k frame coin id? #3112172
01/15/23 04:17 PM
01/15/23 04:17 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
I have a 70 e body K frame with a round coin and the number 06 on it. I cant find any info on this. Has anyone seen this? thanks Guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: k frame coin id? [Re: stickman] #3112212
01/15/23 06:55 PM
01/15/23 06:55 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I believe the 06 would be the last two digits of the k-frame part number.
Crap shoot if you have a k frame with a coin or not.
Discussion from two years ago.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2832870/k-frame-coins.html
Re: k frame coin id? [Re: skdmark] #3112218
01/15/23 07:11 PM
01/15/23 07:11 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
[I cant seem to find a 06 stamped coin anywhere or what it would indicate.
Re: k frame coin id? [Re: stickman] #3112315
01/15/23 11:20 PM
01/15/23 11:20 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
It's probably 90 not 06. Doing a little searching I found references to 90 not 06.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2309970/k-frame-coin.html
Both of my 71 e-bodies are "52"
