Re: 11/16 tie rod upgrade, what are the benefits?
[Re: Kern Dog]
#3054950
07/01/22 01:28 PM
07/01/22 01:28 PM
Posts: 1,387 NW Chicago suburban area
Mopar Mitch
Kern Dog -- Regarding boxing the LCA, I wonder how much that is truly worth ... the race Posey T/A and Gurney AAR cars do not have them boxed... maybe SCCA TransAm rules never allowed that to be done. I've boxed my LCAs and run the 11/16" tie rods, and have the K-frame all reinforced... can't tell if it has made any difference (running competition pylon autocross, as well as HPDE/HSAX)... I suppose better to have it done vs not done.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: AndyF]
#3054985
07/01/22 05:04 PM
07/01/22 05:04 PM
Posts: 4,991 nowhere
Sniper
nowhere
One other thing to consider, the longer the tie rod assembly the more likely it is to bend. So you up the diameter My 51 has a real short driver's side assembly, about a foot. The pass side is about three feet long  Yeah, bumpsteer is a thing
[Re: Sniper]
#3055127
07/02/22 05:43 AM
07/02/22 05:43 AM
Posts: 2,437 Answering the call of the wild
ThermoQuad
many benefits no deficits to upgrading the larger hardware other than the wallet
Use the solid aftermarket ones. . same with boxing the LCAs, aftermarket UCA's, firm feel sway bars/steering, strut rods, etc......................
I spent 22+ yrs running hot laps in high performance driving schools on Thunder Road, this is not autocross, one step less than racing, I had a car that could run with the big dogs if i wanted too. Watkins Glen 2x per yr 2days per event Do the math
At each and every 2 day event there were always upgrades that significantly lowered my lap times to the pt i was running under the "number" which is 2.5 minutes for a full lap. I have had a lot of tech support esp at the track.
If anyone want to ask me what works and wants to tune the suspension let alone a six pak please pm me ....I have data not the seat of my pants
[Re: AndyF]
#3056404
07/05/22 04:18 PM
07/05/22 04:18 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
It is a classic mopar debate. Just like regular or high volume oil pumps. LH wheel studs or regular ones, Dana 60 vs Ford 9 inch, etc. People still question a 9" over a 60?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: AndyF]
#3102410
12/14/22 08:57 PM
12/14/22 08:57 PM
Posts: 80 IL
83hurstguy
IL
I always thought the point I made early in this thread was the most valid reason to upgrade and that was cost. I'm not sure if this is still true, but for a long time the C body ends and adjusters were less expensive than the ABE parts. So it was actually cheaper to install the factory 11/16 parts than to replace the stock parts. If they were also stronger then double win. The cheaper reason was still true earlier this year when I bought parts, and it was a pretty noticeable difference. 11/16 parts seemed to make more sense...
[Re: 83hurstguy]
#3102592
12/15/22 02:57 PM
12/15/22 02:57 PM
Posts: 17,240 north of coder
moparx
i just did a quick rock auto search, and that seems not to be the case any more. i always thought the 11/16 chrysler items were cheaper as well. using moog for my search. chysler tie rod - $15.34, and adjuster sleeve - $14.24 dodge tie rod - $13.78, adjuster sleeve - $11.86 so who knows ?
[Re: 83hurstguy]
#3102853
12/16/22 12:27 PM
12/16/22 12:27 PM
moparx
i keep forgetting about the pro forge stuff ! i have been very disappointed in moog stuff for many years because of the downgrade in quality. however, i haven't had the need to replace anything on my own car, so my moog experience is strictly by installing moog parts brought to me for installation on other's vehicles.
[Re: moparx]
#3106253
12/28/22 11:42 PM
12/28/22 11:42 PM
Posts: 1,491 Seattle, WA
375inStroke
Special needs person
Seattle, WA
i just did a quick rock auto search, and that seems not to be the case any more. i always thought the 11/16 chrysler items were cheaper as well. using moog for my search. chysler tie rod - $15.34, and adjuster sleeve - $14.24 dodge tie rod - $13.78, adjuster sleeve - $11.86 so who knows ? Strange. I show $30.79 for the Dodge tie rod ends.
[Re: 375inStroke]
#3108231
01/03/23 05:29 PM
01/03/23 05:29 PM
Posts: 4,157 Wichita
GY3
Wichita
i just did a quick rock auto search, and that seems not to be the case any more. i always thought the 11/16 chrysler items were cheaper as well. using moog for my search. chysler tie rod - $15.34, and adjuster sleeve - $14.24 dodge tie rod - $13.78, adjuster sleeve - $11.86 so who knows ? Strange. I show $30.79 for the Dodge tie rod ends. Lots of places price according to zip code, so that may play into it?
[Re: 375inStroke]
#3115568
01/23/23 12:19 AM
01/23/23 12:19 AM
Posts: 21,967 Trumussia
jcc
Trumussia
I guarantee the greatest force on those tie rods is when parallel parking in a tight spot. With a BB , wide tires, and not rolling, wonder if anyone can feel the difference? LOL
If you can't dazzle them with diamonds, don't waste your time, because nothing will
