Hemi in E body valve cover clearance #3116810
01/26/23 05:41 PM
01/26/23 05:41 PM
Grand Rapids, MI
472Coronet Offline OP
Grand Rapids, MI
Good afternoon everyone.
I am in the beginning stages of putting together a hemi for my 70 Cuda. I have a BMP block, molar crank and rods, intake, and Edelbrock Victor Jr heads.
I am using an Al Debevic (sp?) k frame, and will be using the small hemi e body power brake booster. Ideally, I am not interested in converting the car to manual brakes.
A few questions. I hope to use Stage V roller rockers, but I am concerned the (stock-ish appearing black wrinkle, but taller and wider) stage V valve covers will not have enough clearance on the passenger side shock tower, and the brake booster. I realize it will be tight no matter what, but I’ve heard horror stories of there being no clearance at all.
I am looking for pictures of something similar to my combination and how tight the clearances are on each side. I do not want to modify the passenger side shock tower.
Again, to sum it up without being too wordy: e body, Debevic k frame, valve covers to fit stage V rockers, and small e body hemi booster. Hoping someone has this combo, or something similar that I can take a look at.
Also, I realize there is currently a thread very similar to my question, using Barton valve covers. I am following the replies there as well.
Thanks to everyone in advance for the help.
Re: Hemi in E body valve cover clearance [Re: 472Coronet] #3116874
01/26/23 10:03 PM
01/26/23 10:03 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
See my post on the other thread. You WILL have clearance problems.
Or skip the prob $4k rockers, run stock units (are you racing?), and stock valve covers.
Re: Hemi in E body valve cover clearance [Re: 472Coronet] #3116978
01/27/23 10:24 AM
01/27/23 10:24 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There is NO extra clearance available on the passenger side for anything larger than OE. And barely enough for the OE.
Then, if you use OE valve covers with just about any roller rockers, you will have the exhaust rockers hitting the valve covers. Been there, done that.
Master, again and still
Re: Hemi in E body valve cover clearance [Re: DaveRS23] #3117061
01/27/23 01:55 PM
01/27/23 01:55 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
[email][/email
Re: Hemi in E body valve cover clearance [Re: HEMI472] #3117063
01/27/23 01:57 PM
01/27/23 01:57 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
mine fits and i can even get them on and off to adjust valves
Re: Hemi in E body valve cover clearance [Re: HEMI472] #3117086
01/27/23 03:04 PM
01/27/23 03:04 PM
Grand Rapids, MI
Grand Rapids, MI
Thank you for the replies so far. It’s interesting how some have zero clearance and a problem, and some don’t.
I’ve been told to get a set of chrome valve covers and paint them black wrinkle. Supposedly the stock appearing chrome valve covers have more room, and Stage Vs will clear? Can anyone confirm this? I’ve also heard of the dual gaskets trick with longer spark plug tubes. I’d be interested to hear about these if anyone has experience with it.
Also, as for the pics above, awesome. Also, did you do anything special to get as much clearance as you have?
Re: Hemi in E body valve cover clearance [Re: 472Coronet] #3117104
01/27/23 04:20 PM
01/27/23 04:20 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
I have a 70 cuda with a bobs pro fab front end with motor plates. I have the barton rocker system, along with larger alum covers. I had to notch the passenger side cover a bit for shock adjustment at top of shock tower, i also dont have a heater in the car anymore, for clearence at the back. On the drivers side i have manual brakes and had to offset brake master. Even with these mods, its tight.
Re: Hemi in E body valve cover clearance [Re: 472Coronet] #3117187
01/27/23 11:20 PM
01/27/23 11:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have MP/ Dick Landy rockers with stock covers and they do hit inside the covers, so you can do what the racers back in the day did and what I did, take a ball end of a ball peen hammer and ding them where they rub, but at least the stock covers clear the shock towers and you can adjust the valves. After a while one of mine started leaking where I kinda put a little hole in it and had to get it welded, also mock it up and check the spring retainers to see if they rub also. Anytime we get away from stock things get complicated squared.
Re: Hemi in E body valve cover clearance [Re: 472Coronet] #3117211
01/28/23 02:32 AM
01/28/23 02:32 AM
P
PasiR Offline
PasiR  Offline
P
Dual gaskets always with OE valve covers if running StageV rollers.
Re: Hemi in E body valve cover clearance [Re: PasiR] #3117215
01/28/23 03:21 AM
01/28/23 03:21 AM
ca
N
nick24 Offline
nick24  Offline
N
ca
I have a '70 Cuda with a Hemi & motor plates. Roller rockers. No heater. I started with chrome covers. The exhaust rockers hit the chrome covers. I tried a few aluminum covers until I chose Stage V.
Stage V covers clear the rockers. I can remove them if I remove the passenger upper shock mount.
