Crankshaft profiling
#3117635
01/30/23 01:33 AM
01/30/23 01:33 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Just received my new Crower 4340 BB crank and was little surprised to not see any profiling of the leading edges of the throws. I will be using a crankscraper, and vacuum pump….but how important is some radiusing to the leading edges in an engine with these systems.
572” 7500 rpm. Good scraper with 13-14” vacuum.
Thanks.
Re: Crankshaft profiling
[Re: Chargerfan68]
#3117700
01/30/23 12:35 PM
01/30/23 12:35 PM
Posts: 4,206 New York
polyspheric
New York
Reason #1: cost$$$, not everyone understands why or wants to spend the money. "Leading edge" means you know which way the crank turns. Not as common as you would think. I've seen some with both edges end as sharp blades... The leading edge should be close to a full radius (using all the web thickness) not just smoothed, the trailing edge as close to a knife as you can. This will ruin the balance. It has almost no effect until high RPM, then it reduces CC pressure cycling, reduces oil temperature, and entrains less air.
Boffin Emeritus
[Re: EchoSixMike]
#3117776
01/30/23 05:39 PM
01/30/23 05:39 PM
Chargerfan68
New York, USA
Thanks all for the replies. I was also surprised that the leading edges were not profiled/radiused after how much this crank cost. However, other than that it is a very, very nice piece. I think I will give a call and ask why. I have seen mixed photos from Crower of radiused vs non-radiused throws.
Here are 2 pics:
[Re: Chargerfan68]
#3117791
01/30/23 07:28 PM
01/30/23 07:28 PM
polyspheric
New York
Extensive work on VW Type 1 (beetle) engines produced a crank where each cheek/CW is a full cylinder. Even changes in the OD of the CW create turbulence. Every cross-sectional area or shape change should be profiled as well - no sharp edges.
Appearance is nice, but the people who do the polishing are not engineers or machinists.
Reasons not to offer this as an option: Huge extra cost Slows down the production line They sell faster than they make already
Boffin Emeritus
[Re: polyspheric]
#3117800
01/30/23 08:14 PM
01/30/23 08:14 PM
Posts: 154 PINE VALLEY
Ray S
PINE VALLEY
Interesting thread. Some coatings are available to reject oil; I have Cerakote in my Geo Metro which regularly sees 6k rpm.
[Re: Chargerfan68]
#3117831
01/30/23 11:24 PM
01/30/23 11:24 PM
Posts: 9,841 MI, usa
dvw
MI, usa
Thanks. What heads ar you using to get the power range up to 7500? Doug
[Re: dvw]
#3117840
01/31/23 01:20 AM
01/31/23 01:20 AM
Chargerfan68
New York, USA
Thanks. What heads ar you using to get the power range up to 7500? Doug I have 572-13 prepped by Dwayne Porter.
[Re: Ray S]
#3117922
01/31/23 03:04 PM
01/31/23 03:04 PM
Posts: 19,408 north of coder
moparx
Interesting thread. Some coatings are available to reject oil; I have Cerakote in my Geo Metro which regularly sees 6k rpm. in my machinist career, cerakoat [coated] carbide cutting inserts were frequently used. they cut very well using little or no lubrication liquid, and would cut at almost twice the rpm and feed rate as a bare carbide insert would.
[Re: moparx]
#3117925
01/31/23 03:17 PM
01/31/23 03:17 PM
Ray S
PINE VALLEY
Interesting thread. Some coatings are available to reject oil; I have Cerakote in my Geo Metro which regularly sees 6k rpm. in my machinist career, cerakoat [coated] carbide cutting inserts were frequently used. they cut very well using little or no lubrication liquid, and would cut at almost twice the rpm and feed rate as a bare carbide insert would. Ooooh, I never knew that I wonder if mill bits would be helped
[Re: Cab_Burge]
#3117933
01/31/23 03:36 PM
01/31/23 03:36 PM
Chargerfan68
New York, USA
I've bought and use many different brands of stroker cranks from CAT (Call Auto Transport (China company) to) to KB, Bryant, Oho Crankshaft CO, and Molnar. Most of them had the front edge of the counterweights rounded off like the front edge of airplane wings and the back sides tapered down to nothing like the back edges of airplane wings are Yes…that’s what I thought of throughout this whole topic. I thought exactly of airplane wings. Rounded raidius front and tapered edge on rear. If calling gets me nowhere, I might do this myself. I have the equipment and ambition.
[Re: Ray S]
#3117947
01/31/23 04:20 PM
01/31/23 04:20 PM
moparx
Interesting thread. Some coatings are available to reject oil; I have Cerakote in my Geo Metro which regularly sees 6k rpm. in my machinist career, cerakoat [coated] carbide cutting inserts were frequently used. they cut very well using little or no lubrication liquid, and would cut at almost twice the rpm and feed rate as a bare carbide insert would. Ooooh, I never knew that I wonder if mill bits would be helped we had a few ceracoated carbide end mills in 3/4" size used to cut T6061 aluminum. those were used with a cutting fluid so the aluminum didn't stick. 3000-3200rpm, but i forget the ipm. it was up there though. man, the chips flew with those babies !
[Re: Chargerfan68]
#3117972
01/31/23 06:55 PM
01/31/23 06:55 PM
polyspheric
New York
Ideally, the trailing edge should taper down from full thickness at a 15° angle. Needless to say, there's no room for that.
