1968 Road Runner emblem locations #312017
05/08/09 06:01 PM
05/08/09 06:01 PM
IL
bluestar2 Offline OP
IL
Can someone give me the dimensions for placing the door Road Runner emblems.I need the locations for the Road Runner emblem itself not the bird.
I also need the locations for the emblems on the trunk for a car without the finish panel and with a Hemi engine. From what I have been told there is a Plymouth emblem, a Road Runner emblem like on the doors, a Road Runner bird sticker and a small Hemi emblem also.
Can someone please confirm that this is true and give me actual dimensions on where they all go?
Thank You, Mark
Re: 1968 Road Runner emblem locations [Re: bluestar2] #312018
05/08/09 10:55 PM
05/08/09 10:55 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
MikeR
Re: 1968 Road Runner emblem locations [Re: A12] #312019
05/08/09 10:56 PM
05/08/09 10:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
*** A dimension 3-15/16"
Re: 1968 Road Runner emblem locations [Re: A12] #312020
05/08/09 11:00 PM
05/08/09 11:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is from upper horizontal edge (that you can just see in the above photo) to the front emblem hole:
C = 3-1/2"
Re: 1968 Road Runner emblem locations [Re: A12] #312021
05/08/09 11:02 PM
05/08/09 11:02 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
From upper horizontal edge (that you can just see in the above photo) to the rear emblem hole:
D = 3-5/8"
Re: 1968 Road Runner emblem locations [Re: A12] #312022
05/08/09 11:31 PM
05/08/09 11:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Let's try this a little differently:
Re: 1968 Road Runner emblem locations [Re: A12] #312023
05/08/09 11:34 PM
05/08/09 11:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
B dimension = 4-11/16"
Re: 1968 Road Runner emblem locations [Re: A12] #312024
05/08/09 11:35 PM
05/08/09 11:35 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
B = 4-11/16"
Re: 1968 Road Runner emblem locations [Re: A12] #312025
05/08/09 11:44 PM
05/08/09 11:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
and now I give you the bird......oops that doesn't sound right
It is about the width of the inside area of the metal emblem or about the width of the letters "oa" of the word road and in line with the bottom edge of the emblem straight between the "toes" of the road runner's foot. If that makes sense you have problems too I've looked at lots of '68 rr door birds and they vary a quarter inch more or less but the photo is an original and a decent location example IMO.
MikeR
Re: 1968 Road Runner emblem locations [Re: A12] #312026
05/09/09 10:02 AM
05/09/09 10:02 AM
IL
IL
Awesome!!!thanks for the help. I assume that the passenger side is the same?
Anyone have dimensions for the emblems on the trunk lid?
Re: 1968 Road Runner emblem locations [Re: bluestar2] #312027
05/09/09 09:59 PM
05/09/09 09:59 PM
SE Pa.
LimeliteAero Offline
SE Pa.
WOW!
talk about a reply!
Re: 1968 Road Runner emblem locations [Re: LimeliteAero] #312028
05/10/09 10:36 PM
05/10/09 10:36 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
WOW!
talk about a reply!
Thanks but now I have to do the trunk:
Here's what it should look like but sorry to say I don't have a Hemi.....but lucky that my original trunk finish panel is being restored by Mr belvedere so for now I'm sporting the non-decor look Some of the photos I'll post will have the incorrect road runner "bird" above the "road runner" emblem but the holes are exposed for the P L Y M O U T H so that will at least be of some help I hope:
Non-decor trunk emblem:
MikeR
Re: 1968 Road Runner emblem locations [Re: A12] #312029
05/10/09 10:44 PM
05/10/09 10:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sorry for the upside down tape measure, I couldn't hold the tape measure steady and push the shutter button holding it in my right hand and the camera in the left hand It also worked better by hooking the tape measure onto the trunk lid edge for a better reference/measurement too: (save the photo and rotate it or turn your monitor upside down )
Re: 1968 Road Runner emblem locations [Re: A12] #312030
05/10/09 10:50 PM
05/10/09 10:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
first this then the trunk lid with the wrong bird and PLYMOUTH emblem holes:
Re: 1968 Road Runner emblem locations [Re: A12] #312031
05/10/09 10:56 PM
05/10/09 10:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
It's about 1-inch from the top of the road runner emblem to the trunk lid body line or 3/8" from the bottom of the emblen to the body line:
Re: 1968 Road Runner emblem locations [Re: A12] #312032
05/10/09 11:01 PM
05/10/09 11:01 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
don't remember but I think the rr emblem pins are in the center of the backside of the emblem so that would be 11/16" up from the trunk line to the hole center....
Re: 1968 Road Runner emblem locations [Re: A12] #312033
05/10/09 11:09 PM
05/10/09 11:09 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
now the rr trunk lid with the incorrect "door" rr bird...but note even though the rr emblem is crooked it is still 2-1/2" in from the trunk lid edge and 3/8" up from the body line......well at some point it's 3/8th of an inch up
MikeR
Re: 1968 Road Runner emblem locations [Re: A12] #312034
05/10/09 11:37 PM
05/10/09 11:37 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The PLYMOUTH emblem hole locations:
Re: 1968 Road Runner emblem locations [Re: A12] #312035
05/10/09 11:41 PM
05/10/09 11:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
PLYMOUTH #1
Re: 1968 Road Runner emblem locations [Re: A12] #312036
05/10/09 11:54 PM
05/10/09 11:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
PLYMOUTH #2
