FINALLY! New vent window seals for 87-93 trucks!!
#3122153
02/16/23 08:02 PM
02/16/23 08:02 PM
Posts: 20,682 in a cattle trailer down by th...
Guitar Jones
Steele Rubber Products finally has vent window weatherstrips for the 87-93 pickup trucks. They also have a new windshield gasket which I'm sure is better than the Precision piece of scrap everyone else sells. New vent window seals
Re: FINALLY! New vent window seals for 87-93 trucks!!
[Re: volaredon]
#3122176
02/16/23 09:13 PM
02/16/23 09:13 PM
Guitar Jones
[Re: volaredon]
#3122317
02/17/23 12:59 PM
02/17/23 12:59 PM
Guitar Jones
Huh... Wouldn't have thought that. I have several spare doors for my 85, gonna have to swap out passenger door sometime, have to watch for that. I'd like to have them both the same, what's different about them? Is it the door shell itself or is it the wing window/ wing window frame? The door I was planning on swapping to came off a 92, can I put my original 85 wing window assy in the 92 door and call it good? I known have to swap out door latches because of a difference in striker posts new to old, in that span. The window and the pivots are different. You can swap the entire frame though.
[Re: 5thAve]
#3122318
02/17/23 01:03 PM
02/17/23 01:03 PM
Guitar Jones
What's wrong with the ones that were available before? I never installed mine yet but a mopar buddy of mine did and I never heard of him ever having problems. There never were any available before for the 87-93 style. You could use the 81-86 style if you modified the gasket for the upper pivot but they still leaked because the bottom of the 87-93 window lacks the metal base of the 81-86 style.
[Re: Guitar Jones]
#3122393
02/17/23 05:27 PM
02/17/23 05:27 PM
Posts: 2,284 ILLINOIS
volaredon
ILLINOIS
Huh... Wouldn't have thought that. I have several spare doors for my 85, gonna have to swap out passenger door sometime, have to watch for that. I'd like to have them both the same, what's different about them? Is it the door shell itself or is it the wing window/ wing window frame? The door I was planning on swapping to came off a 92, can I put my original 85 wing window assy in the 92 door and call it good? I known have to swap out door latches because of a difference in striker posts new to old, in that span. The window and the pivots are different. You can swap the entire frame though. I'll have to look at that next time I'm at the barn where my parts are stored
[Re: Guitar Jones]
#3122532
02/18/23 01:51 PM
02/18/23 01:51 PM
Posts: 4,163 Canada -- Posts: 4034 -Registe...
5thAve
What's wrong with the ones that were available before? I never installed mine yet but a mopar buddy of mine did and I never heard of him ever having problems. There never were any available before for the 87-93 style. You could use the 81-86 style if you modified the gasket for the upper pivot but they still leaked because the bottom of the 87-93 window lacks the metal base of the 81-86 style. Tanks, I didn't know till reading the additional posts how they changed throughout the years.
[Re: 5thAve]
#3124688
02/26/23 03:03 AM
02/26/23 03:03 AM
Guitar Jones
The seals came in late Thursday, I installed them Friday, but didn't drive anywhere. Weather was bad Saturday so I didn't drive it then either. Should be decent here today so I'll update after I drive it down the highway today. They are supple and it definitely feels tighter to close the window so I'm hopeful.
[Re: Guitar Jones]
#3124913
02/26/23 10:50 PM
02/26/23 10:50 PM
Guitar Jones
Well I still have wind noise but it's about half what is was before. I knew it would never be quiet like a new vehicle so it's all good. I still have plenty of weather strips and seals to replace.
