Proper A body crush can gap?
#3115172
01/21/23 03:56 PM
01/21/23 03:56 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Had my steering column down to replace all the inside switches etc. bolted the column back in position and the tuff wheel crush can keeps wanting to suck in almost metal to metal at the top (12 o’clock) and a larger gap at 6. The groove on the column shaft is lined up with the groove on the crush can as well. What is proper gap between the crush can and the column? Thinking maybe I can place something flat in the groove at the top perhaps to get that bottom to suck in properly?
GY3 71 Demon 340
Re: Proper A body crush can gap?
[Re: spk2go]
#3115205
01/21/23 06:07 PM
01/21/23 06:07 PM
ricomondo
It does have the small master spline inside and its lined up with the female groove on the column spline.
GY3 71 Demon 340
[Re: TJP]
#3115419
01/22/23 02:07 PM
01/22/23 02:07 PM
ricomondo
Ok everyone I got it!!
BUT, not for lack of my laziness. I took the advice here and made sure the column was COMPLETELY bolted up, not just under the dash but at the firewall as well. I only had the column loose in the firewall with the bolts just threaded in a couple of turns, but tight under the dash. Upon bolting it up the proper way, the tuff wheel can installed like butter. Guess the "geometry" has to be just right.
Thanks again to everyone that took time to respond greatly appreciated!
GY3 71 Demon 340
