W9 Head Chamber CC's? #3130002
03/16/23 09:50 PM
03/16/23 09:50 PM
WNY
Moparrob68 Offline OP
WNY
Dug out the engine build sheet from the W9 build 2 years ago and I have conflicting notes on the chamber CC's with the Titanium valves.
What is the average W9 chamber volume with Titanium valves?
Pic from the build
Re: W9 Head Chamber CC's? [Re: Moparrob68] #3130015
03/16/23 10:42 PM
03/16/23 10:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
Pic from the build
When in doubt, check it out, now up wrench twocents
Why not make sure exactly how all eight chambers hold now before you wish you did later work
Re: W9 Head Chamber CC's? [Re: Cab_Burge] #3130025
03/16/23 11:19 PM
03/16/23 11:19 PM
WNY
WNY
I already wish I did.
That picture was from 2 years ago. I just put it in for reference. The engine has been together for a year.
Re: W9 Head Chamber CC's? [Re: Moparrob68] #3130044
03/17/23 07:26 AM
03/17/23 07:26 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
My street W9s are 55cc with 2.18/1.60 stainless valves. I havent checked my other pair with 2.20/1.60 Ti valves yet, but I would expect 53cc.
Uncut decks with Brett Miller chamber/porting
Re: W9 Head Chamber CC's? [Re: Moparrob68] #3130081
03/17/23 10:22 AM
03/17/23 10:22 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Pic from the build
Respectfully, what's the difference? What were your conflicting numbers anyway? Are they so different they'll change the fuel you'll use? Do a compression test/cylinder press. These in the pic are nearly max milled based on the valves in relation to the deck.
Re: W9 Head Chamber CC's? [Re: HardcoreB] #3130242
03/17/23 10:32 PM
03/17/23 10:32 PM
WNY
WNY
The engine has 200lbs cranking compression with a 275* @.050 cam. We are heading to the dyno next week with VP C12 fuel.
Re: W9 Head Chamber CC's? [Re: Moparrob68] #3130256
03/18/23 01:04 AM
03/18/23 01:04 AM
I would take some C10 and several different heat ranges of sark plugs and test, test, tests and watch the results wrench scope up twocents
Good luck either way bow luck
