Distributor Vacuum Advance Can......... #3116536
01/25/23 08:18 PM
01/25/23 08:18 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
....... cap it or use it?
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3116554
01/25/23 09:15 PM
01/25/23 09:15 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
If it’s a street car I would use it . But a street car means a streetcar not a race engine driven on the street.
E here berg has written a ton about this
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3116616
01/26/23 12:21 AM
01/26/23 12:21 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Online content
rumblefish72  Online Content
Understand how the can works, adjust it and use it. Street car with HEMI, B or RB and big cam? Get one of these: VC-1 BB Big Block Mopar Low vacuum signal canister for the big cam, pump gas Pro-Street motors at: https://4secondsflat.com/Mopar%20di...low%20vacuum%20performance%20engines.htm
Check this thread out: https://www.forbbodiesonly.com/moparforum/threads/centrifugal-advance-vs-vacuum-advance.172034/
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Distributor Vacuum Advance Can......... [Re: rumblefish72] #3116648
01/26/23 08:03 AM
01/26/23 08:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use them and won't go back to full centrifugal on the street anymore. but, there is somewhat of a learning curve to set a vacuum advance up on a cammed up engine. i've used all kinds and in the end i haven't found anything more versatile than the factory 9 degree that came in the electronic conversion kits.
Re: Distributor Vacuum Advance Can......... [Re: rumblefish72] #3116689
01/26/23 11:27 AM
01/26/23 11:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This and their mechanical advance limiting plate if you're going to play with initial timing so you don't get to much total mechanical advance.
Re: Distributor Vacuum Advance Can......... [Re: JohnRR] #3116777
01/26/23 04:07 PM
01/26/23 04:07 PM
moparx Offline
moparx  Offline
with any factory distributor used on a modified engine, and even a stocker, one needs to get inside and play with the weights and springs.
every combination of the same components is slightly different, so using specs someone suggests will work, is just the STARTING point.
also be forewarned, this is NOT a 5 minute job..........
it takes some trial and error to get the right weight spring and weight calibration for your combination, THEN, you need to work on the vacuum advance curve.
just my personal experience with distributors over the many years. your mileage will vary.
beer
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3116797
01/26/23 04:55 PM
01/26/23 04:55 PM
What application, fuel used and motor type? shruggy
Re: Distributor Vacuum Advance Can......... [Re: Cab_Burge] #3116838
01/26/23 07:37 PM
01/26/23 07:37 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Street, Premium (93). Stock 440 rebuild. Thanks Cab!
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3116918
01/27/23 01:53 AM
01/27/23 01:53 AM
I would set the total timing (rev up beyond the mechanical advance) to 34 BTDC with the vacuum disconnect and see how you like that and then hook it back up and try that also wrench up
What brand spark plug and heat range are you using? How much mechanical compression ratio and which heads, stock or aluminum?
Re: Distributor Vacuum Advance Can......... [Re: Cab_Burge] #3116988
01/27/23 10:49 AM
01/27/23 10:49 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Champion RJ14YC. The heads are stock cast iron. I do not know the compression ratio.
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3116989
01/27/23 10:52 AM
01/27/23 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you need to change those plugs , they are way too hot
Re: Distributor Vacuum Advance Can......... [Re: JohnRR] #3117091
01/27/23 03:15 PM
01/27/23 03:15 PM
iagree Try RJ12YC or something similar in heat range from NGK or Autolite up scope
Re: Distributor Vacuum Advance Can......... [Re: Cab_Burge] #3117367
01/28/23 10:00 PM
01/28/23 10:00 PM
Kudakidd Offline OP
Kudakidd  Offline OP
AC= GM
Autolite = Ford
NGK = Imports
Champion= Mopar
Verdad!
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3117380
01/28/23 10:26 PM
01/28/23 10:26 PM
AC= GM
Autolite = Ford = Prestolite after around 1970 grin
NGK = Imports
Champion= Mopar
Verdad!
Re: Distributor Vacuum Advance Can......... [Re: Kudakidd] #3117405
01/29/23 12:27 AM
01/29/23 12:27 AM
NGK = No Good Kind wink I used to work at a motorcycle dealership back in the 80's ... when putting in fresh plugs in a Suzuki, all the mechanics would ask the parts guy for a new set of of No Good Kind. We all got a chuckle. It stuck.
