trans mount #3118482
02/03/23 12:58 AM
02/03/23 12:58 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
What are you using for trans mount car has mid plate and front plate but the trans is mounted solid to cross member what's your thoughts on this 904 trans and if you are using a mount what make or kind I would just have to change cross member and car is going to to shop soon for some up dates they could do while it's there. THANKS
Re: trans mount [Re: dragon] #3118495
02/03/23 03:46 AM
02/03/23 03:46 AM
Cab_Burge Online work
Cab_Burge  Online Work
My last S/P 1970 Cuda (chromoly tube chassis car) had all three, front motor plate, rear motor plate and a tranny mount with a removal tranny tunnel. That was good up
It was the easiest car I've owned to remove the tranny and converter wrenchup
Re: trans mount [Re: dragon] #3118517
02/03/23 09:30 AM
02/03/23 09:30 AM
an8sec70cuda Offline
Poly.
Periods are friends.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: trans mount [Re: an8sec70cuda] #3118628
02/03/23 03:23 PM
02/03/23 03:23 PM
moparx Online content
moparx  Online Content
poly certainly wouldn't hurt.
a common GM mount can be easily modified to fit, basically just slotting the mounting holes and a slight shave off the outer edges of the poly itself.
plus, the GM mount is shorter than the mopar mount, allowing the crossmember to be fabricated easier.
beer
