Distributor for use on RB with Trick Flows?
#3126660
03/05/23 10:31 AM
03/05/23 10:31 AM
Posts: 1,237 North Central, Indiana
Roughbird72
This has probably been addressed a few times already, but it's been quite awhile since I visited the forum. What/who's distributor have you been running on RBs with Trick Flow cylinder heads?
72 Plymouth Roadrunner 11.08@123.25
Re: Distributor for use on RB with Trick Flows?
[Re: one bad fish]
#3126677
03/05/23 12:00 PM
03/05/23 12:00 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Following along as well as I have Trick Flows on order. I'm hoping the stock electronic distributor fits, I have two that have been recurved with the Mr. Gasket kit and I use them to trigger a 6AL.
[Re: Blusmbl]
#3126708
03/05/23 01:46 PM
03/05/23 01:46 PM
Posts: 4,672 Wichita
GY3
Wichita
Yeah, I really don't see why people spend lots of extra money on an aftermarket magnetic pickup distributor that doesn't fit.
A recurved stock one with a 6AL box works 99% as good on a street car and if you're going full race a magnetic crank trigger is the way to go.
[Re: Roughbird72]
#3126762
03/05/23 05:25 PM
03/05/23 05:25 PM
Posts: 269 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I've used a remaned stock electronic distributor, parts store reproduction electronic distributor, and now a MSD pro billet. All fit the heads fine, but I did have to do some grinding on my cast aluminum valve covers for the MSD
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3126808
03/05/23 07:43 PM
03/05/23 07:43 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
[quote=metallicareload All fit the heads fine, but I did have to do some grinding on my cast aluminum valve covers for the MSD [/quote] This . I have TF270s
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3127240
03/07/23 12:34 PM
03/07/23 12:34 PM
Roughbird72
Thanks for the input! I wasn't sure about clearance issues and will stick with the MP distributor I currently have unless there's a lot of grinding to do.
[Re: Roughbird72]
#3127394
03/07/23 09:12 PM
03/07/23 09:12 PM
Posts: 1,030 ohio
67mprfan
ohio
I'm using the TF 270 heads with a MSD distributor and mopar performance valve covers and had trim the valve cover lip some. Also I had to trim the gasket to, there the black thick rubber 1's
This is a B block
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
