Vacuum advance distribution question #3128827
03/12/23 06:57 PM
03/12/23 06:57 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
If my vacuum advance is bad can I unplug it and set the timing at 32-34 and drive it? Just a street car that gets driven on good weather days.
Re: Vacuum advance distribution question [Re: bobs69] #3128828
03/12/23 07:02 PM
03/12/23 07:02 PM
Findlay
Ramman Offline
Ramman  Offline
Findlay
Sure can. Plug the vacuum line. All you'll lose it a little throttle crispness and fuel mileage.
Re: Vacuum advance distribution question [Re: Ramman] #3128831
03/12/23 07:11 PM
03/12/23 07:11 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Thank you. Most of my time was in a drag car. Wasn’t sure about a street driver
Re: Vacuum advance distribution question [Re: bobs69] #3128836
03/12/23 07:36 PM
03/12/23 07:36 PM
moparx Offline
moparx  Offline
yes, no problem.
however, if it's possible, i would try to get a good [new perhaps ?] can and tune both circuits to get the best of both worlds.
especially if you do any street driving at all.
just my opinion. your mileage will vary.
beer
Re: Vacuum advance distribution question [Re: bobs69] #3128894
03/12/23 11:32 PM
03/12/23 11:32 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Most adverse condition will be at a steady, light throttle, highway condition
Mileage will suffer I believe.
Re: Vacuum advance distribution question [Re: bobs69] #3128909
03/13/23 12:54 AM
03/13/23 12:54 AM
Most of my hot street cars (500+ HP) have MSD or Mopar distributors with no vacuum advance on them or I disconnect them for the best W.O.T. performance up I'm not worried about the gas mileage whistling devil
Re: Vacuum advance distribution question [Re: bobs69] #3128955
03/13/23 09:31 AM
03/13/23 09:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Beside some gains in economy, proper vacuum advance allows the engine to run cleaner. For the same light load cruising, it takes more fuel to do without that advance. That leads to additional deposits in the combustion chamber and on the cylinder walls.
Master, again and still
Re: Vacuum advance distribution question [Re: DaveRS23] #3128990
03/13/23 11:20 AM
03/13/23 11:20 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Street engines definitely run cleaner with vac advance.
I've proven that to myself, with 540 - 600 HP street Mopars.
No matter the amount of max power, most street driving is at a fraction of WOT.
The chambers on our older engines aren't as efficient as the newer high-swirl designs that require less timing.
Re: Vacuum advance distribution question [Re: bobs69] #3129005
03/13/23 11:48 AM
03/13/23 11:48 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
There is a lot more to the subject than is being discussed. The first answer is correct, BUT as mentioned there may be a loss of gas mileage and low end throttle response.
You didn't mention the car, combination or how you "DRIVE" it on good weather days.
Getting the optimum performance requires a combination of initial timing, mechanical advance (how much, where it comes it and how fast), vacuum advance and jetting. The first three variables can have a substantial impact on performance and MPG. I have seen many cars with TOO MUCH vacuum advance which can lead to misfiring and a loss of MPG.
You could try bumping the initial a couple of degrees to give you a higher total as long as you're not introducing detonation or hard starting when hot.
now you have way more information than you asked for grin beer
Re: Vacuum advance distribution question [Re: Cab_Burge] #3129396
03/14/23 04:54 PM
03/14/23 04:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are we in the race forum?
I didn't think so. Try some useful and relevant information, please.
Re: Vacuum advance distribution question [Re: Sniper] #3129481
03/14/23 09:20 PM
03/14/23 09:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Cab has contributed far more than you could hope to. Your entitled to your opinion but your comment has nothing to do with being helpful to the OP, but rather yourself. Why do you have to come across so inflammatory? SOme of your post IMO are helpful while others are quite the opposite. please think before you post beer
Re: Vacuum advance distribution question [Re: TJP] #3129496
03/14/23 09:49 PM
03/14/23 09:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Cab's comment has nothing to do with being helpful to the OP.
Re: Vacuum advance distribution question [Re: Sniper] #3129503
03/14/23 10:11 PM
03/14/23 10:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Seems to me Cab was saying he runs his hot street stuff without vacuum advance, and has found no issues with his engines.
That would be germane to the topic.
I think vacuum advance is a proven asset on the street - if properly tuned - but it's likely Cab doesn't drive the cars he's referencing on the street all that much.
He can expand on that if he wants to.
Re: Vacuum advance distribution question [Re: topside] #3129510
03/14/23 10:50 PM
03/14/23 10:50 PM
My daily street driver is a 2006 Ram 3500 4X4 single wheel C.T.D. or my wife 1996 Camry if she is going with me so she can get in and out better than with the truck.
I drove my old pump gas street Duster in the spring, summer and fall with no vacuum advance on it ever when I wanted to upset the local street enthusiast, especially the Mustang and Camera guys devil hammer grin
I'm not sure how that combination would run against the new Red Eye and other new hopped up supercharged factory cars work shruggy
That car ran a best of 9.993 at 134.7 MPH in the work 1/4 mile corked up with the air cleaner on with me in the car weighing 3450 Lbs. on Oregon 91 octane pump swill shruggy
Traction is king at that level, that car would hook up in a mud puddle in a rain storm whistling grin
Re: Vacuum advance distribution question [Re: bobs69] #3129535
03/15/23 02:12 AM
03/15/23 02:12 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
So basically yes you can. Can be unplugged for racing purposes, or performance street use. But for best "overall" street use, install it.
Re: Vacuum advance distribution question [Re: bobs69] #3130727
03/20/23 07:36 AM
03/20/23 07:36 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Mine quit working several years ago. I couldn't find a replacement, so I bought another distributor for the vacuum advance canister, and that one was bad too. I gave up and do without. A 383 RR with a 3.91 gets horrible gas mileage rumbling around the city no matter what. I'm always speeding up, slowing down or idling at lights anyway, so whatever.
68 Roadrunner. 383 4-spd. Beat up.
