318 pistons ? #3126578
03/04/23 10:49 PM
03/04/23 10:49 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
HI
ANY 318 Pistons that are high enough to 0 deck ?
current ones are .090 down at 1.771 ch
need .040 os
thank you !
Re: 318 pistons ? [Re: calrobb2000] #3126626
03/05/23 03:06 AM
03/05/23 03:06 AM
Originally Posted by calrobb2000
HI
current ones are .090 down at 1.771 ch, need .040 so thank you !
You know where your pistons are now in your block now so it is time look at the other 318 pistons out there for a taller compression height scope wrench up
How about a .050 to .075 longer rod?
Re: 318 pistons ? [Re: Cab_Burge] #3126909
03/06/23 09:43 AM
03/06/23 09:43 AM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
The KB hypereutectics are very close to zero deck, just be careful of the intake valve eyebrows are so big they dont leave much meat around the bores, at least on a standard 3.91 bore, an oversize is probably fine.
I built a 341" motor with those KB's in a standard bore low mileage 318 block and a 3.55 stroke MP crank with 6" aluminum rods, it rev'ed like a Banshee
WIZE
In Car:
Re: 318 pistons ? [Re: Streetwize] #3127446
03/08/23 04:22 AM
03/08/23 04:22 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The 5.2 magnum pistons are higher too.
Plynouth VIP '67 TT IC EFI
Re: 318 pistons ? [Re: jyrki] #3127837
03/09/23 03:03 PM
03/09/23 03:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
https://www.manciniracing.com/keblicprfopi10.html
https://www.summitracing.com/parts/wis-pts529a3/make/dodge
https://www.summitracing.com/parts/dms-1-6310-3940/make/dodge
These all have a compression height of 1.80 to 1.81. I never heard of the DSS piston brand before. The early 340 high compression pistons had a compression height of 1.84" and they stuck above deck by .018" (for a nominal deck height). Reference the Speed-Pro 340 pistons.
https://www.summitracing.com/parts/slp-l2316f30/make/dodge
Floyd Lippencott IV
