Page 1 of 3 1 2 3
Well I just jinxed myself big time... #3111114
01/12/23 10:17 AM
01/12/23 10:17 AM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
Put an ad on here to sell my 2015 Cummins Ram and got bit. Travelling down I-71 in Ohio last night with my 24' enclosed trailer and kicked it down uphill to pass a semi, guess what happened? Yep, the trans went freewheeling of course. It was running perfectly up until the point, don't know what happened but it is definitely toast! Got towed into a local Ram dealer, my brother in law is on the way to rescue me. I had a great 2022, doesn't look like 2023 will continue the trend... frown
JB Rhinehart, Realist
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111124
01/12/23 10:36 AM
01/12/23 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It was only a matter of time , it has a new trans now so might as well keep it ???
Re: Well I just jinxed myself big time... [Re: JohnRR] #3111198
01/12/23 02:19 PM
01/12/23 02:19 PM
moparx Offline
moparx  Offline
i often wonder what was done to the transmission gods that they have it in for rhino ?
beer
Re: Well I just jinxed myself big time... [Re: moparx] #3111251
01/12/23 04:16 PM
01/12/23 04:16 PM
Rhinotruck
Rhinotruck
I should have been a factory transmission tester. Found out a trans line came off, just gotta find out if there is any damage from driving it off the highway a mile with no fluid in it.
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111272
01/12/23 04:54 PM
01/12/23 04:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There would be a little fluid in it...obviously depends on how quickly it was pouring out.
I've accidentally driven a Turbo400 about 1/4 mile with a bad hose leak (add-on ATF cooler) pouring out & making a big mess.
Fixed it, poured maybe 10 quarts of ATF back in, been fine since (happened 5 years ago).
I've since updated the hose/pipe setup so it can't happen again.
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111372
01/12/23 09:19 PM
01/12/23 09:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I blew the trans cooler line off the RE46 in my truck, dumped 9 quarts of ATF+4 onto the road, and coasted into a parking lot. I fixed the line, filled it up with ATF and it functioned, but lost OD. I should have pulled the pan but didn't. I expected the trans was junk, so I just filled up and off I went. My trans doesn't have 200,000 + miles on it though.
Loosing the OD for you would be bad. I'd probably put in new solenoids and change the filter and try filling it up, might be OK.
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111401
01/12/23 10:33 PM
01/12/23 10:33 PM
Guitar Jones Offline
Didn't you just have some repairs done on that recently?
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111454
01/13/23 07:03 AM
01/13/23 07:03 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Over the years there have been so many posts about
external ATF cooler line check valves,
leaking external lines
and engine coolant contamination of ATF
on Chrysler vehicles.
If you spec an OEM ATF that can keep its lube properties at higher temperatures for longer,
many of the above “failure modes” disappear.
It might be possible to design in more external ribs on the aluminum trans casing to carry away heat without a cooler.
My gut tells me:
one transmission and differential
should outlive two engines
because conditions inside an engine are more extreme
but in the real world that has not been true for several decades.
But obviously that is not the root cause of Rhino’s trans curse.
Sometime in the distant past he thought some profane thought about transmissions,
and now the GODS of gears are angry.
A goat must be sacrificed on a mountain top.
Re: Well I just jinxed myself big time... [Re: 360view] #3111471
01/13/23 08:56 AM
01/13/23 08:56 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
"A goat must be sacrificed on a mountain top."
What does Pontiac have to do with all this? confused
John
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111481
01/13/23 09:54 AM
01/13/23 09:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
“Kicked it down uphill to pass a semi”….
With your trans history why do I see you mashing your foot to the floor?
I built a 47RE for my 01 at 34k miles. Even when I sold it last year at 200k it was not even in my head as a worry. Of course I probably only had it “kick down” a handful of times, usually when one of my friends was doing driving duties and didn’t know the idiosyncrasies of piloting that set up. I preferred to not let that happen as pulling a load and having the converter unlock, make the shift, and then apply again can be a shock especially under load.
My 17 3500 has the Aisin. Love the lower 1st gear and it’s much more relaxing to drive than the 01 was.
