Main bearing replacement in car? #3112044
01/15/23 07:09 AM
01/15/23 07:09 AM
Detroit, MI
CokeBottleKid Offline OP
Detroit, MI
Just curious, has anyone successfully spun in new main bearings in a block before?
Re: Main bearing replacement in car? [Re: CokeBottleKid] #3112047
01/15/23 07:21 AM
01/15/23 07:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have done it on the stand, same principle applies because I took nothing else apart. Roll them out and roll them in. In the car it will be the same but just add oil dripping on you haha.
68 Barracuda Formula S 340
Re: Main bearing replacement in car? [Re: Bad340fish] #3112058
01/15/23 09:35 AM
01/15/23 09:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've done it. Its' easiest to loosen all 5 main caps. The thrust is the toughest. I used a nylon trim stick and tapped on it with a hammer to get it started. The rest is easy.
Doug
Re: Main bearing replacement in car? [Re: dvw] #3112065
01/15/23 09:57 AM
01/15/23 09:57 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The make a tool for that but it's kind of spendy. I've seen people do the same thing with a big cotter key but I have personally used neither.
Bearing Removal Tool
Re: Main bearing replacement in car? [Re: dvw] #3112070
01/15/23 10:19 AM
01/15/23 10:19 AM
USA
hudsonhornet7x Offline
USA
Doug
I did two of them the same way, one a big block Chrysler, and one straight six Jeep. DVW has the right idea here.
Re: Main bearing replacement in car? [Re: hudsonhornet7x] #3112078
01/15/23 10:47 AM
01/15/23 10:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
As an experienced engine builder that believes every bearing clearance is critical to the oil pressure and life of the engine. And the only way you can accurately check the clearance is to the measure the crank and bearing journals separately to find the proper clearance. I have to ask this question? Why would you ever need to change the main bearings without removing the crank? Just curious.
Re: Main bearing replacement in car? [Re: fastmark] #3112111
01/15/23 12:19 PM
01/15/23 12:19 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
A very long time ago I saw something like this use successfully.
Not sure why the engine and crank were not removed.
https://tescotools.com/products/t68660-upper-main-bearing-shell-remover
Re: Main bearing replacement in car? [Re: 340Cuda] #3112116
01/15/23 12:32 PM
01/15/23 12:32 PM
central il.
second 70 Offline
second 70  Offline
central il.
I remember back in auto shop in the 70's they had a bit that would go in the oil journal of the crank and had a flat tee on the top of it and you would turn the crank and the T would catch the bearing and just roll it out. Install rotate opposite direction. Looks like the tool listed above.
I've installed them just like Doug said too.
Re: Main bearing replacement in car? [Re: CokeBottleKid] #3112120
01/15/23 12:46 PM
01/15/23 12:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Many years ago a friend and I changed the main bearings on a Ford engine in a one ton truck, wasn't any trouble at all.
Re: Main bearing replacement in car? [Re: CokeBottleKid] #3112173
01/15/23 04:18 PM
01/15/23 04:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
Replacing number five main bearing is the bear due to the main seal. shruggy
I use a small flat narrow bladed screwdriver to start the push the main bearing out of the retainer from the other side of the retaining tang,
As already mentioned, that is with all main caps being loose and drop down a little bit from the block, remove the bolts for each one at a time and then put them back in when your done installing the new main bearings to help keep the crank a little loose so it doesn't press hard up against any of the upper main bearings until you're ready to torque all of them, make sure to check and have enough thrust clearances also scope wrench. twocents
Re: Main bearing replacement in car? [Re: Cab_Burge] #3112822
01/17/23 10:13 AM
01/17/23 10:13 AM
an8sec70cuda Offline
Yep. I used a small screwdriver to tap it and just took my time. Changed out a severely worn thrust bearing in a 440. Long story, but it was a bandaid fix that worked for a while.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Main bearing replacement in car? [Re: an8sec70cuda] #3112881
01/17/23 02:32 PM
01/17/23 02:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've done it. Wouldn't do it on something good.
Small screw driver or flat scraper shaped tool. Tap on the edge of the bearing opposite the lock to get it moving around. It will only go so far with the tool.
I've used the small screwdriver type tool with the edge sharpened, and narrow enough to fit the lock tang slot, to use the slot and walk the thing around until it will come free.
Also used cotter pins with the head flattened, stuck in an oil hole and rotate the crank around to push it out.
Have to be careful not to ding the crank.
Re: Main bearing replacement in car? [Re: an8sec70cuda] #3113012
01/17/23 09:23 PM
01/17/23 09:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
MoparBilly is smiling down on this post smile I’m sure if it needed to be done…. he did it. I’ve only done that with rods when we got silly with a nitrous tune (we couldn’t tune laugh2 ). At least I see I was in good company
Re: Main bearing replacement in car? [Re: J_BODY] #3114175
01/18/23 01:19 PM
01/18/23 01:19 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
As you see a lot of ways to skin a cat..do it!
Re: Main bearing replacement in car? [Re: HardcoreB] #3114745
01/20/23 08:42 AM
01/20/23 08:42 AM
Northern VA
bulletpruf Offline
bulletpruf  Offline
Northern VA
Curious as to why you're thinking about going this route. Doesn't take long to yank an engine.
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Main bearing replacement in car? [Re: bulletpruf] #3114770
01/20/23 10:04 AM
01/20/23 10:04 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
My lower back and neck were telling me the same thing!
'63 Dodge 330
11.19 @ 121 mph
Re: Main bearing replacement in car? [Re: bulletpruf] #3114791
01/20/23 10:38 AM
01/20/23 10:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Main bearing replacement in car? [Re: 6PakBee] #3115004
01/20/23 10:15 PM
01/20/23 10:15 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
Done it many times on rb mopar engines . Flatten the top of a cotter pin and use it to rotate the bearing out and the new one in. Works very well,
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Main bearing replacement in car? [Re: 6PakBee] #3115108
01/21/23 12:31 PM
01/21/23 12:31 PM
BDW Offline
BDW  Offline
Great meme, after pulling my Gen3 swap 3 times, I understand it’s not as easy as thought
Re: Main bearing replacement in car? [Re: CokeBottleKid] #3115132
01/21/23 01:59 PM
01/21/23 01:59 PM
AndyF Offline
AndyF  Offline
Sure, people do it all the time. Not really a long term solution but sometimes you have to do what you have to do. Falls into the category of quick and dirty.
