shocks in so the rear end is out of it to cut and weld new brackets in place and strengthen the rear end
[Re: dvw]
#3130684
03/19/23 09:58 PM
03/19/23 09:58 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
850+ passes with a Dr Diff forged yoke. I've never seen a yoke bend. Where did you get it? Doug I wish I could remember (probably bought through bears in canada http://bearsperformance.com/canada/...h_in_description=1&keyword=yoke+dana) I am fairly new to drag racing and set up It only have 30-50 passes and some street miles. DETAILS Its a foot brake car Launch at 2000 rpm (I have have launched of idle as well) 3850 lbs 3.54 gears Ladder bars 1 degree down best of 6.15 in the 1/8 at this track Here is a video from this year. Maybe I am doing something wrong??? https://www.youtube.com/watch?v=N5Wx7eWLGNYIt is not a great track and I have had to get on and off the throttle at the beginning of some runs because I was spinning See the 3 min mark (end of video)
[Re: Kam*Kuda]
#3130702
03/19/23 11:09 PM
03/19/23 11:09 PM
Posts: 43,734 Bend,OR USA
Cab_Burge
it sounds like the throttle opening is real slow on the last couple of runs, where you doing that intentionally or is it my hearing or perception?
[Re: Cab_Burge]
#3130963
03/20/23 09:46 PM
03/20/23 09:46 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
it sounds like the throttle opening is real slow on the last couple of runs, where you doing that intentionally or is it my hearing or perception? I am not sure I usually launched at 2000 rpm Thanks Ro
[Re: Pacnorthcuda]
#3130966
03/20/23 09:49 PM
03/20/23 09:49 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Kam, I see you say you are 1 degree down, but is there a chance you are going too far positive on launch and creating a bind at the yoke? Pac That is a good question , I am putting in longer shocks now and that may multiply the problem,
[Re: Kam*Kuda]
#3131040
03/21/23 09:53 AM
03/21/23 09:53 AM
Posts: 13,493 Marion, South Carolina [><]
an8sec70cuda
That's odd. Maybe you got real lucky and caught it right before it broke? My dana has a Moser 1350 yoke on it...honestly can't remember if it's forged or billet. It's been on the car since 2003 w/ no issues.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Kam*Kuda]
#3131069
03/21/23 11:27 AM
03/21/23 11:27 AM
Posts: 2,982 A shed in England
Tig
A shed in England
I replaced the upgraded forged with a billet one purely because I needed to fit a collar to monitor D/S speed. I used the one listed below. The caveat ? I had to get my D/S shortened 1/2" or so. https://www.strangeengineering.net/product/dana-60-yoke-1350-strange-chrome-moly.html/
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3132251
03/25/23 05:41 PM
03/25/23 05:41 PM
Posts: 5,127 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Kam Kuda are you going to do your Dana or do you have someone else in mind.
Not a big fan of Shannonville, after they sent two cars down one my buddy that just made a pass on his bike and it runs in the 7s easily and is raked and has a giant wheelie bar. The track must of forgot that once you are by the return road that this kind of bike has to foot backwards to get back to the return road. The Chevelle went by him very fast and saw him in time. I wont run against bikes with a car anyway.
1971 HEMI E BODY REGISTRY
