Re: Big power & 727… input or output shaft the weak link? [Re: polyspheric] #3125707
03/01/23 05:00 PM
03/01/23 05:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by polyspheric
What does this remind me of?
"When should I stop "improving" my 8-3/4 and get a 9"?"
Rossler T400
They blow up too.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125708
03/01/23 05:03 PM
03/01/23 05:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by topfueldart
Originally Posted by J_BODY
I’d run em! Personally I’ll think you’ll be fine.
At its current power level, I think it’s ok, but being it’s turbo’d, it’s really easy to pickup another 100 horse. I did already break a set of stock pump gears, and I plan to do a drag and drive this year, so considering all upgrade options since it’s already out. I think my combo is potentially pretty hard on hard parts leaving on a bunch of boost with the transbrake, and stiff/short radials.
Spend it now or spend it later. Trans is out, it's hard to find 727 parts when everyone else is running .. insert GM trans here ....
Re: Big power & 727… input or output shaft the weak link? [Re: JohnRR] #3125718
03/01/23 05:45 PM
03/01/23 05:45 PM
Renton Wa
topfueldart Offline OP
Renton Wa
Originally Posted by JohnRR
A friend of mine was doing the burnout contest at carlisle one year and broke the output shaft at the end of the front planet splines. Car was stationary , 383 - 2bbl in a 69 Satellite wagon. What happened was the spiders in his single track 3.23 gear rear end seized on it's shaft shaft and in the split second it took for the spiders to break into pieces it shocked the driveline enough to break the output shaft. He was lucky because the rear sprag in the trans was also rolled, I don't know when that happened though as he didn't really beat on the car outside of that one burnout contest.
My pumps gears broke on decel or engine shut off, after a usual pass. Fired the car back up at the ticket shack and it wouldn’t move.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Big power & 727… input or output shaft the weak link? [Re: 440Jim] #3125753
03/01/23 07:38 PM
03/01/23 07:38 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by 440Jim
Originally Posted by dvw
My input and output shafts have 850+ passes. Though all are footbrake. I've broken 3 Dana pinion gears. Dizusters turbo car also ran stock shafts. Its broken rear axle pinion shafts, aftermarket steel drive shafts. But never either trans shaft, Both were over 850 hp. His weighed 3750, mine 3350. Both are 65 push button. Both have stripped stock front planet carriers. Both run stock pump gears.
Doug
I broke the "ears" off one set of stock 727 pump gears also. It happened during the Mopar weekend about 2008, during time trials.
With the help of a couple racers, we pulled the trans, took it apart, found some new pump gears at a vendor; and I made the first round of eliminations. wrench drive
I remember being under your Dart getting it out….lol
You helped me running a charger up to the lanes in later rounds
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125825
03/02/23 12:25 AM
03/02/23 12:25 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I broke a hub two years ago.
[Linked Image][/url][/img]
And a band anchor last year.
Re: Big power & 727… input or output shaft the weak link? [Re: polyspheric] #3125841
03/02/23 08:17 AM
03/02/23 08:17 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
T400s fail too, just like every transmission can. Their biggest advantage is they have an aftermarket SFI certified case. So if they do have an internal failure, it will help contain the explosion. Being that the 727 we are discussing has a bolt in sprag and billet front drum, the main explosion risk is already addressed. He is simply asking about upgrading to hardened shafts. At his power level, and intended use, the stock shafts should be fine, but if he upgraded, he will never need to worry about it again.
Re: Big power & 727… input or output shaft the weak link? [Re: PLUM BAD] #3125849
03/02/23 09:31 AM
03/02/23 09:31 AM
A727Tflite Offline
A727Tflite  Offline
Your hub broke due to the very common issue of hub to support interference.
Notice the shiny area just above the break.
Re: Big power & 727… input or output shaft the weak link? [Re: B3422W5] #3125889
03/02/23 12:30 PM
03/02/23 12:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Blast from the past. Eric on the back of my mini-bike, hauling a generator and charger to the staging lanes. From the date on this pic, it was 2005.
It looked so funny, someone took a picture and gave it to us later... LOL
Re: Big power & 727… input or output shaft the weak link? [Re: A727Tflite] #3125927
03/02/23 02:52 PM
03/02/23 02:52 PM
Renton Wa
Renton Wa
Can you elaborate on this at all? Any specific cause, or just something to keep an eye out for? I imagine a thicker fiber washers would help push the hub back.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125932
03/02/23 03:08 PM
03/02/23 03:08 PM
A727Tflite Offline
A727Tflite  Offline
Edit - incorrect or broken #1 or 2 thrust, or mismatched parts.
Notice the earlier picture of a truly broken hub, it has a rough appearance. The second image is a smooth break, like it was machined in a lathe.
When first building the unit, place the empty support on the input assembly and see if there is interference.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3126379
03/04/23 09:55 AM
03/04/23 09:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I think I have a good 727 input shaft and hub in the archives. I’ll look. I certainly don’t need it.
Re: Big power & 727… input or output shaft the weak link? [Re: 440Jim] #3126384
03/04/23 10:05 AM
03/04/23 10:05 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Haha….I remember seeing that years ago. You guys bailed me out that night!
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3126947
03/06/23 12:06 PM
03/06/23 12:06 PM
an8sec70cuda Offline
FWIW I still have the stock shafts in the 727 in my cuda. It's over 3800 lbs and ran mid 9s NA from 2006-2015 w/ no trouble. Been running 8s on nitrous ever since. I don't race it very often though.
From what others have experienced, it wouldn't surprise me if it snapped something the next time I ran it. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Big power & 727… input or output shaft the weak link? [Re: an8sec70cuda] #3127442
03/08/23 02:22 AM
03/08/23 02:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I do have a 727 input hub assy smile
