Re: Got a heck of a deal on a big air compressor
[Re: TJP]
#3123679
02/22/23 02:00 PM
02/22/23 02:00 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
SOMEWHAT APPROPPRIATE Put a ball valve drain on the tank with a catch pan under it. I used a brass 1/4" NPT elbow with a 6" ? nipple with the valve and another elbow on the end. Just crack the valve every morning before starting it as all the water will be at the bottom. If you don't use it every day, just crack it open to drain the majority and recheck later or before using again. Thank you.
Keep old mopars alive.
