Is an old waterpump with markings worth holding on to? #311567
05/08/09 10:21 AM
05/08/09 10:21 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I have a old original sb waterpump with the circular stamp with a 71 and the bottom hose inlet that has the pentastar and # 7951571 09104, what i'm getting at is when i restore the car can i get it rebuilt or can i remove the internals of a new pump into the old pump. the pump i have now in my 71 demon is a napa made in japan, great pump but...
Re: Is an old waterpump with markings worth holding on to? [Re: ademon] #311568
05/08/09 10:41 AM
05/08/09 10:41 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Hey Mike
I had searched out a date coded small block water pump for my T/A project and had it rebuilt.
Pete's restorations did mine, not sure if he is still doing that, but even if he is not, I am sure others are.
Re: Is an old waterpump with markings worth holding on to? [Re: Mastershake340] #311569
05/08/09 11:02 AM
05/08/09 11:02 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Thanks Brad the pump i have has a 71 in the center of the pie but with no dot's around it, What month would that be
Re: Is an old waterpump with markings worth holding on to? [Re: ademon] #311570
05/08/09 05:50 PM
05/08/09 05:50 PM
Crook County, ILL
Crook County, ILL
I'm not sure how that style of date code works, hopefully someone here can chime in with the deciphering.
Re: Is an old waterpump with markings worth holding on to? [Re: Mastershake340] #311571
05/09/09 09:40 AM
05/09/09 09:40 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Hi: I think the part number you listed should start with a 2 rather than a 7. There should be at least one dot in that sun pattern surrounding the 71. There are 12 "slices" around the 71 each indicating a month. The same dating system is also on alternators. When was you car built? The date on the water pump should predate your cars SPD by a month or two, or be the same month as your SPD. Thanks for the information about Pete's Resto. I will email him and see if he is still restoring water pumps. I have a whole mess of original ones I need to get done!
Re: Is an old waterpump with markings worth holding on to? [Re: m46rat] #311572
05/09/09 11:40 AM
05/09/09 11:40 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
It does have one dot visable after i cleaned it, But not sure if its usable due to the hose end housing having heavy and deep pitting?
