Distributor hold down finish. #3128246
03/10/23 07:53 PM
03/10/23 07:53 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
What kind of finish should be on the distributor hold down on a 1970 440. Thanks.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: Distributor hold down finish. [Re: stickman] #3128247
03/10/23 08:04 PM
03/10/23 08:04 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Kinda hard to see, but here's a 17,000-mile original (except valve covers, since returned to stock) '69 RR clamp.
A '70 Satellite I had was the same, like a clear zinc over clean bare steel, so a dull medium silver...
Re: Distributor hold down finish. [Re: topside] #3128312
03/11/23 03:28 AM
03/11/23 03:28 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Just so people don't get confused, my '69 340 distributor hold down is copper plated steel with a blackened finish. Birchwood-Casey, maker of gun bluing, sells a brass blackener that also blackens copper. It's easy to plate copper with some battery current and a copper penny or Romex.
One could guess the copper plate was to make sure there's a good ground between the intake manifold and the distributor. And in addition, for good measure, the intake manifold to head bolts were zinc plated with yellow chromate, rather than phosphated, likely to make a better path to the negative battery cable attached to one of the heads. And maybe the battery negative cable was bolted to the head rather than some place else specifically to make as direct an electrical connection to the distributor as possible.
In the photo, most of the original blackening is gone due to too aggressive cleaning and scrubbing. Oops.
Re: Distributor hold down finish. [Re: stickman] #3128759
03/12/23 01:39 PM
03/12/23 01:39 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
clear zinc or silver cad
Re: Distributor hold down finish. [Re: TONY_DAGOSTINO] #3129762
03/15/23 10:07 PM
03/15/23 10:07 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
I painted mine a matte nickel color
'69 Plymouth GTX
See you on the street...
Re: Distributor hold down finish. [Re: Black_Sheep] #3129811
03/16/23 08:07 AM
03/16/23 08:07 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have come across copper ones also always small block.
Re: Distributor hold down finish. [Re: B1MAXX] #3129948
03/16/23 05:21 PM
03/16/23 05:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Yeah, My 73 340 had a copper one under the gunk.
