Re: Rear defogger blower location ?
[Re: buzz440]
#3128513
03/11/23 05:20 PM
03/11/23 05:20 PM
Posts: 19,355 north of coder
moparx
from my really AWFUL memory, if you look under the package tray, there will be an opening for the speaker that will fit it [kind of] flush with the tray. the other opening will fit the defrost unit with it's gasket attached. i don't know if this helps or not. i tried looking in my 70 FSM under the Heating and AC chapter, the body and the interior groups, but i found nothing except the front under dash information. i probably missed where it is, sorry.
[Re: srt]
#3128812
03/12/23 04:41 PM
03/12/23 04:41 PM
moparx
after i made my comment, i looked closer at the FSM, and although i couldn't find mention about the rear defrost, i could clearly see the mounting surface for it on the package tray picture. as said, it was clearly on the left side, with [of course] the vent outlet in the center. even though this was a 1970, i took a peak at my charger, which is a 69, and it was [basically] the same. same [basic] cut out and mounting surface, and same [basic] vent shape and location. this prompted me to do a little [snooping ?] investigating, and the A-bodies of my buddy's 71 duster and 73 dodge sport are somewhat the same in the package tray area. it looks like a defrost assembly could be mounted in the [somewhat] same location, and the vent used in the middle. now with that said, is it possible defrost units were mounted to the left on all body styles that had this as an option ? if so, how does this affect rear AC units installed on new yorkers and imperials ? remember, i'm just throwing this out there, and although i have owned imperials with rear AC, [plus scrapped some in my junkyard ownership days] it's been so long ago, and i don't have any FSM's to refer to.
[Re: moparx]
#3128959
03/13/23 09:50 AM
03/13/23 09:50 AM
Posts: 892 MA
steve70
MA
after i made my comment, i looked closer at the FSM, and although i couldn't find mention about the rear defrost, i could clearly see the mounting surface for it on the package tray picture. as said, it was clearly on the left side, with [of course] the vent outlet in the center. even though this was a 1970, i took a peak at my charger, which is a 69, and it was [basically] the same. same [basic] cut out and mounting surface, and same [basic] vent shape and location. this prompted me to do a little [snooping ?] investigating, and the A-bodies of my buddy's 71 duster and 73 dodge sport are somewhat the same in the package tray area. it looks like a defrost assembly could be mounted in the [somewhat] same location, and the vent used in the middle. now with that said, is it possible defrost units were mounted to the left on all body styles that had this as an option ? if so, how does this affect rear AC units installed on new yorkers and imperials ? remember, i'm just throwing this out there, and although i have owned imperials with rear AC, [plus scrapped some in my junkyard ownership days] it's been so long ago, and i don't have any FSM's to refer to. My 70 Challenger TA has the blower motor on the right and the speaker on the left.
1970 Challenger T/A 4 speed
[Re: moparx]
#3129333
03/14/23 01:33 PM
03/14/23 01:33 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
Mine has an offset bracket in my 70 Charger. I have a 5 speaker system with an AM 8 track radio, with the 3 speaker dash and also two under the rear deck. The blower has a bracket that mounts off of the speaker.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3129532
03/15/23 01:41 AM
03/15/23 01:41 AM
Posts: 985 montreal,quebec,canada
buzz440
Thanks.... to all that replied, so I climbed my lazy ass into the trunk and had a good look at this %*&@# ! defogger set-up and to my surprise, it mounts on the right (passenger) side. Also, it can only mount in that location cause the defogger mounting plate is an oval 6x9 shape and the matching 6x9 oval opening is on the passenger side, The hole on the driver side is more of a square design and smaller looks like maybe a 5x7 speaker would fit there. To sum up all has been installed, tested and working.....PLEASE note this is on (MY) car a 69 Superbee, might be in a different location on other models/ years. Again thanks for all the info and replies.
Later, BUZZ