Re: Well I just jinxed myself big time... [Re: Guitar Jones] #3111497
01/13/23 10:57 AM
01/13/23 10:57 AM
Rhinotruck
Rhinotruck
I just had oil and fuel filters done right before the trip, never had a trans service done as I have owned the truck for less than a year and the fluid was pink and full. One question I have now, should I have the trans filter changed when they put the new cooler lines on or find out if the trans is still good then change the filter? $102 for trans fluid right now. Also, on my 2015 5.7 Hemi truck that had the trans changed at 280K miles, shortly afterwards the trans cooler line started leaking and had to have them changed. Is there a known problem with the lines? shruggy
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: J_BODY] #3111498
01/13/23 11:01 AM
01/13/23 11:01 AM
Rhinotruck
Rhinotruck
I did not mash my foot to the floor, typical situation on a three lane highway going up hill and the semi's were jogging for position so I didn't want to lose my momentum too, so I kicked it down about 3/4 throttle to get to the inside lane and get around them. The RPM's went redline and it was tricky to get back to the outside lane and onto the shoulder. It is a 68RFE trans and I take it out of overdrive when I haul the enclosed trailer. Too many damn semi's out there nowadays with steering wheel holders driving them and very few professional drivers... mad
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111537
01/13/23 12:13 PM
01/13/23 12:13 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
This is SO true!! There have been several several real bad accidents in this area caused by these "steering wheel holders" in recent months. I'm talking about drivers that were intoxicated, high on drugs, etc. In another case, a tanker driver went around a corner to fast and rolled his truck. He was hauling a hazardous chemical which leaked out resulting in a massive clean up mess! It took about 24 hours to clean it up. During that time, the Interstate was closed in BOTH directions!!
My father was a professional driver many years ago. Back then, when semi trucks were involved in an accident, the accident was typically caused by the driver of a car doing something stupid.
Back to the subject of transmissions, I hope Rhino's truck can be easily repaired.
Re: Well I just jinxed myself big time... [Re: QuickDodge] #3111622
01/13/23 02:53 PM
01/13/23 02:53 PM
moparx Offline
moparx  Offline
all i can offer on repair advice...........if you ever get close to Brookville, Pa. Rhino, let me know and i will get my tool box ready for ya ! [just in case, of course] whistling no biggrin
beer
Re: Well I just jinxed myself big time... [Re: moparx] #3111662
01/13/23 04:12 PM
01/13/23 04:12 PM
Rhinotruck
Rhinotruck
beer
Thanks, I actually stayed at the Super 8 in Brookville late last year, go that way often... wave Had some good BBQ at Devil's BBQ that night too!
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111750
01/13/23 09:32 PM
01/13/23 09:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The trans has no fluid in it now, changing the filter shouldn't add that much to the cost. The reality is, if the trans is OK, you won't want to dump the new fluid to change the filter and then refill it, one less thing to be concerned about If it needs to be rebuilt, you will loose the fluid anyway, the only extra cost is the filter, pan gasket, and whatever labor to change it. If it works, your good until the next scheduled fluid change.
Re: Well I just jinxed myself big time... [Re: SattyNoCar] #3111751
01/13/23 09:35 PM
01/13/23 09:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
He has already pre-sacrificed a firebird in a flaming garage sacrifice, doesn't that cover the goat sacrifice?
Re: Well I just jinxed myself big time... [Re: poorboy] #3111755
01/13/23 09:45 PM
01/13/23 09:45 PM
Rhinotruck
Rhinotruck
Originally Posted by poorboy
[quote=Satilite73]
He has already pre-sacrificed a firebird in a flaming garage sacrifice, doesn't that cover the goat sacrifice? [/quote
All that did was piss off the wife. She didn't think it was funny when I said she had a true FIREbird... panic They told me $350 for a filter change at the dealer that is installing the lines and the mechanic thought it would be a waste of time and money if the trans is indeed smoked...
A-Body's RULE!
Re: Well I just jinxed myself big time... [Re: Rhinodart] #3111789
01/14/23 01:31 AM
01/14/23 01:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
[quote=Satilite73]
How do they justify $350 to drop the the pan and change the filter???
Kevin
Re: Well I just jinxed myself big time... [Re: Twostick] #3111837
01/14/23 11:13 AM
01/14/23 11:13 AM
Rhinotruck
Rhinotruck
[quote=Satilite73]
Kevin
Over $100 for trans fluid, who knows how much for a filter through a dealer plus the gasket, doesn't matter if it has anything in it or not. I am sure the labor is $150 on the schedule... work
A-Body's RULE!
Page 1 of 3 1 2 3
