Big power & 727… input or output shaft the weak link? #3125412
02/28/23 07:06 PM
02/28/23 07:06 PM
Renton Wa
topfueldart Offline OP
Renton Wa
I’ve got a 727 with all the normal heavy duty must haves, billet front drum, super sprag, steel front planet, billet servos and heavy struts and pump gears. I’ve got the trans out for a converter check and refresh, and just considering my remaining options for making it even stronger. Who has had a failure with an input shaft/hub, or an output shaft? Both look to be approaching $1000, so trying to decide if one or the other is more of a weak link. Also considering a rear roller kit.
Car is 3600 lbs with driver, leaving off a transbrake, running low 10’s, 60’s high 1.3x, and hopefully a little faster in the future.
Thanks all!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125423
02/28/23 08:37 PM
02/28/23 08:37 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
I only know one person who had an issue and it was the stock input hub that failed not the shaft. It was a 3,000 lb car that ran 8.80s-8.90s @ 150+. It was trans brake as well. But other than that, I have never heard of anyone having one fail. I know plenty who have ran high 8s-low 9s with heavy cars running stock input and output shaft. To include DVW.
I know if you were to do one or the other I’d say do the input and the hub. But I personally would do the roller components first. Just my own opinion.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125424
02/28/23 08:41 PM
02/28/23 08:41 PM
NC
440Jim Offline
440Jim  Offline
NC
I had an output shaft break, but not an input shaft.
3200 lb car & driver, 1.2x sixty foot, footbrake only
Re: Big power & 727… input or output shaft the weak link? [Re: 440Jim] #3125429
02/28/23 09:00 PM
02/28/23 09:00 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Dang Jim! That’s crazy.
I know mine has hardened input and output shaft and steel input hub. But for what he’s doing I wonder if it will be ok running 10s.
I know Rick Allison gives a general recommendation of 800hp and above 3,000lbs, he recommends the aftermarket shafts.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125435
02/28/23 09:10 PM
02/28/23 09:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’d run em! Personally I’ll think you’ll be fine.
Re: Big power & 727… input or output shaft the weak link? [Re: J_BODY] #3125444
02/28/23 09:53 PM
02/28/23 09:53 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My input and output shafts have 850+ passes. Though all are footbrake. I've broken 3 Dana pinion gears. Dizusters turbo car also ran stock shafts. Its broken rear axle pinion shafts, aftermarket steel drive shafts. But never either trans shaft, Both were over 850 hp. His weighed 3750, mine 3350. Both are 65 push button. Both have stripped stock front planet carriers. Both run stock pump gears.
Doug
Re: Big power & 727… input or output shaft the weak link? [Re: dvw] #3125461
02/28/23 10:29 PM
02/28/23 10:29 PM
NC
440Jim Offline
440Jim  Offline
NC
Doug
I broke the "ears" off one set of stock 727 pump gears also. It happened during the Mopar weekend about 2008, during time trials.
With the help of a couple racers, we pulled the trans, took it apart, found some new pump gears at a vendor; and I made the first round of eliminations. wrench drive
Re: Big power & 727… input or output shaft the weak link? [Re: J_BODY] #3125468
02/28/23 10:44 PM
02/28/23 10:44 PM
Renton Wa
Renton Wa
At its current power level, I think it’s ok, but being it’s turbo’d, it’s really easy to pickup another 100 horse. I did already break a set of stock pump gears, and I plan to do a drag and drive this year, so considering all upgrade options since it’s already out. I think my combo is potentially pretty hard on hard parts leaving on a bunch of boost with the transbrake, and stiff/short radials.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125470
02/28/23 10:54 PM
02/28/23 10:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rollerized rear support is a no brainer.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125474
02/28/23 11:00 PM
02/28/23 11:00 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Dizusters ran 22lbs boost, trans brake, radials. 1.38/9.55@142 3750lbs full exhaust with the same M/T radials it ran on tthe street.
Doug
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125507
03/01/23 01:02 AM
03/01/23 01:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Interesting on the pump gears….. I lost a set in my old dump truck trans.
Re: Big power & 727… input or output shaft the weak link? [Re: J_BODY] #3125512
03/01/23 01:27 AM
03/01/23 01:27 AM
A727Tflite Offline
A727Tflite  Offline
What kind of power were you making? grin
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125523
03/01/23 04:47 AM
03/01/23 04:47 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
if you have it apart, look at the oil holes in both the input and output. when they’re getting ready to let loose, the oil holes will be oval instead of round. also check the input splines. if they aren’t straight, you’re at the limits of stock shafts.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125527
03/01/23 07:14 AM
03/01/23 07:14 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Broke an O/P shaft, 9.60 / 9.70 1/4, mid 1.30's 60, car w/d was 3900lb, motor around 880hp at the time, footbrake only. We upgraded the I/P and O/P shaft while it was apart.
We have a 655 waiting for parts, to go in. We will run it behind that but before we fit N20 we are going to a TH400 derived box.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125558
03/01/23 09:29 AM
03/01/23 09:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
What does this remind me of?
"When should I stop "improving" my 8-3/4 and get a 9"?"
Rossler T400
Boffin Emeritus
Re: Big power & 727… input or output shaft the weak link? [Re: A727Tflite] #3125577
03/01/23 10:07 AM
03/01/23 10:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mid 9 sec small block. 3k weight. Leave 4500-5k off the brake. I’m now at low 9’s with an incredibly stock component 904…… but I used simple mopar math for that swap 904>727. 86 passes and ok so far. Good thing I don’t race much I guess.
Re: Big power & 727… input or output shaft the weak link? [Re: topfueldart] #3125658
03/01/23 02:02 PM
03/01/23 02:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As most probably know, there is a factory HP input shaft identified by a radial groove and (sometimes) a yellow paint daub, it's made of a better alloy steel. I believe the majority of input failures aren't the shaft itself but the hub at the rear clutch piston retainer.
Re: Big power & 727… input or output shaft the weak link? [Re: 440Jim] #3125699
03/01/23 04:38 PM
03/01/23 04:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
[ [/quote]
With the help of a couple racers, we pulled the trans, took it apart, found some new pump gears at a vendor; and I made the first round of eliminations. wrench drive [/quote]
I sheared the pump lugs/ears driving up the freeway , trans shop asked if I had any backfires . None , I think after 15 yrs use it was bad luck . But it filled the trans and cooler with metal . So I bought billet gears and a super sprag as upgrades . Footbrake low mid 10s . I do have a Griner vb .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Big power & 727… input or output shaft the weak link? [Re: 71Demon528] #3125704
03/01/23 04:56 PM
03/01/23 04:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A friend of mine was doing the burnout contest at carlisle one year and broke the output shaft at the end of the front planet splines. Car was stationary , 383 - 2bbl in a 69 Satellite wagon. What happened was the spiders in his single track 3.23 gear rear end seized on it's shaft shaft and in the split second it took for the spiders to break into pieces it shocked the driveline enough to break the output shaft. He was lucky because the rear sprag in the trans was also rolled, I don't know when that happened though as he didn't really beat on the car outside of that one burnout contest.
Re: Big power & 727… input or output shaft the weak link? [Re: John_Kunkel] #3125705
03/01/23 04:58 PM
03/01/23 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by John_Kunkel
As most probably know, there is a factory HP input shaft identified by a radial groove and (sometimes) a yellow paint daub, it's made of a better alloy steel. I believe the majority of input failures aren't the shaft itself but the hub at the front clutch piston retainer.
The Diesel trucks usually split the hub instead of breaking the shaft out of the hub.
