Re: Drill press
[Re: DusterKid]
#3129340
03/14/23 01:45 PM
03/14/23 01:45 PM
Posts: 26,036 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Have you tried contacting Northern Tool? I
Re: Drill press
[Re: John_Kunkel]
#3129350
03/14/23 02:12 PM
03/14/23 02:12 PM
Posts: 16,846 Between Houston & Galveston TX
SattyNoCar
While sitting here having lunch, I 'chatted' with Doug from there regarding this. In a nutshell, he said its too old and no longer supported. He showed me a newer model but the parts were totally different. I think the part is mislabeled in the manual? What 68 is pointing to sure looks like a spindle, which 69 pointing to a pulley claims to be? I tried to save the chat we had, as he suggested one place that might be able to help, but it hasn't shown up in my email (yet).
John
Re: Drill press
[Re: DusterKid]
#3129352
03/14/23 02:14 PM
03/14/23 02:14 PM
Posts: 4,767 Moved to N.E. Tennessee
GomangoCuda
Is that shaft missing or worn? Have any machinist friends? Looks simple enough for any one that has a lathe and knows how to use it.
Re: Drill press
[Re: GomangoCuda]
#3129362
03/14/23 02:58 PM
03/14/23 02:58 PM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
Is that shaft missing or worn? Have any machinist friends? Looks simple enough for any one that has a lathe and knows how to use it. It's broke in half where it changes in diameter from big to small. There's 2 bearings that mount on the bottom side with a spacer in between the bearings. The top part goes thru the top pulley. The center of the "insert pulley" is hollow for a square stock of the drill press shaft spindle.
Re: Drill press
[Re: mopars4ever]
#3129390
03/14/23 04:30 PM
03/14/23 04:30 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Agreed that a guy with a lathe could knock that out fairly easily.
The question becomes, will he do it for less than the machine is worth.
Sad but true, much of this import equipment and tools are considered consumables. Use it 'till it breaks and get another.
I'm like you, I hate to throw otherwise good tools away. I'll usually spend the money to fix it, if it's a good tool otherwise.
Re: Drill press
[Re: CMcAllister]
#3129418
03/14/23 05:39 PM
03/14/23 05:39 PM
Posts: 5,501 Michigan
oldjonny
Don't argue with me.
I'm like you, I hate to throw otherwise good tools away. I'll usually spend the money to fix it, if it's a good tool otherwise. I suffer from the same problem. I just spent $60 to fix my old (like 43 years old) Craftsman 1HP air compressor. Probably should have just chucked it, but it did serve me well for a bunch of years. DeVilbiss actually made them back then, so maybe it was the right thing to do.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Drill press
[Re: oldjonny]
#3129423
03/14/23 05:54 PM
03/14/23 05:54 PM
Posts: 10,777 North Dakota
6PakBee
North Dakota
I'd much rather repair something old that is quality. If you pitch and buy new, you have just gotten on the throw-away merry-go-round.
Re: Drill press
[Re: SattyNoCar]
#3129487
03/14/23 09:30 PM
03/14/23 09:30 PM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
While sitting here having lunch, I 'chatted' with Doug from there regarding this. In a nutshell, he said its too old and no longer supported. He showed me a newer model but the parts were totally different. I think the part is mislabeled in the manual? What 68 is pointing to sure looks like a spindle, which 69 pointing to a pulley claims to be? I tried to save the chat we had, as he suggested one place that might be able to help, but it hasn't shown up in my email (yet). Any chance he could research who the supplier was ? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: Drill press
[Re: DusterKid]
#3129488
03/14/23 09:32 PM
03/14/23 09:32 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
Is the hollow in the middle round or square to fit the drill press shaft spindle or is it round and the drill press shaft spindle connects to the pulley on top? If the hollow is square then it may take a shop with a broach or something to make the square hole. (Not a machinist so I don't know what the options there are). If that is the case it may be cheaper to have the two pieces welded together and machined down to fix it. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) If it seems like a decent tool then it would be worth fixing but I have seen some really bad crap being sold in the last couple decades. Sadly it's kind of a crap shoot.
