Page 2 of 3 1 2 3
Re: Rottella T #312694
05/10/09 01:20 AM
05/10/09 01:20 AM
minnesota, USA
greenfire Offline
greenfire  Offline
minnesota, USA
i have been running shell rotella t 5w-40 synth in my 96 1400 suzuki intruder motor cycle for about 4 years now, and the bike loves the stuff. no problems at all and i can go a little farther between oil changes as well. all tho it says its a synthetic blend, its still dino cracked but works very well
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: Rottella T [Re: greenfire] #312695
05/10/09 01:53 AM
05/10/09 01:53 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The syn Rotella in the blue jug is spendy but a great oil for the money. I bought a ton back when it was 15 bucks a gallon and used it in lots of stuff.
I want my fair share
Re: Rottella T [Re: SomeCarGuy] #312696
05/10/09 07:46 AM
05/10/09 07:46 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
The reason for using Rotella as I've seen in other posts was for the ZDDP content that is no longer in conventional oils because nearly OEM has gone to roller tappets. As far as sludge, that comes from cheap oils, wrong viscosity, short trips, or lack of oil changes. There may be other reasons that I don't know.
Re: Rottella T #312697
05/10/09 08:05 AM
05/10/09 08:05 AM
United States
V
v269 Offline
v269  Offline
V
United States
brad penn and amsoil have an adequate amount of zinc and phosphorus, approximately 0.15% phosphorus, and 0.18% zinc.
Re: Rottella T [Re: dUmB!] #312698
05/10/09 10:14 AM
05/10/09 10:14 AM
Az
Crizila Offline
Crizila  Offline
Az
Cool ...THX
Is that CI an "industry" rating ?
CI is an industry rating. Has nothing to do with zinc content. Believe the older Rotella T was 1400 ppm zinc while the newer stuff is 1200ppm. Still the best out there for zinc content. Understand you can get it at Farm&Fleet, some Walmarts, and most truck stops.
Fastest 300
Re: Rottella T [Re: Crizila] #312699
05/10/09 10:28 AM
05/10/09 10:28 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Cool ...THX
I posted this quite some time ago,I'll do it again.The only way you will know the zinc content is have an analysis done.
Re: Rottella T [Re: 62maxwgn] #312700
05/10/09 01:35 PM
05/10/09 01:35 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
I use the Rotella in all of my older MOPARS and in my 1981 diesel farm tractor.
A fellow MOPARTS member was recently in his local Tractor Supply Co. store and he told me that they still carry motor oil with zinc and the real, old style green antifreeze. My guess is that some of the older farm tractors and other equipment must have the oil with zinc as well as the old style antifreeze. I know that this is where I am going to purchase my next batch of antifreeze if I can't find the old style locally.
Bill
Re: Rottella T [Re: dUmB!] #312701
05/10/09 09:20 PM
05/10/09 09:20 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I would use a roller but since the roller lifters I have heard of here and elsewhere are not reliable .....I will pass on that idea.
Interesting. What's happening now with the newer roller lifters? I've seen something about this in another thread but couldn't remember exactly what was being discussed at the time. Can you tell more?
Next thing. Maybe a little off topic, but what exactly makes a "flat tappet" cam vulnerable now opposed to several years ago. I know the quality of oil has changed and the zinc/phosphourous is way less nowadays (for a flat tappet cam), but what makes the roller a stronger cam that it doesn't need the same amount of zinc? Is the flat tappet cam just weaker? Made of a lesser strength of metal?
Re: Rottella T [Re: 68Bullit] #312702
05/10/09 09:54 PM
05/10/09 09:54 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I emailed Shell a while ago about Rottela. I got an email back and also phoned and talked to one of the Reps. They said Rottela has now 1200 ppm and recommended the Racing Oil that had 1500+ PPM. They recommended Pennzoil Racing Oil mainly because Shells owns them. I have heard Val.Racing Oil is Good and also Royal Purple. I have been using Val. Racing Oil 40 weight for years and now am almost out of it so I need to buy some more oil for use in the solid lifter cam motor.
1971 HEMI E BODY REGISTRY
Re: Rottella T [Re: 68Bullit] #312703
05/10/09 10:02 PM
05/10/09 10:02 PM
[quote), but what makes the roller a stronger cam that it doesn't need the same amount of zinc?
The rolling friction is way less than the sliding friction of the flat tappet lobe/lifter setup
Re: Rottella T [Re: hemicar1971] #312704
05/10/09 10:21 PM
05/10/09 10:21 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I talked to a rep with Royal Purple and was impressed with their knowledge and understanding of the importance of using the right oils with flat tappets. The rep was of course biased toward his own RP brand, but he advised to just pick a good synthetic (of any brand), and avoid using addtives that we really don't know much about. Some additives with too much zinc could cause an ashing effect, which of course is bad. GM EOS as an example, warns against use after break-ins, and states on the bottle not to use as an engine "additive"
Re: Rottella T [Re: RapidRobert] #312705
05/10/09 10:32 PM
05/10/09 10:32 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Thanks Robert. You know anything about problems with some of the new roller lifters? I've been looking very seriously into a roller cam to be retrofitted into my LA 360. Giving 2nd thoughts now that I'm hearing more about problematic lifters
Re: Rottella T [Re: 68Bullit] #312706
05/10/09 10:36 PM
05/10/09 10:36 PM
You know of anything about problems with the new roller lifters?
