Page 1 of 5 1 2 3 4 5
W9 Small Block - Quest for the 9's #3114684
01/19/23 11:29 PM
01/19/23 11:29 PM
WNY
Moparrob68 Offline OP
WNY
After spending over 2 years building a W9 Ritter block 434 the performance results are a little disappointing. I was expecting this engine combo to easily put the dart in the 9 second zone.Any tuning suggestions greatly appreciated.
Car details:
1972 Dart Bracket car, 3275 lbs w/driver 51/49% wt list
Ritter 48* Block
4.175 bore
4.00" stroke Scat Ultralight
Manley M300 rods w/ CARR 5/16 bolts
Diamond dish pistons 13.25 comp
W9 heads fully CNC ported by Tilburg Racing Engines in Trout Run, PA
2.15 / 1.60 Titanium valves
Mopar "420" 4150 manifold ported by Tilburg
Bullet Roller 275/280 Dur .730/.725 Lift 110 cam
Jesel 1.65 Rockers
950 Promax carb
1" SuperSucker spacer
1 7/8-2" step 3 1/2 collector custom headers
727 race trans
Turbo Action 4600 converter, Flashes 5000
Dana 4.88
12.2 / 31.25 Phoenix slicks
Leaf / Ladder bars
QA1 single adj shocks
36* timing
Foot brake 2500 launch / 7800 shift
Tried a 9375 1050 Dominator on a 1.5" adaptor and it went 0.05 faster on a sketchy track at the end of the season
416 car no. on time slips
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114686
01/19/23 11:32 PM
01/19/23 11:32 PM
WNY
WNY
W9 head and intake pics
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114688
01/19/23 11:34 PM
01/19/23 11:34 PM
WNY
WNY
Engine pics
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114692
01/19/23 11:42 PM
01/19/23 11:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m not a W9 guy but your converter stall needs raised bigtime, and I mean bigtime
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W9 Small Block - Quest for the 9's [Re: pittsburghracer] #3114700
01/20/23 12:10 AM
01/20/23 12:10 AM
WNY
WNY
I talked to Paul at turbo Action yesterday and he suggested rebuilding the converter with 5500-5700 stall. ATI wanted to build one similar to what we have 3000 launch 5000 stall
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114706
01/20/23 12:24 AM
01/20/23 12:24 AM
PA.
"Little"John
"Little"John
PA.
Still not high enough for a W9 combo. Edelbrock heads like mine A 5800 is ok.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114715
01/20/23 01:11 AM
01/20/23 01:11 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
My old 9w 440 with 11-1 pump gas went 9:50. Yor cam is close to the one I had. My converter was 5000 stall, 456 gear, 904 w/ brake. What are your flow numbers? Something’s off.
Re: W9 Small Block - Quest for the 9's [Re: rickraw] #3114720
01/20/23 02:12 AM
01/20/23 02:12 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My converters when I ran my 727 were 5800 and 6200 stall. Not going to pick up the 10+ mph you’re lacking though. Would have been interesting if it were dynoed.
264-272 at .050" 108 LSA .750" lift at retainer is what I’m running for a cam which is smallish in the W8/9 circles. 4.56 gear 29.5x10.5 tire. Been a really reliable set up. Dynoed 773 @7200.
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114723
01/20/23 02:34 AM
01/20/23 02:34 AM
AndyF Offline
AndyF  Offline
Looks great and I'd say you have all the right parts. Don't get discouraged, you just need to work at it. Do you have a data logger in the car? A data logger can really speed up the learning curve. If it is a new combination then don't be surprised to find several tenths in the details. Shock settings, tire pressure, converter, carb tuning, cam tuning, ignition curve, etc.
Re: W9 Small Block - Quest for the 9's [Re: AndyF] #3114742
01/20/23 08:05 AM
01/20/23 08:05 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
It seems to me that the car is very under geared. The motor isn’t getting into its power range to move the car. The most important thing you could do now is take the motor out and dyno it. Then you will know what converter and rear end ratio you need without guessing. When you get that right you will see drastic improvement.
Re: W9 Small Block - Quest for the 9's [Re: ValiantRich] #3114744
01/20/23 08:39 AM
01/20/23 08:39 AM
San Antonio, Tx
bulletpruf Offline
bulletpruf  Offline
San Antonio, Tx
That would be my recommended course of action as well.
Beautiful car, by the way.
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: W9 Small Block - Quest for the 9's [Re: ValiantRich] #3114747
01/20/23 08:48 AM
01/20/23 08:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I only worked on one 440 ci small block, It had 360-1's on it but I'm pretty sure it wasn't shifted at 7800. If you over rev at shift points It can slow it down pretty good.Converter is way off.Think of it this way the stall/flash should be within 1000 rpm of the shift point. So either you need a 6800-7000 converter, or you need to shift at 6000.
I would be curious what the cranking compression is.
A 440 cube small block with a 275 at .050 should make a lot of down low power.
Re: W9 Small Block - Quest for the 9's [Re: Moparrob68] #3114749
01/20/23 09:02 AM
01/20/23 09:02 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I agree with others, you need more stall, I think it needs more carb too. Did you dyno the engine? Have you tried less timing? My Indy headed 434 made the most power at 34°, any more and power fell off. I'd talk to your head guy about converting the intake to a dominator flange.
IMHO your 60' and 1/8 mile et and mph are down too. My street/strip Dart has been 6.25 @ 110 and 10.008 @ 134.75 on pump 93 at 3293#, foot braking at 2000 rpms. it went 6.33 @ 109 in street trim last fall. The engine is 4.125" stroke and 4.09" bore R1, 11.2-1, 266/271° @ .050", .711/.719" at the retainers, ported Indy 360-1's and ported Indy intake, a 1050ish Thumper built 4150, 1 7/8" Hedmans. 727, Coan 8" that flashes 5600, Strange S-60 with 4.10 gears, Cal-Tracs, monos and Viking D/A all around. It's currently on a 275 radial, but previously was on a 325 radial. The engine made peak power at 6750 on an engine and chassis dyno, I shift it 68-6900 rpms.
I think my car will run well into the 9.90's in decent conditions. With some tuning you should run a couple tenths faster than mine. Keep after it, you'll get there. Great looking Dart too.
Re: W9 Small Block - Quest for the 9's [Re: justinp61] #3114751
01/20/23 09:11 AM
01/20/23 09:11 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Converter ain't converting
Re: W9 Small Block - Quest for the 9's [Re: justinp61] #3114754
01/20/23 09:24 AM
01/20/23 09:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I know they’re all different, but we got better numbers with 31-32 degrees of timing.
Re: W9 Small Block - Quest for the 9's [Re: J_BODY] #3114763
01/20/23 09:42 AM
01/20/23 09:42 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i im no expert but i dont know if any of u guys ever seen my cuda run but for what it is shes a nasty bi@!@@## 60foot 127 on a foot brake 418 small motor
Re: W9 Small Block - Quest for the 9's [Re: one bad fish] #3114764
01/20/23 09:50 AM
01/20/23 09:50 AM
bronx n.y
O
O
bronx n.y
Re: W9 Small Block - Quest for the 9's [Re: one bad fish] #3114765
01/20/23 09:53 AM
01/20/23 09:53 AM
bronx n.y
O
O
bronx n.y
Re: W9 Small Block - Quest for the 9's [Re: one bad fish] #3114774
01/20/23 10:09 AM
01/20/23 10:09 AM
bronx n.y
O
O
bronx n.y
Re: W9 Small Block - Quest for the 9's [Re: B1MAXX] #3114785
01/20/23 10:33 AM
01/20/23 10:33 AM
WNY
WNY
200psi cranking compression
