Re: Whole House Generator
[Re: JDMopar]
#3128733
03/12/23 12:10 PM
03/12/23 12:10 PM
Posts: 1,715 central il.
second 70
central il.
I'm retiring in 20 days from the power company after 44 1/2 years. I'm very thankful to have been taught very early on as a young lineman to watch out for the Ding Dongs with rigged up generators. After the big ice storm right before Christmas in Tulsa, OK in 2007, one of said Ding Dongs dumbassed his disconnect procedure on his huge portable generator when we got the power to his street back on. He forgot to disconnect his generator before he flipped his main breaker back on. He was back feeding the panel with another breaker below the main. It went KABOOMYOW right in hs face, blew up his panel, backfed onto the energized power lines and burnt all of the backlot lines that fed his house and 9 others. After a week of being without power, they had to be out another night because we had to quit in time to drive back to NW Arkansas where our hotel rooms were. One of the lineman came over the radio and said "At least we will be able to get a truck to the pole tomorrow. His neighbors are gonna burn his house down tonight and we can back the bucket truck across the slab and reach the pole!" ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Thank you to the OP, who intends to do it right! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) [/quote] I'm too a retired lineman and your story reminds me of one we had happen in an ice storm. Overhead service was broke and laying on ground. Transformer and circuit was dead. No generator. We were attaching service back on house with the pole end still on the ground and were getting shocked on the neutral. What the heck??? It was in a crappy old neighborhood with trash everywhere. Low and behold the genius ran an extension cord under the trash from neighbors basement window to his basement window and hooked up his furnace fan. He hooked it up backwards and had the neutral hot casing us to get shocked. Luckily no one got hurt! And really lucky it was backward so we found it or otherwise someone could have got killed when it backfeed the transformer when we hooked it up.
[Re: Powerflow]
#3128738
03/12/23 12:38 PM
03/12/23 12:38 PM
Posts: 26,017 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This is the Generac manual transfer switch I use, totally isolates the generator from the utility.
[Re: Fat_Mike]
#3128757
03/12/23 01:26 PM
03/12/23 01:26 PM
Posts: 6,341 nowhere
Sniper
nowhere
Not sure what manual switch you are thinking of, but a properly installed and used one will only connect the house to the generator or to utility but not both at once. The only thing manual about it is that you have to throw the switch rather than pay a lot more for one that will throw it for you. There are several ways to connect a manual switch. If not used properly, it creates a potentially deadly situation for others. It's not worth taking the chance that someone may not perform that one important step! Automatic switches are cheap, and in my county (maybe even state) they are mandatory. I don't think you understand how a properly installed manual switch functions, nor do the politicians who passed your law. In a properly installed manual transfer switch there is no way to back feed anything. It's wiring is no different than automatic transfer switch. I don't really think you even know what the difference is between a manual and automatic transfer switch is, nor do your politicians.
[Re: TJP]
#3128808
03/12/23 04:21 PM
03/12/23 04:21 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
I’m running a generac and love it
24kw powers my house and the shop
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: 360view]
#3129036
03/13/23 01:08 PM
03/13/23 01:08 PM
John_Kunkel
Rio Linda, CA
add on secondary breaker box that allows room circuit by room circuit generator power up That's how I'm setup, a 60-amp breaker in my main utility breaker box powers a sub-panel with 12 breakers that power the circuits I want to keep alive during a power outage. My generator has a 50-amp outlet that goes into the manual transfer switch I showed above that powers only the circuits in the sub-panel. Another advantage to the sub-panel is it frees up space in the main breaker box. (old Zinsco 100-amp)
[Re: 340Cuda]
#3129046
03/13/23 01:36 PM
03/13/23 01:36 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
I don't think this has been mentioned but an inexpensive alternative to a transfer switch is an interlocking breaker.
The breaker for the generator goes at the top of the panel and has a mechanism that will not allow it to close until the main breaker is open.
Yup. In my opinion its a safe inexpensive method to hook up a generator. The auto swap generac stuff gets way too complicated with way too much electronics for my liking.
[Re: markz528]
#3129121
03/13/23 05:46 PM
03/13/23 05:46 PM
Posts: 5,497 Michigan
oldjonny
Don't argue with me.
Its all whether you want to be the one that has to make the transfer on whatever date and time it needs to happen. The value in an automatic one is that you don't have to be there and/or bother waking up in the middle of the night.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: Cab_Burge]
#3131497
03/22/23 05:15 PM
03/22/23 05:15 PM
Posts: 12 Wisconsin
wjb123
Wisconsin
There are sizing charts online. It really depends on the appliances you have and what you want to run. Electric heat, hot water heater, dryer, stove, Hot tub all add up fast. The automatic transfer switch is pretty slick. We lose power and it takes about 10 seconds before the Generac kicks on and takes over. When power returns, I never know. The ATS just flips back to Electric co. no interruption. btw- with Tesla powerwall you don't even lose those 10 seconds of power. But it will cost a crapload. Once this year we had a huge outage in my area that included cell towers and cable service. We had power but no TV/nternet or cell service. That was unusual. Normally those are unaffected.