This is also a favored shape for the back of LSR vehicles. The "Kamm" principle dictates that if this isn't possible, the next best shape is to reduce both length & width of the tail at 15° until the cross-sectional area is 50% of the car's full dimensions, and cut it off flush at this point (no radius). Is the closed end vertical, or 90° to the air flow? IDK.
Boffin Emeritus
[Re: Chargerfan68]
#3118072
02/01/23 10:25 AM
02/01/23 10:25 AM
polyspheric
New York
It has little value at lower RPM, but is especially helpful with big strokers where the crankcase air volume is nearly OEM but the pressure cycling is higher.
Boffin Emeritus
[Re: HardcoreB]
#3118082
02/01/23 11:10 AM
02/01/23 11:10 AM
Ray S
PINE VALLEY
Not sure what it cost you? No-doubt that's a 'good' CCW crank! I'll look at my old Crower BBM crank and compare but, I doubt you'd notice any power difference. So don't risk anyone messing things up to fix what isn't broken IMO. Keep us updated on your build, so far it sounds promising. Yeah, and maybe a better overall option is to just coat it to sling oil off and add a crankcase vacuum pump that switches on at high-rpm/throttle or low vacuum to lower the air density it sees.
[Re: Chargerfan68]
#3118169
02/01/23 06:48 PM
02/01/23 06:48 PM
polyspheric
New York
Getting the oil off the crank is a different question, even a sharp tail will do that. The blunt CW leading edges create a lot of drag trying to plow through the hurricane of hot air, oil vapor, blah. Reducing the air density with a pump is a great idea: do both. It's why modern boats have a "bulb" in front of the bow, but a rounded nose was used on the Nile 6,000 years ago.
Boffin Emeritus
[Re: polyspheric]
#3118172
02/01/23 07:06 PM
02/01/23 07:06 PM
Chargerfan68
New York, USA
Getting the oil off the crank is a different question, even a sharp tail will do that. The blunt CW leading edges create a lot of drag trying to plow through the hurricane of hot air, oil vapor, blah. Reducing the air density with a pump is a great idea: do both. It's why modern boats have a "bulb" in front of the bow, but a rounded nose was used on the Nile 6,000 years ago. Thank you. That’s what I thought and it made sense in my mind. I am gonna call Crower..,,,then figure out best course of action to have it done. No sense, to me, in trying to accomplish a maximum effort build if I leave details untouched. This seems to be the modern, agreed upon shape at the leading edge:
[Re: dvw]
#3118281
02/02/23 12:37 PM
02/02/23 12:37 PM
Posts: 4,050 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
The trouble with the deep skirted block is the oil comes off and hits the block skirt. Back when I was working with Koffels their 400 block comp motor had holes milled betweeneach main web from the crank C/L to the pan rail. There were large buckets on that side of the block going to the pan. As I remember the opposite side of the block was filled with epoxy and smoothed. I would pay more attention to scraper/tray/pan then worry about the crank shape. Doug X2 Also, if it makes you feel any worse LOL the crank i have is rounded on both edges of the throws like in your LAST picture of another crank. Other than the crank being an oddball that was on the shelf in their inventory I don't know why it is made differently. I can tell you its color is an indication that it WASN'T profiled AFTER it was heat treated. It has a 'baked' appearance.
[Re: Chargerfan68]
#3118282
02/02/23 12:38 PM
02/02/23 12:38 PM
HardcoreB
Shelby Twp. Mi
Getting the oil off the crank is a different question, even a sharp tail will do that. The blunt CW leading edges create a lot of drag trying to plow through the hurricane of hot air, oil vapor, blah. Reducing the air density with a pump is a great idea: do both. It's why modern boats have a "bulb" in front of the bow, but a rounded nose was used on the Nile 6,000 years ago. Thank you. That’s what I thought and it made sense in my mind. I am gonna call Crower..,,,then figure out best course of action to have it done. No sense, to me, in trying to accomplish a maximum effort build if I leave details untouched. This seems to be the modern, agreed upon shape at the leading edge: Mine looks like this one!
[Re: Chargerfan68]
#3118323
02/02/23 02:03 PM
02/02/23 02:03 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Getting the oil off the crank is a different question, even a sharp tail will do that. The blunt CW leading edges create a lot of drag trying to plow through the hurricane of hot air, oil vapor, blah. Reducing the air density with a pump is a great idea: do both. It's why modern boats have a "bulb" in front of the bow, but a rounded nose was used on the Nile 6,000 years ago. Thank you. That’s what I thought and it made sense in my mind. I am gonna call Crower..,,,then figure out best course of action to have it done. No sense, to me, in trying to accomplish a maximum effort build if I leave details untouched. This seems to be the modern, agreed upon shape at the leading edge: There can be a lot of power found in the detail stuff. I always figure if I can find 10 places to get just 5 HP that is 50 HP obviously assuming they are not all 10 doing the same thing. 5 HP from a top notch valve job VS run of the mill production shop VJ plus 5 HP from well thought out windage control is 10 HP but 5 HP from well thought out windage control and a vacuum pump that normaly gives you 5 HP would not nessacary be 10 more HP. DISCLAIMER!!! The numbers might not be those exact numbers but just trying to get the IDEA across.
[Re: Ray S]
#3118846
02/04/23 01:32 PM
02/04/23 01:32 PM
Chargerfan68
New York, USA
Thinking on it, if a surface is always up against the web/cap it should not be round; it is not spinning in free air, rather should be shaped like an air dam on that side. Pinching air & oil up against the web will hurt more than a flat edge. This point looks like it could be the reason why this Nascar crank is profiled this way. Good point!
