I'm running an MP .557 cam; was wondering if, from a tuning perspective, closing the lash up .010 (in steps)is too much; spec is .028 int and .032 exh, so I'd be closing up to .018 int, and .022 exh. I know there are "tight lash cams" that run closer than this, but I also know the ramp on the lobe is different also.
Just don't want to cause a cam failure.
If the engine likes tighter lash (more lift) I'll probably go shopping for another cam.
Thanks,
Jim Burch
65 Barracuda, 360, Eddy heads, 11.14 in the quater with almost no tuning yet.
