Re: Does this sound like a Thermoquad problem?
[Re: Dusted_Ya]
#311423
05/08/09 09:44 PM
05/08/09 09:44 PM
Posts: 5,270 Missouri
MY340
Missouri
Possibly a float stuck or needle stuck open. Clean it with some carb cleaner and check adjustments. If after reinstalling it still runs crappy & backfires I'd agree with timing issues. Don't forget to check your dizzy too!
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: Dusted_Ya]
#311426
05/09/09 01:19 AM
05/09/09 01:19 AM
Posts: 857 The Dalles, OR.
Dusted_Ya
The Dalles, OR.
Update: Okay this if freaken wierd! When I replaced the distributor with a new one I hand turned the crank to 5deg. before TDC and popped the distributor cap to make sure that the rotor was pointing at #1 and the pickup and reluctor were in perfect alignment (and it was). Then I replaced the distributor, cap and rotor with a new one and re-aligned the rotor, pickup and reluctor. It didn't start again so I assumed it was something else but after everyone was saying timing I put a timing light on it and it is not firing any where NEAR 5deg. before TDC!!! [Edited by Moparts - Keep it clean]!!! And I found out the previous owner had the same problem with this truck (wouldn't start/run). I just assumed the motor was bad! What could possible cause such a change in the signal from the time it leaves the distributor to the time it returns to the distributor? Could a wire be grounding out somewhere between the distributor and the ECU or between the ECU and the coil and cause this type of delay?
This is wierd sh#%! Time for a Petronics...
