Page 2 of 3 1 2 3
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3116856
01/26/23 08:54 PM
01/26/23 08:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Does it have a smaller battery inside? or is it a gel type battery?
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: mopars4ever] #3116891
01/26/23 11:23 PM
01/26/23 11:23 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
Yes it does. I removed the 6 caps. Looking down into the case, it appears to be an Odyssey AGM battery.
David
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3117115
01/27/23 05:09 PM
01/27/23 05:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Did Jims give you any info on it? What warranty did they give with the battery? I wonder about the cranking amps on that particular battery?
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: mopars4ever] #3117203
01/28/23 12:58 AM
01/28/23 12:58 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I intended to call Jim's today to ask for the manufacturer and model of the AGM, but forgot. I will call next week. Here is the info that came with the battery:
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3117208
01/28/23 01:41 AM
01/28/23 01:41 AM
WA
tman Offline
tman  Offline
WA
When you do call, do ask is there a way to open the case when the battery dies so we can replace ourselves. Thx
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: tman] #3117247
01/28/23 11:02 AM
01/28/23 11:02 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I too was curious if that could be done. When I asked last year, this is the response I got: "Very difficult and very time consuming. But it can be done." Here is a picture of the underside. You can see a seam near the outer edge,,, that's where I would probably began the surgery if I needed to get inside the case.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3117530
01/29/23 04:18 PM
01/29/23 04:18 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good news on the caps and decals...good news on the resto case with AGM inside.
What does that new Jim's battery weigh?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: DynoDave] #3117641
01/30/23 02:25 AM
01/30/23 02:25 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
It's not visible in the image I uploaded of the shipping carton...but the UPS Ground shipping label states 35 lbs.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3117783
01/30/23 06:12 PM
01/30/23 06:12 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Thanks David. I didn't see that.
DynoDave
Member # 12304
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: mopars4ever] #3118222
02/02/23 02:55 AM
02/02/23 02:55 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
I spoke to Jim yesterday and asked for the name of the manufacturer and model of the battery inside. He said it was an Odyssey and the model was "similar" to a PC925. I then asked if the specs were exactly the same as the PC925. His response was "very close". My last question was if the battery was custom made for him. He said no.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: David1971] #3118254
02/02/23 10:35 AM
02/02/23 10:35 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
I've done this - it's not that bad. Just cut along the edge/seam and make sure you leave enough to accept a screw to hold a new plexi cover (to keep the new battery in the case). The hardest part is getting the replacement cable the right length so it can be tightened to the new battery terminal and still fit within the case. The replacement battery was a PC925.
Link
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: KWF340] #3118449
02/02/23 09:48 PM
02/02/23 09:48 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: RealWing] #3118485
02/03/23 02:19 AM
02/03/23 02:19 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: 340SIX] #3118487
02/03/23 02:34 AM
02/03/23 02:34 AM
WA
tman Offline
tman  Offline
WA
Battery we are referring to are from "Jims Battery" cases with a battery inside. So when it fails, we are trying to figure out an easy way to change it out the inner battery. I assume all the hardware to hook them up are inside. So this would be a no mess situation like the one you are referring to. I totally agree, cleaning out an exiting battery is a mess and lots of work.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: tman] #3118505
02/03/23 08:06 AM
02/03/23 08:06 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
The hardware is there, but you will find the cables are too short. Best to get a longer cable and cut to size. There isn't much room in the case to fit your hand in there and make the connection to the battery.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: KWF340] #3118571
02/03/23 11:56 AM
02/03/23 11:56 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I bought 12" cables and do my conversions with the Odyssey PC925 batteries.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: 6PKRTSE] #3118601
02/03/23 02:00 PM
02/03/23 02:00 PM
moparx Offline
moparx  Offline
what does the pc925 battery weigh ?
beer
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: moparx] #3118630
02/03/23 03:27 PM
02/03/23 03:27 PM
Kirkland, Washington
Pacnorthcuda Offline
beer
23.8 pounds. I put one in my gutted retro case. I weighed the old batt before gutting and the damn thing was 58 pounds. I think my odyssey version is 28-29.
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: Pacnorthcuda] #3118703
02/03/23 07:42 PM
02/03/23 07:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That is a small trolling motor or atv battery isn`t it. Not many CCA`s
Re: Will Repro Group 27 Batteries Ever Be Made Again [Re: mopars4ever] #3118729
02/03/23 09:58 PM
02/03/23 09:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Actually, it rolls over my 10.75:1 440 faster than the reproduction batteries ever did.
Page 2 of 3 1 2 3
