How to start-up in -55 Alaska #3118220
02/02/23 01:59 AM
02/02/23 01:59 AM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
Re: How to start-up in -55 Alaska [Re: Dart 500] #3118385
02/02/23 06:38 PM
02/02/23 06:38 PM
Minnesota
peabodyracing Offline
Minnesota
Even if it's a Ford it kind of hurts to watch. With the oil that cold it seems like a pointless exercise to destroy the bottom end of a good engine.
To each his own.
Lead, follow or get the hell out of the way
Re: How to start-up in -55 Alaska [Re: peabodyracing] #3118404
02/02/23 07:49 PM
02/02/23 07:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My 68 dart with a 273 always started right up even at -40F as long as I brought the battery in at night and I always ran 20-50 in it.
Re: How to start-up in -55 Alaska [Re: HotRodDave] #3118453
02/02/23 10:05 PM
02/02/23 10:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The oil as it cooled down likely became the equivalent of STP LOL, Surprised you didn't snap the oil pump drive laugh2
Re: How to start-up in -55 Alaska [Re: TJP] #3118457
02/02/23 10:32 PM
02/02/23 10:32 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Old Peg likes to keep er to the wood! Minty!
https://www.youtube.com/watch?v=b8gIUTkRqgM
Re: How to start-up in -55 Alaska [Re: Dart 500] #3118473
02/02/23 11:36 PM
02/02/23 11:36 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Well, that's why you need 0W & newer equipment! I'll remain at this latitude & if anything, head South!
Re: How to start-up in -55 Alaska [Re: Sunroofcuda] #3118554
02/03/23 11:29 AM
02/03/23 11:29 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Quite interesting! I honestly cant believe the Tranny even began to turn over even after the engine came to temp. I figured the clutch would say good night!
Re: How to start-up in -55 Alaska [Re: Moparnut426] #3118666
02/03/23 04:44 PM
02/03/23 04:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No. Way.
I'm too far north now.
Re: How to start-up in -55 Alaska [Re: Moparnut426] #3118672
02/03/23 05:00 PM
02/03/23 05:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I used to have a 91 Toyota that around 200000 miles on it. The trans whined pretty bad in 5th gear so I through a quart of Lucas in the trans. It made it super hard to shift even in Oklahoma winters, so on mornings below freezing I would start it to warm it up and put the transfer case in neutral and let it run with the trans in 3rd gear to turn all the parts. Always made it way easier to shift cold lol.
68 Barracuda Formula S 340
Re: How to start-up in -55 Alaska [Re: Bad340fish] #3118798
02/04/23 08:06 AM
02/04/23 08:06 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I saw a show that detailed how (and I don't recall if the German or Japanese did it) they left an airplanes engine empty of oil in super cold climates on their carrier. When it was need they poured in preheated oil and the startup was significantly better. Not practical with a car but feasible. Borrow several of your neighbors coffee makers specifically for the carafe and the hot plate!
Keep old mopars alive.
Re: How to start-up in -55 Alaska [Re: 2boltmain] #3118810
02/04/23 09:36 AM
02/04/23 09:36 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Or just plug on your block heaters, You can even put heaters on your trans, transfer case and rear.
Re: How to start-up in -55 Alaska [Re: 2boltmain] #3118835
02/04/23 12:38 PM
02/04/23 12:38 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
For years arctic bush pilots would drain the oil and store it inside. It made prop starting a lot easier.
When I lived in Fairbanks, I had block/oil/battery heaters that did the job well. I would always start the engine, get it to idle, let out the clutch. After a few seconds, I'd put the trans in gear, and the t-case in neutral and idle a bit more, then go.
Had to drive on flat spotted tires for 50 yards or so, and the seats felt like picnic benches for 5 or 10 minutes.
Radiator blankets are mandatory if you want cabin heat, heck the temp gauge would barely leave the peg. Never set the e-brake because the cable would freeze inside the casing, I saw more than one car getting hauled to a shop to thaw. It always involved an irate husband lol.
I didn't bother with the video, never understood why doing these things is so amusing. It takes forever, and the mechanical stuff takes a beating, but hey it's their stuff.
Re: How to start-up in -55 Alaska [Re: A990] #3118844
02/04/23 01:12 PM
02/04/23 01:12 PM
my own world
theraif Offline
theraif  Offline
my own world
i think this little thing looks cool
Re: How to start-up in -55 Alaska [Re: Dart 500] #3118852
02/04/23 01:47 PM
02/04/23 01:47 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
No Thank You. We had -31 here in W Md. b/4. It sucks.
America First!
Re: How to start-up in -55 Alaska [Re: carnut68] #3118875
02/04/23 02:47 PM
02/04/23 02:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Two of the things I noticed on the 1st video are probably the worst fan belt I've ever seen, and the fuel gauge never rose above empty.
Then again, a look at the rest of the truck, and I guess it's a science experiment...
I don't really understand a lack of mechanical sympathy, though; I plug in the plow truck & Pathfinder if temps get much under 32.
Even with 10W-30 in them, I notice a difference in turnover.
Re: How to start-up in -55 Alaska [Re: topside] #3118884
02/04/23 03:34 PM
02/04/23 03:34 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Arctic paradise? No such thing! As far as I'm concerned anyone living in - temps is realcrazy
Re: How to start-up in -55 Alaska [Re: Moparite] #3119066
02/05/23 01:15 PM
02/05/23 01:15 PM
moparx Offline
moparx  Offline
i think there is a name for that.......masochist ? shruggy
beer
