aftermarket k-member race only
#3118930
02/04/23 08:50 PM
02/04/23 08:50 PM
Posts: 2,048 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I'm looking at different aftermarket tubular K members for my E-body, but not sure which one will do what I want (if any will). Most appear to change the spindles to a mustang II style, meaning new brake kit. Anyone know of a kit that will use a tubular K member, coil over shocks (no torsion bars), stock spindles, a manual rack and no engine mounts? Drag race only. I seem to remember someone years ago on here that had what I'm looking for, I think his business was Bondo Bob or something like that.
Thanks, Brian
Re: aftermarket k-member race only
[Re: '72CudaRacer]
#3118945
02/04/23 10:17 PM
02/04/23 10:17 PM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
Thanks, Brian His website is still up Here. But I think he quit a long time ago.
[Re: dvw]
#3118951
02/04/23 10:55 PM
02/04/23 10:55 PM
'72CudaRacer
Mooresburg, Tn
Pretty tough to do a rack with rear steer. Rack to pan interference is tight. Personally for the work invovled I'd either trim the stock K frame and keep the stock steering. Or go all the way and put a strut front end on it. Doug Not wanting to have a rear steer, want to move the rack up front, to get the steering link out of the oil pan. I hadn't thought of putting strut front end under it. I'll look into that option. Brian
[Re: dvw]
#3118969
02/05/23 12:19 AM
02/05/23 12:19 AM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Is Gerst still building his setup?
[Re: slantzilla]
#3118975
02/05/23 12:33 AM
02/05/23 12:33 AM
Posts: 9,847 MI, usa
dvw
MI, usa
Gerst sold out to QA1. After installing onef there kits I can make three observations. One; It doesnt save much weight. Two; The outer tie rods take close to 2 " of spacer to correct bumpsteer. Three: It's about $3500 Doug
[Re: dvw]
#3118976
02/05/23 12:38 AM
02/05/23 12:38 AM
Posts: 8,288 fredericksburg,va
cudaman1969
fredericksburg,va
If you convert to front steer you can't use the the stock steering arms/ball joints. The Ackerman will be backwards causing toe in on turns, not good. So again your back to swapping everything. Not much of a gain. Sure a little extra header clearance would make taking it apart easier. You loose a little weight with the rack. But not enough benefit to come even close to covering the cost. You could almost buy an aluminum block for the cost of the conversion. Doug I did one in a 68 Dart 42 years ago (reversed the spindles, ran the rack thru the x member) had no problem with steering. There’s a secret to it.
[Re: cudaman1969]
#3118994
02/05/23 06:46 AM
02/05/23 06:46 AM
dvw
MI, usa
If you convert to front steer you can't use the the stock steering arms/ball joints. The Ackerman will be backwards causing toe in on turns, not good. So again your back to swapping everything. Not much of a gain. Sure a little extra header clearance would make taking it apart easier. You loose a little weight with the rack. But not enough benefit to come even close to covering the cost. You could almost buy an aluminum block for the cost of the conversion. Doug I did one in a 68 Dart 42 years ago (reversed the spindles, ran the rack thru the x member) had no problem with steering. There’s a secret to it. And you secret is? Doug
[Re: dvw]
#3118996
02/05/23 07:04 AM
02/05/23 07:04 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I have one in my Challenger with a manual rack. Best part is, it was free to me. Just some manual labor that paid for it. Which was the only reason why I went with it. Otherwise, I would still be running all stock parts. I ordered mine with no tow hook, no motor mounts and no powder coating, since I painted it how I wanted everything. I run front and midplates with for/aft bars. It was close to 100 lbs of weight savings and if I remember correctly almost 2" of extra suspension travel. The adjustability of double adjustable coil overs. I drive mine on the street as well. I am able to run a flat bottom 10 quart top fuel/funny car type oil pan with no ground clearance issues. My trans pan and headers hang lower than the oil pan does. I am able to bolt in both headers from underneath with the engine installed on both sides all welded up in one piece. No multiple slip tubes to deal with since no torsion bars. Overall, I have no complaints.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dvw]
#3119029
02/05/23 10:36 AM
02/05/23 10:36 AM
cudaman1969
fredericksburg,va
If you convert to front steer you can't use the the stock steering arms/ball joints. The Ackerman will be backwards causing toe in on turns, not good. So again your back to swapping everything. Not much of a gain. Sure a little extra header clearance would make taking it apart easier. You loose a little weight with the rack. But not enough benefit to come even close to covering the cost. You could almost buy an aluminum block for the cost of the conversion. Doug I did one in a 68 Dart 42 years ago (reversed the spindles, ran the rack thru the x member) had no problem with steering. There’s a secret to it. And you secret is? Doug Simple, keep the tie rods from rack straight as possible out to lower ball joint arms. When one moves the rack way out front and tie rods are angled back the problems begin. Same as factory did it, in fact they’re angled forward a little. Factories spent millions figuring this out. It wasn’t perfect but we never had a problem with the outside tire flopping in on a turn.
[Re: cudaman1969]
#3119128
02/05/23 04:35 PM
02/05/23 04:35 PM
Posts: 19,456 north of coder
moparx
unless the factory tierod arms are a rusted mess, they can be lightly heated and bent outward using a rosebud torch head and a long piece of pipe. have a sand pile ready with a space dug out that will fit the tierod arm. after being heated and bent, get it in the sand pile as quick as possible, cover it up, and let it cool naturally. no strength will be lost. if needed, a small spacer can be added between the tierod arm and spindle to gain a little more bend [ackerman] if needed. this applies to the later style factory tierod arms without the ball joint attached. like the [easily fabbed] arms used on my "eternal '33 dodge humpback project", only using factory arms on a stock K member and bending them to get the ackerman needed, along with the correct height needed to keep the rack arms parallel with the arm attaching ends.
[Re: dvw]
#3119157
02/05/23 06:39 PM
02/05/23 06:39 PM
cudaman1969
fredericksburg,va
Simple, keep the tie rods from rack straight as possible out to lower ball joint arms. When one moves the rack way out front and tie rods are angled back the problems begin. Same as factory did it, in fact they’re angled forward a little. Factories spent millions figuring this out. It wasn’t perfect but we never had a problem with the outside tire flopping in on a turn. [/quote] This will not correct the Ackerman issue. The outer tie rod pivot will be way to far inward. Easy check. measure the toe. turn the wheel to full lock, then measure the toe. It will be towed in on a turn. Drive a car with a 1/2" or more of toe i and let me know how it drives. Doug [/quote] Sorry dude you have no clue
[Re: dizuster]
#3119226
02/05/23 11:55 PM
02/05/23 11:55 PM
slantzilla
Park Forest, IL
My car has the rack in the front of the k-frame. When I got it the tie rods were basically a "Z" shape. Bump steer and Ackerman sucked.
I gave it to a buddy of mine for a makeover and now the tie rods are straight. It has fabricated steering arms on it and spacers lowering the tie rods. We slso put stops on to limit the flopping of the tire crap.
[Re: slantzilla]
#3119234
02/06/23 07:38 AM
02/06/23 07:38 AM
Posts: 10,032 MN
JERICOGTX
MN
I made my own K memeber. Uses stock lower ball joints with the arms cut off. I then welded an arm onto the spindle. Also uses stock spindles, lower control arms, and upper A arms.
69 GTX
68 Road Runner
[Re: FastmOp]
#3119245
02/06/23 09:12 AM
02/06/23 09:12 AM
Posts: 10,032 MN
JERICOGTX
MN
Are you still using the torsion bars ? Yes.
69 GTX
68 Road Runner
