Re: 8 3/4 chuck vendor
[Re: Neil]
#3111451
01/13/23 06:12 AM
01/13/23 06:12 AM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
I use DoctorDiff on all my parts buys. He has a nice surgrip that he sells. If you find a used one with the old style clutches, he can sell you a new clutch pack. The 69 up oem suregrip can fail after long term use and can’t be rebuilt. However, I’ve owned many of those and they all worked fine. Buying a used anything is a crap shoot now days. After all, the parts are 50 years old. That’s why I sell his new suregrip to my customers.
[Re: fastmark]
#3111546
01/13/23 12:34 PM
01/13/23 12:34 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
Another vote for the good doctor. Bought all of the parts to build my D60 from him.
[Re: IROC78]
#3111747
01/13/23 09:22 PM
01/13/23 09:22 PM
Posts: 20,547 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Ok, if Dr. Diff is not an option how about Mancini, or Randy's Ring and Pinion?
A shop that does 18 wheeler drivetrain service work should be able to do a gear swap as well if you give them the specs and parts. Cheaper to rebuild what you have vs a new one + shipping.
[Re: bobby66]
#3111835
01/14/23 10:52 AM
01/14/23 10:52 AM
fastmark
Abilene, Texas
Well, I’m a do it your self guy because I can’t find a shop or contractor, for that matter, that can’t do the job right. Most everyone just wants to get done and get paid. And most customers can’t understand the process well enough to know what it takes to do the job correctly and don’t want to pay for that service. Over the years I’ve collected the tools and knowledge to do most jobs associated with rebuilding these old Mopars. It’s my passion, not a job. I started doing a few jobs to pay for my tools and the overhead for my big shop. I’ve got a press, the clamshell pullers and the $1000 setup tool that no shop in town has. They just guess, then run a pattern. Get it close then out the door and if it whines, just blame in on” well sometimes these gears just whine a bit”. I watched a shop do that just the other day. And they are one of the better ones. Anyway, I cook the case, clean, paint, change the bearings, gears and using my setup tool, I set the depth and run a pattern. It’s perfect when it leaves my place. I do all that labor for $650. Some gears are harder than others to get it right. I can get all the jobs I want and never had a job complaint from noise. Most shops don’t go through all the steps I do and don’t charge as much, but they know what there service is worth. That’s why I do it myself.
From my understanding. These new cases all come from the same place and are slow in coming like everything else. Cass can make more money selling parts than building them and with no help, it would be worse. He’s a volume dealer instead of one of these guys that tries to make a lot off of one sale. I sure can’t complain about him. He’s always been good to me or anyone else I send his way. You are just as good in using your oem case and rebuilding it. I’ve done many and never had a problem.
[Re: Pacnorthcuda]
#3114944
01/20/23 06:00 PM
01/20/23 06:00 PM
Posts: 4,727 Florida
BDW
Pumpkin, This is always what I heard them called
[Re: 70X]
#3115001
01/20/23 10:02 PM
01/20/23 10:02 PM
Posts: 15,355 Omaha Ne
TJP
Omaha Ne
