Re: Aluminum Rods & Titanium Valves on the street? [Re: Dragula] #3115960
01/24/23 11:00 AM
01/24/23 11:00 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
CRN Or DLC coating is now used on Titanium valves & will help them last on street duty
Re: Aluminum Rods & Titanium Valves on the street? [Re: CSK] #3116082
01/24/23 04:38 PM
01/24/23 04:38 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Powdered metal seats, {Durabond Killer B for example) are more common, at least more machinist friendly than beryllium copper/bronze. It's all just money but for most people, the Ferrea hollow stem valves are better return on the dollar. Unless you have the heads and are willing to cam to support the high rpm, I would think that taking the titanium valve money and spending it on more cubic inches makes more sense, especially in a mopar situation. S/F...Ken M
Re: Aluminum Rods & Titanium Valves on the street? [Re: EchoSixMike] #3116113
01/24/23 06:09 PM
01/24/23 06:09 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
With lighter valves, any given cam could be used with less spring pressure, better for engine longevity.
Lighter valves doesn't by itself mean you HAVE to rev the motor higher.
Re: Aluminum Rods & Titanium Valves on the street? [Re: Dragula] #3116136
01/24/23 07:25 PM
01/24/23 07:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
British bikes used aluminum rods 70 years ago. Honda 750 got 70,000 street miles.
Limited RPM is the key.
Boffin Emeritus
Re: Aluminum Rods & Titanium Valves on the street? [Re: CSK] #3116217
01/24/23 11:27 PM
01/24/23 11:27 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Correct you are sir! DLC is tougher than CrN however CrN can be reworked whereas DLC requires recoating from the base material. Either coating can be run with a standard seat and both create a very durable valve job.
For a BBC 2.250 +.100 long intake the difference is between steel and Ti is about 50g i.e. 144 vs 92g
Ti valves are more forgiving due to the coatings. Either will require a moly stem coating.
+.300 tip are typically steel insery and .250 use lash caps in many apps so be cautious of that spec.
The Xceldyne rep told be the BeCu seats (and moldstar 90, etc) were employed for heat dissipation more than anything. He also advised me to avoid working with the material without a respirator.
