Re: Oh good, even safer gas cans
[Re: 65pacecar]
#3119230
02/06/23 12:40 AM
02/06/23 12:40 AM
Posts: 9,140 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I don’t think O ever spilled a drop of gas in my life until the new “safe” one came out. Nearly impossible to use and not spill. Yep. Me too.
[Re: Ramrod39]
#3119236
02/06/23 08:14 AM
02/06/23 08:14 AM
Posts: 19,970 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I don’t think O ever spilled a drop of gas in my life until the new “safe” one came out. Nearly impossible to use and not spill. Yep. Me too. Me three. If the cans being open was a problem, a small cap on the end, like a few of my "pre-safety" cans have, was a sufficient solution. I like having those caps anyway in case I need to transport the cans while full.
Earning every penny of that moderator paycheck.
DBAP
[Re: TJP]
#3119244
02/06/23 09:12 AM
02/06/23 09:12 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Maximum retardation.
Nothing to stop you from unscrewing the crap device and just pouring the gas through a funnel into the vehicle.
Which is exactly what I do, neater and doesn't spill a drop.
I have a number of cans purchased back in the 80's and early 90's before all this nonsense.
"I think its got a hemi"
[Re: gdonovan]
#3119259
02/06/23 10:16 AM
02/06/23 10:16 AM
Posts: 3,389 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Still have some old metal Eagle cans I still use. They are tough, seal tight, and don't tip over in the trunk.
They are pricey new, but I got them at a DRMO auction years ago. Keep your eye out at garage sales and estate sales--the old cans are still out there.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wjb123]
#3119267
02/06/23 11:15 AM
02/06/23 11:15 AM
gdonovan
Oakdale CT
They are pricey new, but I got them at a DRMO auction years ago. Keep your eye out at garage sales and estate sales--the old cans are still out there. Same here. I went to the Eagle cans probably 10-12 years ago when I first experienced those garbage ventless cans they forced on us. Expensive is right, just googled them up and I think they are 2x what I paid back then. I like the eagle can just fine. I can't tell if this has any impact on the manufacture of those. Let's hope not. The Chinese are perfectly happy to sell you a 5 gallon "water jug" https://www.ebay.com/itm/392196444984?epid=8013092175&hash=item5b50bad338:g:wQgAAOSwh4ZiGD1o:sc:ShippingMethodStandard!06370!US!-1&amdata=enc%3AAQAHAAAAsGUqYiHOlroBrSKx3Kk9WcqAI0hx7Vsa6m9VPYRK%2BqgEXxRFoY3zJk97Ihkia1Mn3%2Br9bG3MeDZKyW9PXuHeE%2FOqEPTp%2F%2F4BepO%2BRbb4XLlqs1eyg8dxz4FnK8U8bwVBxSdF2KorZi6f%2FLuf8E%2BO0V0SR3re%2B0GARlzWL1dpTclUbPLdZUPZv5VEDtgPD5jeskRXqt3IEF9NeS63wCprU5oF7ukSeDNA5RHudVtiLLaS%7Ctkp%3ABk9SR96o1vTEYQ
[Re: gdonovan]
#3119283
02/06/23 12:44 PM
02/06/23 12:44 PM
Posts: 15,469 Omaha Ne
TJP
Omaha Ne
They are pricey new, but I got them at a DRMO auction years ago. Keep your eye out at garage sales and estate sales--the old cans are still out there. Same here. I went to the Eagle cans probably 10-12 years ago when I first experienced those garbage ventless cans they forced on us. Expensive is right, just googled them up and I think they are 2x what I paid back then. I like the eagle can just fine. I can't tell if this has any impact on the manufacture of those. Let's hope not. The Chinese are perfectly happy to sell you a 5 gallon "water jug" https://www.ebay.com/itm/392196444984?epid=8013092175&hash=item5b50bad338:g:wQgAAOSwh4ZiGD1o:sc:ShippingMethodStandard!06370!US!-1&amdata=enc%3AAQAHAAAAsGUqYiHOlroBrSKx3Kk9WcqAI0hx7Vsa6m9VPYRK%2BqgEXxRFoY3zJk97Ihkia1Mn3%2Br9bG3MeDZKyW9PXuHeE%2FOqEPTp%2F%2F4BepO%2BRbb4XLlqs1eyg8dxz4FnK8U8bwVBxSdF2KorZi6f%2FLuf8E%2BO0V0SR3re%2B0GARlzWL1dpTclUbPLdZUPZv5VEDtgPD5jeskRXqt3IEF9NeS63wCprU5oF7ukSeDNA5RHudVtiLLaS%7Ctkp%3ABk9SR96o1vTEYQ Might advise painting it red as I believe federal law states so for gasoline, just in case
[Re: IMGTX]
#3119314
02/06/23 02:51 PM
02/06/23 02:51 PM
Posts: 5,475 Michigan
oldjonny
Don't argue with me.
Nothing but race gas cans at my house for everything. Maximum fill rate into giant funnels for everything I do. I bought one of the "safe" cans just for diesel fuel for my Kubota. TOTAL piece of garbage. Most of the diesel ended up on the hood of the compact tractor when filling it.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: gdonovan]
#3119330
02/06/23 03:44 PM
02/06/23 03:44 PM
Posts: 19,548 north of coder
moparx
https://www.ebay.com/itm/392196444984?i crabbed and complained about three 5 gallon cans i bought about 6-8 years ago at the local gas station for 13 bucks a pop ! i fixed them by tearing the spouts apart, gutting them, and using a heavy plastic "push on" cap that fit the spout diameter. for a vent, i drilled a hole in the top of the can just past the handle, that fits a standard short rubber tire valve stem. it took a little finagling to fish the valve stem through the can to grab the end and finally popping it into the drilled hole. i removed the core, then reinstalled the cap. works like a charm ! just remove the valve stem cap when pouring, and it lets in just enough air to pour a nice, steady flow without the "glug, glug, glug" that can splash all over.
[Re: moparx]
#3119354
02/06/23 04:31 PM
02/06/23 04:31 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
For a future note. The replacement spout kits like this include a vent cap. Drill a hole, pop in the vent, Swap the spout and you are good as old style. I like your idea but this may save some fabrication.
[Re: IMGTX]
#3119399
02/06/23 07:56 PM
02/06/23 07:56 PM
Posts: 5,917 ohio
ruderunner
ohio
Looks like the kits I bought.
Angry white pureblood male