Unfortunately I do not but definitely investigate before you invest.
Re: Rottella T [Re: 68Bullit] #312707
05/11/09 03:25 AM
05/11/09 03:25 AM
Florida STAYcation
dUmB! Online penguin-006
The village idiot's idiot
dUmB!  Online Penguin-006
Florida STAYcation
MY thoughts ...almost exactly. But I was thinking more in-the-line of a RB engine for an RV application.
Some of these RV/towing cams that Crane and CC make have radical high lifts, short duration, quick ramps and absolutely require the usage of a roller lifter(a flat tappet cam would go "flat" in no time) .....
B U T ...I have yet to see any type of reliability testing on these aftermarket parts. And I have heard many horror-stories HERE and elsewhere about these lifters failing.
What specifically ? ....guide bars falling off ... and the rollers coming apart and filling the motor with that junk.
WHEN the aftermarket can convince me of a fail-safe part(like the OEM has) ...I will stick with a flat tapet cam and USE the good-oil
Re: Rottella T [Re: 68Bullit] #312708
05/11/09 03:14 PM
05/11/09 03:14 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
We see OEM hydraulic roller lifters holding up well for several 100k miles. But I wouldn’t put that much merit into an aftermarket set in high performance applications. In my view, more moving parts means more moving parts that could go wrong.
Also, the founder of Schubeck lifters warned of using roller lifters that have needle bearings in them likening them to a ticking time bomb. Instead, Joe Schubeck had a roller lifter design that utilized pressurized oil from the motor rather than the needle bearings. That would be the way to go if you wanted to run a roller lifter.
Roller lifters have a roller on the side of the tappet that meets the cam lobe. Because of this design, the coefficient of friction is greatly reduced when compared to a flat-tappet lifter which is basically a flat piece of metal that comes directly into contact with the cam lobe which slides over the cam lobe when in operation. As a result, a flat-tappet lifter has no provision in of itself to reduce friction like the roller lifter. This is why flat tappet cams rely primarily on anti-wear additives like Zinc & Phosphorous in motor oil to reduce the metal-to-metal contact friction.
Re: Rottella T [Re: CompSyn] #312709
05/11/09 03:24 PM
05/11/09 03:24 PM
scratchnfotraction Offline
my stock roller lifter have well over 150,000 miles and I swaped them to another roller block with a lunati roller cam .485/.485 lift and comp 901 springs 2 yrs ago
all stock valve train and not a problem yet
turns right up to 6000 rpms with no valve float
ticking time bomb?...maybe..but I bet the rest will let go first on this 88 high milage jy cop motor
runwhatyabrung
Re: Rottella T [Re: scratchnfotraction] #312710
05/11/09 03:35 PM
05/11/09 03:35 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
runwhatyabrung
That’s right “stock” or in other words “OEM” roller lifters probably have a little more quality assurance than something you might get from an aftermarket retrofit kit; the kind people are reporting issues with.
Also, .485/.485 is conservative for a roller cam.
You prove the point well.
Wonder if we could find out what vendors the OEMs use?
Re: Rottella T [Re: dUmB!] #312711
05/11/09 03:47 PM
05/11/09 03:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Slightly OT ....
Anyone here know the designation on any oil container that indicates heavy zinc content?
I have got a couple of motors going together and will be using NON-roller cam.
hmm...roller lifters have only been in small block mopars for 24 years now......the OEM hydraulic rollers are VERY reliable.
2017 Grand Cherokee Overland
Re: Rottella T [Re: patrick] #312712
05/11/09 04:05 PM
05/11/09 04:05 PM
Umm?
I prove what point well?
that "oem" roller lifters are reliable or my cam is conservative?
I would think that the roller lifters that ou812 has that have been modded to address some of the probs would be the ticket
longer skirts around the roller to keep it from uncovering the oil galley with high lifts and edm/pressurized oiling to the neddle bearings
and link bar away from the block and to the inside
would be the way to go,seems they did there home work for longevity to me
dont know what all probs there could be..but roller lifters have been around since the 1800s
but again its qaulity control,I geuss that make the diff
Re: Rottella T [Re: scratchnfotraction] #312713
05/11/09 04:32 PM
05/11/09 04:32 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I’m not disagreeing with you for the most part. Roller lifters are the pinnacle of valve-train technology.
What I’m getting at is the roller lifters that come standard on new vehicles that were engineered to use roller lifters are designed to last the duration and will undoubtedly be reliable.
The question I’m raising is aftermarket type roller lifters you might purchase from Jegs, Summit or other speed shops, and ones designed for use in older engines that didn’t originally utilize roller lifters may have questionable longevity when compared to a new Dodge Hemi over at the car lot.
What I’m talking about is OEM VS. AFTERMARKET.
NOT saying that roller lifters are a bad idea in general.
I believe this is what Doc was getting at as well.
Page 2 of 3 1 2 3
