Timing Cover oil seal difference #3110826
01/11/23 12:54 PM
01/11/23 12:54 PM
VA
dragon slayer Offline OP
VA
The parts book had a different part number for the Big Block versus small block TC oil seal vintage 1970? What is the difference? Current seals seem made to fit either.
Re: Timing Cover oil seal difference [Re: dragon slayer] #3111836
01/14/23 11:04 AM
01/14/23 11:04 AM
VA
VA
Nobody knows?
Re: Timing Cover oil seal difference [Re: dragon slayer] #3111861
01/14/23 01:28 PM
01/14/23 01:28 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by dragon slayer
Nobody knows?
Me recollection is they are the same but the B/RB had a flange that limited how far it would go in the cover while the A was just a “bell” type.
Re: Timing Cover oil seal difference [Re: A727Tflite] #3111898
01/14/23 03:16 PM
01/14/23 03:16 PM
AndyF Offline
AndyF  Offline
Originally they were different but eventually someone at Chrysler was smart enough to figure out that they could be the same part. There are lots of examples of stuff like this. Chrysler Engineering was very poor at reuse and simplification during the 60's and 70's but gradually they started to figure things out and they worked to consolidate part numbers over time.
Re: Timing Cover oil seal difference [Re: AndyF] #3112080
01/15/23 11:00 AM
01/15/23 11:00 AM
VA
VA
Ok thanks. Going thru a box of these in original Mopar parts box. I thought might be a subtle width difference. These are all flanged. There are a few examples that are much wider, but that seems to be a late 50s early 60 seal from what I see on ebay, so I guess a different timing cover in that time frame.
