Cam Bearing replacement #3118180
02/01/23 08:01 PM
02/01/23 08:01 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
I'm thinking this is an easy question,I have a 383 short block sitting on the engine stand,motor has 80k miles on it.The #3 cam bearing is starting to flake apart.Can the cam bearings be replaced without taking the motor apart? 2 local machine shops told me no,the motor needs to come apart to do them.Is this true,I really don't want to dis-assemble this.Any input,Thanks,John
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Cam Bearing replacement [Re: charge70] #3118188
02/01/23 09:04 PM
02/01/23 09:04 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
If you're down to a short block you should be good to go as long as the rest of the engine is in good shape.
Re: Cam Bearing replacement [Re: charge70] #3118190
02/01/23 09:15 PM
02/01/23 09:15 PM
IMGTX Offline
IMGTX  Offline
I have the tool and have replaced them with the engine assembled. In fact I bought it because I had already assembled the engine before I realized the machine shop botched the bearing install and I didn't want to tear it down or take it back to them.
You will have to have access to the front and back of the engine with my tool so I actually did one in the car and others on the crane or bench so the engine stand wasn't in the way.
It is important to align the oil holes so I used a sharpie to mark the block and the bearing. I checked it afterward with a mirror and flashlight.
Just make sure the oil holes are aligned and no shavings get in the block. Shaving are a bad sign they usually mean the bearing didn't go in straight and the bearing is ruined. At least that has been my experience.
Re: Cam Bearing replacement [Re: charge70] #3118201
02/01/23 10:57 PM
02/01/23 10:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've done several in the car. it really helps to have the open valley wink In th ecar one has to be careful not to disturb the rear plug. This can be accomplished by A: using a spacer to limit the depth of the bearing mandrel / installer. or B: if you have access to a lathe have a shorter mandrel made. wink beer
Re: Cam Bearing replacement [Re: charge70] #3118206
02/01/23 11:20 PM
02/01/23 11:20 PM
are you feeling REALLY LUCKY? work
I would at least take the # 3 and 4 and # 5 and 6 rods and pistons out to provide some working room for access to that #3 cam bearing boss.
I have been installing cam bearings for a long, long time, make sure that the cam slides in and rotates smoothly before starting to reassemble the motor. If it doesn't rotate easily and smoothly get ready to carve on the new bearing with a bearing knife to fix it wrench up scope
Re: Cam Bearing replacement [Re: Cab_Burge] #3118224
02/02/23 07:00 AM
02/02/23 07:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I agree with Cab. I’ve install all my cam bearings as well.
Re: Cam Bearing replacement [Re: Cab_Burge] #3118313
02/02/23 01:42 PM
02/02/23 01:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it doesn't rotate easily and smoothly get ready to carve on the new bearing with a bearing knife to fix it.
I've never installed a set of cam bearings that the cam would fit in without scraping the bearings. (E-Booger claims the factory bored the installed bearings) This is why I wouldn't install them in an assembled short block...too much risk of shavings in the oil galleries. twocents
Re: Cam Bearing replacement [Re: TJP] #3118432
02/02/23 09:23 PM
02/02/23 09:23 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
How were you able to get the rear bearing out without taking the rear plug out?
Re: Cam Bearing replacement [Re: charge70] #3118493
02/03/23 03:36 AM
02/03/23 03:36 AM
All of the cam bearings except the rear #5 are easy to drive out, that one needs to have the rear plug removed to change it hammer wrench up
Re: Cam Bearing replacement [Re: charge70] #3118751
02/03/23 11:07 PM
02/03/23 11:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've done so by "hooking" the oiling hole and "Rolling" the bearing out like a freeze plug beer
Re: Cam Bearing replacement [Re: TJP] #3121034
02/12/23 09:59 PM
02/12/23 09:59 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
Just wanted to update this post.We were able to replace the bad cam bearing #3 along with #'s1&2. We did not due 4 or 5 because they looked to be in good shape and didn't want to make more problems that I already had.All went smooth,got the old ones out without any problems and the new ones went in nice as well.Cam turns smooth as it should and now I'm able to move forward with this.Thanks to all that replied..
Re: Cam Bearing replacement [Re: charge70] #3121041
02/12/23 10:44 PM
02/12/23 10:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Wimp on 4 & 5 LOL beer
Re: Cam Bearing replacement [Re: TJP] #3121069
02/13/23 02:35 AM
02/13/23 02:35 AM
Sounds like a ex Chevy racers comment to me whistling stirthepot devil stirthepot grin
Re: Cam Bearing replacement [Re: Cab_Burge] #3121312
02/13/23 10:19 PM
02/13/23 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
haha Only one and it was because the motor was free and money was TIGHT!!!! argue laugh2 beer
